Workforce: How Sites Accidentally Burn Out Their Best People
Key Takeaways
- Reliable people often absorb invisible operational load.
- Hidden workload creates human dependency risks.
- Burnout is a capacity and performance issue, not simply a well-being issue.
- Hero culture can mask deeper operational inefficiencies.
- AI and automation should reduce low-value workload, not intensify expectations.
- Sustainable operations require workload distribution, redundancy, and visibility into hidden work.
A late equipment delivery. A permit issue. A contractor misunderstanding. A production concern raised at the end of shift handover. Suddenly, the same names are pulled into the meeting room. They stay late, bridge the gaps, calm tensions and somehow keep things moving. They are the fixers. Most facilities see these people as high performers: dependable, resilient, safe pairs of hands. But there is a hidden risk in relying too heavily on the same individuals to absorb operational pressure. Often, the work that is causing the damage never actually appears on a work plan.
The Reliability Punishment
In many chemical facilities, reliability quietly becomes a punishment rather than an asset. The more dependable someone is, the more ambiguity they inherit. They become the person who fixes poor coordination, mentors new starters, joins “quick” calls, recovers weak handovers and absorbs escalation work when timelines are tight. None of this typically arrives as a formal role change. It accumulates gradually through trust and habit. These individuals continue to deliver, but leaders may not realize how much invisible work has accumulated around them until their capabilities have already begun to wear away.
Human Single Points of Failure
Many facilities work hard to eliminate single points of technical failure while unintentionally creating single points of human dependency. We build redundancy into systems, equipment and processes because we understand the operational risk of over-reliance. Yet the same principle is often overlooked when it comes to people. The same engineers, operators, supervisors or project leads become holders of historical knowledge, coordination capability, stakeholder trust and recovery expertise. Teams begin relying on individuals rather than resilient systems. The issue is not whether these people are capable; it is whether the operation has become too dependent on them remaining constantly available.
The Hidden Workload Nobody Measures
Part of the challenge is that most resource plans only capture visible work. Meetings, maintenance tasks, shutdown scopes and deliverables are easy to track. Hidden workload is harder to quantify. Context switching between problems, translating vague direction into action, mentoring junior colleagues, managing stakeholder tensions and recovering weak communication pathways all take up cognitive capacity. Often, the most exhausted people on site are not the ones with the longest formal task lists; they are the ones carrying the heaviest invisible operational load. Like fatigue loading in equipment, the strain builds gradually until performance starts to decline.
Burnout as Capacity Erosion
This is why burnout should not be viewed only as a well-being issue. In operational environments, burnout is a capacity erosion issue. It appears through slower judgment, reduced curiosity, lower collaboration, disengagement and fewer improvement ideas. Exhausted teams are less likely to challenge assumptions, raise concerns or think proactively about risk. Resilience matters, but resilience was never meant to mean tolerating unsustainable pressure indefinitely. If resilience is constantly required just to maintain normal operations, something upstream is broken.
Hero Culture and Firefighting
Certain industries can unintentionally reinforce this problem by rewarding endurance and firefighting behaviors. The person who always answers late-night calls, stays calm under pressure and rescues difficult situations is frequently praised as committed and dependable. However, repeated heroics can also indicate unresolved structural inefficiencies. If the same people are repeatedly saving operations, you may not have a people success story. You may have a system design problem. Sustainable performance should not rely on a handful of people permanently operating beyond reasonable capacity.
AI and Smarter Capacity Use
There is also a growing opportunity to use technology more intelligently to reduce invisible workload. Highly skilled technical professionals often spend significant time on repetitive coordination and administrative activity. AI-supported tools can now help reduce effort associated with meeting summaries, action tracking, reporting, information retrieval and documentation preparation. Used properly, this is not about squeezing more output from already stretched teams. It is about restoring human capacity for higher-value activities such as engineering judgment, proactive risk management, mentoring and operational decision-making.
High-performing facilities are not built on endless endurance. They are built on systems and cultures that distribute load sustainably before capability starts to erode. Often, the warning signs are subtle: the same names always carrying uncertainty, the same people solving recurring problems, the same individuals quietly absorbing pressure without complaint. Eventually, even the strongest people reach capacity. Unfortunately, when the same people carry operational risk for too long, the system may eventually lose the very people holding it together.
Lauren NealLauren Neal
Founder and Chief Program Creator, Valued at Work
Lauren Neal is the founder of Valued at Work, a consultancy helping STEM and technical organizations build workplaces where people thrive, and results rise.
With over 20 years of experience as an engineer and project manager delivering complex, multimillion-dollar projects globally, Lauren understands firsthand how leadership, team dynamics and culture directly impact performance under pressure.
She now works with senior leaders in male-dominated industries to move beyond tick-box inclusion efforts, embedding practical, people-centered systems that improve retention, strengthen leadership capability and unlock high-performing teams.
Chartered through both the Institution of Engineering and Technology (IET) and the Association of Project Management (APM), Lauren is a sought-after speaker, writer and consultant known for her straight-talking, commercially grounded approach to workplace culture.
Her book, Valued at Work: Shining a Light on Bias to Engage, Enable, and Retain Women in STEM, became a #1 best-seller and was shortlisted for the 2024 Business Book Awards and the Institute of Leadership’s 2024 Leadership Book of the Year.
Learn more at: valuedatwork.com
