How Close Is the Chemical Industry to True Autonomy?
Key Highlights
- AI autonomously controlled a butadiene distillation column for 35 days, reducing steam use by 40%.
- Chemical industry autonomy is advancing through supervised AI systems with humans still overseeing operations.
- Data connectivity, legacy systems and workforce readiness remain major barriers to full plant autonomy.
At an ENEOS Materials Corp. plant in Yokkaichi, Japan, operators were grappling with a stubborn control challenge.
A distillation column used in butadiene production required precise control of liquid levels and heat and steam inputs to maximize product quality and conserve energy. The plant’s distributed control system and advanced process controls struggled to optimize adjustments to two critical valves, so operators had to manually control the valves to keep the column operating within target specifications.
After years of relying on manual intervention to regulate distillation operations, artificial intelligence provided a solution.
As part of a field test in early 2022, an AI-based control system ran the distillation process autonomously for 35 consecutive days. A key technology enabling autonomous control of the distillation column was factorial kernel dynamic policy programming (FKDPP), a reinforcement learning-based AI algorithm developed by Yokogawa Electric Corp. and the Nara Institute of Science and Technology. At the time, Yokogawa declared that the successful pilot project was a global first.
After the initial field test, ENEOS and Yokogawa reported that the AI controller had achieved stable production of high-quality butadiene while eliminating off-spec production, maximizing waste-heat usage and cutting steam consumption by 40% – all without the need for operator intervention.
The results were so promising that ENEOS in March 2023 formally announced that the AI-enabled control system would operate the distillation column at its Yokkaichi facility. This past December, a technical consultant from Yokogawa told Chemical Processing that ENEOS continues to run the AI-enabled control system at its Yokkaichi facility, and the company is eyeing opportunities to expand its use.
The ENEOS deployment is proof positive that autonomy in chemical processing is no longer theoretical. At the same time, it highlights the limits of autonomous operation in today’s chemical industry. While most chemical facilities are highly automated, they still rely on varying levels of human oversight. And according to one industry observer, some plants have been slow to embrace digitalization in their day-to-day operations, a key barrier to autonomy.
Still, there are signs that the industry is making progress in the transition from automation to autonomy. And the good news, according to Yokogawa, is that “even in specific processes or at a limited scale,” autonomous operations “can deliver substantial benefits across industries.”
“As autonomy advances, a multitude of benefits will emerge, driving efficiency and safety to new heights,” the company declares on its website.
On the road to autonomous operations, industry partnerships like the Yokogawa-ENEOS collaboration could take on increasing importance. In March, Evonik and Siemens announced plans to collaborate on the development of next-generation autonomous technology for chemical plants. Henrik Hahn, chief digital transformation officer for Evonik Industries, says the companies view the road to autonomy as “a progressive, structured journey rather than a ‘big bang’ transformation.”
“The autonomy vision becomes achievable only through strong partnerships that combine deep operational know‑how with automation, digitalization and AI expertise,” asserts Hahn. “This is exactly why Evonik and Siemens are pursuing this work together: Autonomy requires the integration of technology, process knowledge and organizational readiness.”
From Automation to Autonomy: Measuring Progress
In the future, Sundeep Ravande, CEO of Innovapptive, envisions humanoid robots, intelligent machines and AI-driven decision systems working together seamlessly in a chemical plant to execute operational and maintenance tasks without human intervention. For now, though, chemical facilities can take incremental steps toward “semi-autonomous” operations by using AI to automate repeatable workflows — all within clearly defined constraints that keep humans firmly in the supervisory loop.
“At this point, semi-autonomous capability is achievable, and we’re already seeing elements of it in practice,” said Ravande, who also is the founder of the Houston-based provider of AI-powered operational software. “I describe it as supervised autonomy — essentially autopilot with human oversight. You can think of it in terms of self-driving cars today. You still need a person in the driver’s seat, paying attention and ready to intervene if the system makes a mistake.”
Ravande’s description of “supervised autonomy” reflects a broader industry reality: Autonomy in chemical operations isn’t an all-or-nothing proposition. At the same time, the definition of autonomy — and what progress looks like — could vary across organizations.
Evonik and Siemens define autonomy in chemical production as “the capability of a plant to run, optimize and adapt its operations safely and efficiently with minimal human intervention, supported by dynamic, self‑learning digital systems,” according to Hahn.
“In practical terms, autonomy means that a plant can independently manage routine tasks, anticipate and correct deviations and optimize key performance parameters while operators move into a supervisory, expertise based role,” Hahn said.
To define the progression from automation to autonomy and help manufacturers understand where they are in the journey, ARC Advisory Group developed what it calls an Autonomous Operations Maturity Model. The five-level autonomy index is summarized below:
- Level 0 (no autonomy) – Operations rely on humans to make all decisions and perform all functions.
- Level 1 (operations assistance) – Basic automation technology supports human decision-making.
- Level 2 (regulatory automation) – Basic control systems maintain process variables automatically using technologies such as PID loops.
- Level 3 (advanced regulatory) – Automation can recognize defined abnormal conditions and take corrective actions within programmed limits.
- Level 4 (select autonomy) – Systems can make certain operational decisions independently, such as switching to standby equipment in the event of a pump failure, while notifying human operators.
- Level 5 (full autonomy) – Facilities function as largely self-directing operations with minimal need for human intervention.
A Schneider Electric report published in late March concluded that companies in the energy and chemicals sector are making more progress toward autonomy than expected.
