Energy Saver: Adapting Pinch Analysis to Real-World Operations
Pinch analysis is a powerful heat-integration tool for chemical engineers, but its true potential is often lost between study and execution. In theory, the method is relatively straightforward. Operations teams identify the pinch point, avoid cross-pinch heat transfer and target the minimum hot and cold utility demand. But many sites zero in on a single design case without adapting to changes in feeds, rates and fouling. This happens despite the availability of modern controls and modeling tools that enable enhanced analysis as your plant evolves.
That gap matters because process heating is a major industrial energy sink. Fuel-based process heating accounts for roughly 17% of total U.S. industrial energy use, and that often represents 2%-15% of total production cost, according to the U.S. Department of Energy’s process-heating sourcebook reports. DOE also notes that waste heat recovery can deliver meaningful energy savings, but varies based on the application, temperature and integration cost. With so much energy at stake, pinch analysis should be treated as an operating strategy, not just a design exercise.
Stalling Studies
Traditional pinch designs account for clean exchangers, fixed flow rates and steady temperatures. But chemical plants have dynamic systems with feed variability, production swings, startup and shutdown transients and fouling accumulation. Common implementation constraints for pinch-based heat exchanger networks include flexibility, controllability, pressure drop, maintenance and utility-placement issues (Mandalagari, 2021; Linnhoff, 1983).
The core pinch rules of avoiding cross-pinch heat transfer and keeping hot utilities above the pinch and cold utilities below it still apply to chemical plants. But once a plant veers from the studied operating point, it’s important to reinforce those rules with control logic, monitoring and disciplined maintenance. Fouling is especially important because it steadily raises thermal resistance and erodes heat-recovery performance over time. A pinch study that ignores fouling describes yesterday’s plant, not tomorrow’s operating reality.
Fouling should be treated as a planning input from the start. Other factors to consider include heat losses from poor insulation, air infiltration and surface fouling. They can quickly erode potential gains. In addition, maintenance and insulation restoration are often among the quickest payback actions. In practice, that means a useful pinch revamp accounts for realistic fouling factors backed by instrumentation that tracks exchanger performance over time.
Dynamic Digital Data
More researchers are using sensor data, mathematical programming and simulation to make pinch analysis more time aware and better suited to multi-period operation (Yuan and Mao, 2024). One approach uses sensors and unsupervised learning to divide operating data into distinct regimes before applying pinch analysis to each one rather than to a single averaged case (Halisdemer, 2023). This method improved waste heat recovery by 20% and reduced heat exchanger network costs by 31% for one plant.
Digital twins and advanced process controls (APC) can provide additional value for pinch analysis. APC can help plants stay within their intended operating envelope by adjusting to load, fuel, air, pressure, temperature and emissions trends. Digital twins help engineers test assumptions early and keep operating decisions aligned with changing plant conditions across the asset lifecycle.
APC can improve the operating point by optimizing interacting control loops, while digital twins let teams test designs against real operating scenarios. While that combination doesn’t replace pinch analysis, it helps ensure the success of pinch recommendations over time.
Operations and Corporate Commitments
Pinch analysis also is a tool for achieving emissions-reduction goals. Heat recovered from the process displaces utility demand, usually steam or fired-heater fuel, avoiding emissions upstream. That makes pinch analysis especially relevant where capital budgets must support both energy productivity and emissions reduction.
Chemical plant operators should evaluate heat-integration projects alongside electrification, waste-heat recovery and carbon-reduction initiatives in the same capital portfolio. Some projects will be utility-only changes, while others will require exchanger additions or control upgrades. The question is whether the plant is using the latest controls and digital modeling to shape both operations and the corporate commitment roadmap.
References
Li, B. H., & Chang, C. T. (2010). Retrofitting heat exchanger networks based on simple pinch analysis. Industrial & engineering chemistry research, 49(8), 3967-3971. https://doi.org/10.1021/ie9016607
Halisdemir, U., Dumont, Q., & Jean-Marie, A. (2023). Time dependent pinch analysis with sensor data and unsupervised learning algorithms. Journal of Physics: Conference Series, 2430, 012001. https://doi.org/10.1088/1742-6596/2430/1/012001
Linnhoff, B., & Hindmarsh, E. (1983). The pinch design method for heat exchanger networks. Chemical Engineering Science, 38(5), 745-763. https://doi.org/10.1016/0009-2509(83)80185-7
Mandalagiri, L., Irawan, A., & Yani, S. (2021). Operability and Flexibility of Pinch Applications on Heat Exchanger Network in Chemical Industry. Journal of Chemical Process Engineering, 6(1), 36-47. https://doi.org/10.33536/jcpe.v6i1.827
Marton, S., Langner, C., Svensson, E., & Harvey, S. (2021). Costs vs. flexibility of process heat recovery solutions considering short-term process variability and uncertain long-term development. Frontiers in Chemical Engineering, 3, 679454. https://doi.org/10.3389/fceng.2021.679454
Marton, S., Svensson, E., Subiaco, R., Bengtsson, F., & Harvey, S. (2017). A steam utility network model for the evaluation of heat integration retrofits–a case study of an oil refinery. Journal of Sustainable Development of Energy, Water and Environment Systems, 5(4), 560-578. https://doi.org/10.13044/j.sdewes.d5.0167
U.S. Department of Energy, Office of Energy Efficiency and Renewable Energy. (2015). Improving process heating system performance: A sourcebook for industry (3rd ed.). https://www1.eere.energy.gov/manufacturing/tech_assistance/pdfs/proc_heat_sourcebook.pdf
Yang, Z., Pan, T., Chang, C., Zhang, S., Zhang, N., & Smith, R. (2025). Multi-objective-period heat exchanger network synthesis and decarbonization for industrial-scale crude oil distillation system. Energy, 326, 136300. https://doi.org/10.1016/j.energy.2025.136300
Yuan, T., & Mao, Y. (2024). A review of pinch analysis techniques and extended application in power systems. Renewable and Sustainable Energy Reviews, 202, 114684. https://doi.org/10.1016/j.rser.2024.114684
Thomas KwanThomas Kwan
Global Vice President, Strategic Innovation and Industrial Ecosystems
Thomas Alan Kwan is an energy transition expert at Schneider Electric's Sustainability Research Institute. With a Ph.D. in chemical and environmental engineering, he brings a blend of academic rigor and industrial experience to the field of sustainable manufacturing and green engineering.
At Schneider Electric, he leads initiatives focused on new and emerging industrial systems, with a particular emphasis on the chemical processing sector. His work involves developing innovative solutions and practices to drive energy, environmental and economic benefits.
Previously, he was a key member of Unilever's product engineering team, where he integrated green chemistry and engineering principles for product and process development. His contributions earned him a lifetime honorary membership on the team. Kwan also has experience in environmental regulation, having worked with the U.S. EPA on Clean Water Act programs.
Through his research and collaborations, Kwan continues to explore innovative ways to reduce energy consumption, minimize waste, maximize value and improve overall process efficiency in chemical manufacturing operations.
