Innovative Process Boosts Emerging Bioplastics
Oct. 22, 2012
5 min read
The first plant pioneering a breakthrough process developed by Sulzer Chemtech for making polylactic acid (PLA) is operating in Etten-Leur, The Netherlands. Synbra Technology successfully put the 5,000-mt/yr plant (Figure 1) into service in 2011. Since then, Sulzer has started up a second plant (Figure 2) for its own use. The 1,000-mt/yr facility, located in Pfäffikon, Switzerland, is expected to produce high-quality PLA samples by the end of this year.
SYNBRA PLANT
Figure 1. The PLA facility employs a polymerization process jointly developed by Sulzer and Purac. The patented process allows production of PLA with very high stereochemical purity, which has a high crystallinity, and, thus, a much better heat stability than other PLA products currently available in the market. In addition, Sulzer’s proprietary static reaction and devolatilization equipment help reduce energy consumption and optimize operational expenses. All in all, these advances enable PLA-based bioplastics to become even more interesting alternatives to petrochemical plastics in a broader range of areas. The biopolymer resembles conventional high-volume petrochemical plastics like polystyrene or polyethylene terephthalate (PET) in many characteristics and can be processed using typical equipment. PLA and PLA blends usually come as granulates and currently are used in commercial applications such as packaging, one-way food services and disposable tableware.PLA commonly is produced through the ring-opening polymerization of lactide monomers, which are based on lactic acid produced by the fermentation of sugar or starch. Selective mixing of lactides made from the natural L(+) isomer of lactic acid and lactides from the D(-) isomer allows producers to tune important characteristics of the polymer like the degree of crystallinity.Researchers are working on new fermentation processes using cellulosic material from wood, grass, or agricultural wastes to replace sugar as a raw material, thus making PLA an even more attractive and interesting material for the future. This “next generation” process also will create synergies with other industrial sectors working with cellulose, such as the pulp and paper industry.THE NEW PRODUCTION PROCESSMajor shortcomings of current bioplastics are their low heat resistance and high price — as well as the lack of sufficient amounts of high quality resin. Therefore, in 2008 Sulzer Chemtech and Purac, a company of the Dutch CSM group, began to jointly develop a cost-efficient polymerization process. It uses Purac’s high purity lactide monomers and relies upon Sulzer’s proven proprietary polymerization technology. Output consists of PLA grades with exceptionally high stereochemical purity and a wide range of molecular weights. The substantially better heat resistance enables the PLA grades to endure temperatures of up to 180°C, opening up potential applications in the automotive, electronics and textile industries.PLA MODULE
Figure 2. Modules for Sulzer’s new PLA polymerization plant were trucked to the Swiss site in February 2012.Purac manufactures its polymer-grade D- and L-lactides at a new 75,000-mt/yr lactide facility in Rayong province, Thailand. These lactides originate from cane sugar or cassava starch, and are certified to be free of genetically modified organisms (GMO) — an aspect that becomes more and more important in the perception of consumers when, for example, food packaging applications are envisaged.Sulzer’s polymerization technology represents an energy efficient way to produce various PLA grades and allows fast processing and short product development times. The successful combination of Sulzer Chemtech’s three core competencies — static mixing and reaction expertise; proven experience in piloting and scale-up; and process and equipment engineering capabilities — has made the development of this novel polymer production process possible.The technology provides full scalability. This helps lower entry barriers to PLA production at smaller scales (5,000 to 20,000 mt/yr). Yet, it easily can be scaled up to world-scale, fully integrated sugar-to-PLA facilities. Such world-scale plants will open the door to PLA manufacturing that is cost competitive with oil-based polymers, while smaller-scale plants can be used to produce niche PLA grades for special applications once the market for commodity PLA is fully developed.COMMERCIALIZATIONThe Synbra facility currently is the second largest PLA plant in the world and the only one to produce a greater-than-99%-pure PLLA or PDLA for stereocomplex production at a commercial scale. The Dutch company, which aims to achieve a leading position in Europe as a supplier of biodegradable polymers from renewable sources, plans to significantly increase the annual PLA capacity. Synbra also uses its PLA output to make expanded PLA foam (Biofoam), an attractive biodegradable alternative to expanded polystyrene (EPS) foam in a variety of application areas — for example, agriculture, packaging and insulation. “We looked for an industrial PLA process all over the world and found the most advanced technology available at Sulzer,” says Jan Noordegraaf, Managing Director, Synbra.By investing in its own PLA production plant, Sulzer Chemtech has demonstrated its dedication to bioplastic development. This move will enable Sulzer to support its clients in the development of new PLA applications — both by providing samples in sizable quantities and by demonstrating the feasibility of Sulzer’s PLA polymerization technology.PHILIP NISING is director, polymer business for Sulzer Chemtech, Winterthur, Switzerland. E-mail him at [email protected].
Philip Nising
Sulzer Chemtech
Sponsored Picks
Sponsored