Based on a survey of 400 executives across 12 countries, the report stated that organizations in the sector are operating at an average autonomy level of 3.52 out of 5 on the ARC Autonomous Operations Maturity Model. On average, energy and chemical companies aim to achieve Level 4.02 (80% autonomy) by 2030. While North America lags other regions in terms of progress, nearly 90% of executives from North American companies rank autonomy as a high priority.
“Autonomy is rapidly becoming the new operating model of industry,” said Gwenaelle Avice Huet, an executive vice president at Schneider Electric.”
Where Autonomy Can Deliver Value Now
The forces driving the industry toward greater autonomy are familiar day-to-day challenges for chemical facilities, which are under increasing pressure to boost productivity and manage costs while ensuring worker safety in hazardous environments and remote locations. Technologies that reduce the need for human intervention hold the potential to lower risk exposure while improving operational reliability.
One of the most compelling drivers is the ongoing shortage of skilled professionals. Many chemical facilities are dealing with the one-two punch of managing an aging workforce while competing for a limited pool of skilled replacements. The intensifying talent gap is a key reason why Evonik and Siemens view autonomy as “a strategic necessity.”
However, Hahn emphasized that autonomy isn’t about “replacing human judgment.”
“It’s about giving our production teams digital systems that take over repetitive, time critical and stabilization focused activities so that people can focus on problem solving, quality, safety and improvement,” Hahn said.
In terms of the most realistic starting points for implementing autonomous technology, Axel Lorenz, CEO of process automation at Siemens, said chemical facilities should look for opportunities to shift personnel away “from manually coordinating routine operational decisions toward supervising increasingly automated process control and optimization.”
“Operators still spend significant amounts of time monitoring different screens, acknowledging alarms, investigating root causes and manually identifying and implementing relevant SOPs,” Lorenz says.
According to Lorenz, a “high-impact candidate for early-stage autonomy” is state-based and procedural automation, integrated with digital twins and shared data layers.
The goal of these systems is to recognize defined operating conditions, such as startup, steady-state operation or abnormal events and automatically execute the appropriate response based on established procedures.
For example, instead of requiring an operator to interpret alarms and manually initiate corrective actions during a process upset, the system would identify the condition and follow preapproved workflows to stabilize the process within defined safety limits.
“This technology lays the foundation for tighter closed-loop integration with optimization and control technologies,” Lorenz says. “For example, rather than optimizing only setpoints within a fixed operating mode, future systems will increasingly be able to move plants safely between operating modes to realize greater benefits.”
Barriers to Autonomy: Data, Integration and the Human Factor
While AI tends to grab most of the headlines, it’s only one part of a broader technology stack that organizations are leveraging to make autonomous operations a reality.
Evonik and Siemens say they’re developing a layered “digital plant” architecture that will bring together existing plant control systems, digital twins, edge computing, data connectivity and AI-driven analytics into a unified operating environment.
A vital component of that digital plant technology stack is “seamless data connectivity, both vertically from ERP to the shop floor and horizontally across systems,” Lorenz says.
That level of data connectivity remains aspirational for many chemical facilities, according to Ravande, who asserts that slow progress on the road to digitalization could be the industry’s biggest hurdle to autonomy.
“Many customers that we deal with are still on paper, still using walkie-talkies, still relying on binders,” Ravande says. “Their OT and IT stacks are disconnected, and the front line is still operating with little to no [digital] technology.”
Other notable challenges include the complexities of integrating advanced technologies into legacy systems, as well as the increased cybersecurity risks that come with expanding connectivity across plant operations. But not all the hurdles are related to technology. Autonomy will dramatically change the role of the operator in a chemical facility, reshaping how work is structured and how decisions are made on the plant floor. That’s more of a cultural sea change than a technological shift.
“Operators will work more closely with digital systems, focus more on exception handling and specialized workflows and supervise a broader operational scope than today,” Lorenz says. “As autonomy expands, digital literacy and cross-functional operational understanding will become increasingly important.”
The Road Ahead
Despite the challenges, real-world deployments are beginning to demonstrate what’s possible.
FKDPP, the AI protocol that enabled autonomous control of a distillation column at the ENEOS facility in Yokkaichi, Japan, is particularly promising. The FKDPP algorithm can learn optimal control directly from operational data instead of relying on pre-built process models, making it highly adaptable to chemical operations with hard-to-control dynamics.
Also noteworthy is FKDPP’s rapid learning capability. The algorithm can build robust control models in just 30 learning trials.
This past December, Chemical Processing recognized Yokogawa with a Vaaler Award for its role in developing FKDPP and implementing the technology at the ENEOS plant’s distillation column. In an episode of the Chemical Processing “Distilled” podcast, Yokogawa solution consultant Karthik Gopalakrishnan asserted that autonomous control “is something [that] is eventually going to be part of our life.”
But he also emphasized that there will always be some level of human involvement.
“At the end of the day, you still need a human in the loop to make sure those AI [controls] are not going haywire and going toward AI hallucination, which is a real thing,” Gopalakrishnan said.
But in terms of the industry’s overall progress on implementing autonomous operations, he added: “We are absolutely there, and we are going to get there more and more.”
Josh CableJosh Cable
Josh Cable is a Cleveland-based freelance writer and editor with more than 20 years of experience in B2B journalism and content marketing, specializing in U.S. manufacturing and the technology sector. His coverage areas have included workplace safety and health, lean manufacturing, warehousing and distribution, industrial automation, sustainability, emerging technologies and operational best practices. As a former editor at Babcox Media and Penton Media, Josh has produced news articles, feature stories, blog posts and educational videos across a range of technical topics.
