Workforce: When "Lessons Learned" Never Actually Change Anything
Repeated safety recommendations often fail to drive change. Plant leaders can build a culture that turns incident reporting into genuine learning.
Key Highlights
  • Most organizations don't fail to investigate incidents — they fail to create the conditions for genuine learning. Documenting lessons is much easier than changing behaviors.
  • Defensiveness is one of the biggest barriers to improvement. When people feel their reputation or status is under threat, protecting themselves often takes priority over understanding what really happened.
  • Psychological safety is a performance issue, not simply a cultural one. Teams that feel safe to question assumptions, report concerns and admit uncertainty are better equipped to identify and manage risk.
  • Leaders don't need more bureaucracy to improve learning. Asking better questions, encouraging challenge, listening to quieter voices and rewarding curiosity can have a far greater impact than introducing another process.
Imagine you worked at the BP Texas City refinery before the explosion on March 23, 2005. You'd attended incident reviews, seen audit findings discussed and watched actions being assigned. Like many major industrial sites, the refinery had processes for investigating incidents and identifying improvements. Then, on March 23, 2005, an explosion killed 15 people and injured more than 170 others.
Following the incident, the U.S. Chemical Safety and Hazard Investigation Board concluded that the refinery lacked a "reporting and learning culture," identifying repeated failures to act on previous incidents, audit findings and safety recommendations.
Most organizations will never experience an incident on the scale of Texas City. But many experience the same pattern on a smaller scale. A near miss is investigated. Recommendations are made. Actions are assigned. Everyone agrees improvements are needed. Six months later, remarkably little has changed.
The problem isn't that organizations don't know how to investigate incidents. Most have robust processes, experienced investigators and detailed reporting systems. The challenge is that documenting lessons is much easier than changing behavior.
When Learning Becomes Blame Theater
Following an incident, people rarely set out to avoid learning. Instead, they begin protecting themselves. Managers defend previous decisions. Departments explain why the issue wasn't theirs. Individuals justify why they acted as they did. Without realizing it, the conversation shifts from "What happened?" to "How do we make sure nobody thinks this was our fault?" I call this blame theater.
Unlike open finger-pointing, blame theater often sounds entirely professional: "Communication could have been better." "Additional training will be provided." "The procedure will be updated." These actions may all be necessary, but they can also become a substitute for asking more difficult questions. If every investigation ends with another procedure or another training course, are we fixing the system, or are we creating the appearance of learning?
Defensiveness Prevents Learning
Experience saves lives in high-risk industries, but it can also make admitting uncertainty feel uncomfortable. The more someone is recognized as an expert, the harder it can become to acknowledge that they may have missed something. Defending previous decisions can feel psychologically safer than questioning them. That defensiveness comes at a cost.
Curiosity disappears. Alternative explanations receive less attention. Different perspectives become less welcome. Eventually, the investigation is complete, but the organization has already lost its opportunity to learn.
Most corrective actions focus on systems by updating procedures, delivering refresher training or adding more approvals. Far fewer examine the behaviors that allowed the issue to develop in the first place.
  • Did someone hesitate to challenge a decision?
  • Were concerns dismissed because of who raised them?
  • Did production pressure quietly outweigh operational caution?
Unless organizations are prepared to explore these questions, they risk creating more paperwork while leaving the underlying culture unchanged.
What Leaders Can Do Differently
Creating a stronger learning culture doesn't require more bureaucracy. It requires better conversations. Instead of asking, "Who made the mistake?" ask, "What made this decision seem reasonable at the time?" This shifts the discussion from blame to understanding.
Invite quieter voices into investigations. New starters, contractors and junior engineers often notice assumptions that experienced teams have stopped questioning.
Finally, recognize people who raise concerns before they become incidents. Rewarding curiosity sends a far stronger signal than simply rewarding outcomes.
Every organization says it wants to learn. Far fewer create the conditions where people feel safe enough to tell the organization what it truly needs to hear.
In chemical processing, we invest heavily in improving our equipment, our procedures and our technology. We should apply the same attention to the human factors that determine whether learning actually takes place.
Until organizations replace defensiveness with genuine curiosity, "lessons learned" risk becoming little more than well-formatted documents while the same patterns continue to repeat themselves.
Lauren Neal
Lauren Neal
Founder and Chief Program Creator, Valued at Work
Lauren Neal is the founder of Valued at Work, a consultancy helping STEM and technical organizations build workplaces where people thrive, and results rise.
With over 20 years of experience as an engineer and project manager delivering complex, multimillion-dollar projects globally, Lauren understands firsthand how leadership, team dynamics and culture directly impact performance under pressure.
She now works with senior leaders in male-dominated industries to move beyond tick-box inclusion efforts, embedding practical, people-centered systems that improve retention, strengthen leadership capability and unlock high-performing teams.
Chartered through both the Institution of Engineering and Technology (IET) and the Association of Project Management (APM), Lauren is a sought-after speaker, writer and consultant known for her straight-talking, commercially grounded approach to workplace culture.
Her book, Valued at Work: Shining a Light on Bias to Engage, Enable, and Retain Women in STEM, became a #1 best-seller and was shortlisted for the 2024 Business Book Awards and the Institute of Leadership’s 2024 Leadership Book of the Year.
Learn more at: valuedatwork.com
