OSHA’s Hazard Communication Deadline Is Here
The compliance deadline for the U.S. Occupational Safety and Health Administration (OSHA) Hazard Communication Standard (HCS), 29 C.F.R. Section 1910.1200, has finally arrived. The Nov. 20, 2026, compliance date follows the May 19, 2026, compliance deadline for manufacturers, importers and distributors. This column outlines what employers must do to comply and why it matters.
Background
OSHA issued a final rule on May 20, 2024, that amends the HCS to conform to the Globally Harmonized System of Classification and Labeling of Chemicals (GHS) Revision 7, to address issues that arose during the implementation of the 2012 update to the HCS and to align better with other U.S. agencies and international trading partners. The modifications to the HCS are significant. They include revised criteria for classification of certain health and physical hazards, revised provisions for updating labels, new labeling provisions for small containers, new provisions related to trade secrets, technical amendments related to the contents of safety data sheets and related revisions to definitions of terms used in the standard.
The implementation of HCS 2024 included staggered compliance dates. The rule established two sets of compliance dates for chemical manufacturers, importers and distributors evaluating substances and mixtures. Members of the regulated community asked for additional guidance to comply with the updated HCS. Although OSHA has been working to issue final guidance on the updated HCS for both the regulated community and agency personnel, it was unable to complete these documents in time before the initial compliance date of Jan. 19, 2026. OSHA thus extended the initial compliance date by four months to allow it time to publish the necessary guidance materials.
To maintain the tiered approach to compliance adopted in the final rule, OSHA also extended each of the subsequent compliance dates in paragraphs (j)(2)(ii) and (j)(3) by four months. The final rule was effective Jan. 15, 2026. The revised compliance dates are as follows: Chemical manufacturers, importers and distributors evaluating substances were required to comply with all modified provisions of the HCS no later than May 19, 2026 (paragraph (j)(2)(i)); entities evaluating mixtures must comply with all modified provisions no later than Nov. 19, 2027 (paragraph (j)(3)(i)); and paragraphs (j)(2)(ii) and (j)(3)(ii) require employers to update any alternative workplace labeling under paragraph (f)(6), update the hazard communication program required by paragraph (h)(1) and provide any additional employee training in accordance with paragraph (h)(3) for newly identified hazards no later than Nov. 20, 2026, for substances and May 19, 2028, for mixtures.
What items must employers comply with?
No later than Nov. 20, 2026, employers must update the following items related to chemical substances: workplace labels, written hazard communication programs and employee training for newly identified physical hazards, health hazards or other hazards. As employers by now appreciate, OSHA revised certain hazard classification criteria. The revisions include criteria pertinent to the skin and eyes. The rule also requires that hazard classifications consider reasonably anticipated downstream uses when such uses are known or can be reasonably ascertained. This standard invites speculation and thus can be especially challenging to implement. OSHA responded to concerns raised in this regard during the comment phase and modified the final language to limit downstream uses to those a manufacturer or distributor knows or can reasonably anticipate. The change helps, but what uses people might “reasonably anticipate” will vary greatly.
Employers must also comply with updated small-container labeling requirements. OSHA prescribed special language for containers holding less than 100 milliliters. Two other changes are important. The first relates to confidential business information (CBI). Under the rule, certain chemical concentration information may be withheld as CBI, provided the criteria are met. The second is that new requirements apply to compressed gases and aerosol products.
Discussion
In a perfect world, employers are aware of these important new requirements, have taken full advantage of the delayed compliance deadlines and have completed all updates well before Nov. 20. Employers running behind schedule should work quickly to comply to avoid the assertion of noncompliance and the assessment of penalties.
OSHA has prepared several guidance documents that regulated entities may find instructive. These include an enforcement directive — Directive CPL 02-02-079, “Inspection Procedures for the Hazard Communication Standard (HCS 2024)” — that formally establishes the extended timeline rules for agency personnel and the public. This 132-page document “is designed to provide guidance to compliance safety and health officers (CSHOs) on how to enforce the revised Hazard Communication standard during its transition period and when fully implemented.” OSHA also has released Publication 4437, a brief introductory guide outlining the major alterations, including alignment with GHS Revision 7, small-container labeling changes and updated trade-secret allowance criteria. OSHA reportedly is preparing detailed compliance guidance for “downstream hazards” and chemical reclassification, but it has not yet been released.
Lynn L. Bergeson, Compliance Advisor columnistLynn L. Bergeson, Compliance Advisor columnist
