Plant InSites: Double Check Your Physical Properties Data
Inconsistencies found across major references for common substances raise a harder question about what we assume we know and whether that's enough for design, operation and troubleshooting.
Key Highlights
- Physical property data is less reliable than engineers assume. Across three major references, more than half of 73 common chemicals showed boiling point discrepancies — not just rounding differences, but gaps large enough to affect calculations built on those values.
- The references themselves have hierarchy and hidden flaws. The API Technical Data Book is the most traceable but least accessible. The CRC Handbook is the most complete but contains internal inconsistencies for the same compound depending on how it's indexed. Perry's widely used summary tables (3-1 and 3-2) are the least reliable, while its lesser-known vapor pressure tables (3-7 and 3-8) are more accurate — a distinction most users never make.
- Knowing your uncertainty is part of doing the job. Whether the data feeds a training handout or process simulation software, engineers need to understand the accuracy limits of the values, correlations and thermodynamic methods they rely on — not because perfection is achievable, but because troubleshooting depends on knowing when an answer should be trusted.
