Plant InSites: Come Up With a Solid Estimate
Use geometry to figure out the amount of material in storage or equipment.
Dec. 14, 2009
4 min read
Large-scale solids-handling operations often rely on storing material in piles. The pile layout and solid's properties set the volume storable in a given area. Piles most often approximate one of four common shapes: a cone: a frustum of a cone; a wedge; or a frustum of a wedge (Figure 1) — a frustum essentially is the underlying shape with its top cut off.
Pile Shapes
Figure 1. Most piles of solids fall into one of these four basic shapes. Angle of repose, Θ, which is the stable angle between the surface of the pile and the horizontal, is the major bulk material property affecting volume. Angle of repose varies with base material, particle size, particle size distribution (or fines content), particle shape and other factors such as moisture content. Table 1 (at the bottom of this page) lists reasonable values of Θ for some common materials; many references also provide such information. Values for specific cases can vary considerably. So, always try to get data from industrial applications similar to yours; in critical cases, you may need to test your actual materials. For a cone, the volume is: v = πhr2/3(1)
where h is the height and r is the radius.For a frustum of a cone, the volume is:v = πh(r12 + r22 + r1r2)/3(2)
where r2 = r1h/tan Θ.For a wedge, the volume is:
v = hb(2a1 + a2)/6 = hb[3a1 – 2h/tan Θ]/6   (3)
where a2 = a1 – 2h/tan Θ1.
For a frustum of a wedge, the volume is:
v = h[a1b1 + (a1 + a2)(b1 + b2) + a2b2]/6      (4)
where b2 = b1 – 2h/tan Θ2.
You can use these equations, which apply both to unconstrained piles and bulk solids flowing in constrained spaces such as hoppers, with those for other standard shapes to determine a variety of volumes.
Feed Hopper
Figure 2. Figuring out the volume of material remaining requires splitting the hopper into three sections.For example, let's find the volume of grain remaining in a 10-ft.-dia. 50-ft.-high feed hopper when it's nominally half full (Figure 2). We break the hopper into three zones: a frustum of a cone on the bottom, a cylinder in the middle, and a cylinder minus a cone on the top. The first section has 1 ft. of height cut from the cone. We determine r2 as 5 - 4/tan 45° or 1 ft. This gives a volume of the bottom section of π4[52 + 12 + (5 x 1)]/3 or 130 ft3. The second section has a cylinder height of 25 - 5 tan 28° or 22.3 ft. This gives a cylinder volume of 1,753 ft3. The third section has the volume of a cylinder 25 - 22.3 or 2.7 ft. tall minus the frustum height. Volume is π52 × 2.7 - π52 × 2.7/3 or 141 ft3. So, total volume in a half-full feed hopper is 130 + 1,753 + 141 or 2,024 ft3. This relatively simple example illustrates how you can estimate bulk solid volumes.
Andrew Sloley is a Chemical Processing contributing editor. You can e-mail him at [email protected].
Angle of Repose for Common Bulk Materials
Table 1. This list presents reasonable values for the materials but actual value can vary markedly depending upon application.
Material Θ, degrees
Activated carbon 20-29
Alfalfa, meal 45
Alfalfa, pellets 9
Alumina 22
Anthracite ash 45
Barley 30
Bauxite 31
Carbon black 25
Caustic soda 29-43
Cement 37-40
Cinders, bituminous coal 25-41
Clay, soft 10
Clay, compacted 10-25
Coal, anthracite 27
Coal, bituminous 35
Coke, lose pile 30-45
Corn 23
Diatomaceous earth, calcined 30-44
Flaxseed 21
Gravel, round 30
Gravel, sharp 40
Gypsum 30
Iron Ore 35-45
Limestone, pulverized 30-44
Lime, hydrated 40
Linseed 25
Millet 23-25
Phosphate rock, crushed 25-29
Phosphate rock, ground 40
Plastic resin grains, cellulose acetate 16
Plastic resin grains, fluorocarbon 6
Plastic resin grains, nylon 9
Plastic resin grains, polyethylene pellets 23
Plastic resin grains, vinyl 10
Plastic resin grains, viscose 10
Oats, rolled 30-44
Quartz, ½-in. screenings 20-29
Quartz, 1.5-3 in. 30-44
Rapeseed 18-22
Rice 30-44
Safflower 24
Salt 36
Sand, dry 25-35
Sand, moist 30-45
Sand, wet 20-40
Scrap metal 35-45
Silt, compacted 25-40
Silt, loose 20-30
Sand-clay, compacted 40-50
Soda ash, dense 32-42
Soda ash, light 59
Sulfur, granules 35
Sunflower seed 23
Wheat, whole 28
Wheat, cracked 30-44
Wood chips 45
