Compressed Air: In Search Of Perfection
The path to enlightenment can result in significant energy savings.
May 30, 2013
OK, true perfection may not exist in compressed air systems. But implementing any sort of improvements can only help the bottom line. Chemical Processing covers this topic often -- and we are always on the lookout for other stories that will offer information to enable readers to make their plants more efficient. This article by our sister publication is just another example.
[sidebar id=1]
The word “perfect” is not commonly used when describing the performance of a typical compressed air system. A good quality, fully loaded, air-cooled, lubricated rotary-screw compressor consumes about 16.5 kW of power to produce 100 cfm of compressed air at 100 psi. Refrigerated air drying of this air costs another 0.5 kW/100 cfm.
Read the full story on PlantServices.com
If you want more coverage from Chemical Processing, check out the articles in the Related Content You May Like box in the upper-right corner.
Ron Marshall
Manitoba Hydro
