HART Devices - Dispelling the Myths
Myths and misconceptions surround the HART Communication technology despite being in use for as many as 15 years in some places. This article dispels those myths and highlights the benefits of HART.
March 10, 2005
6 min read
HART Communication technology has been employed in intelligent field devices for 15 years. Today, even though millions of HART-enabled devices are installed in locations around the world, myths and misconceptions about this powerful technology abound.
From its inception, the power of the HART Protocol has been underutilized due to misconceptions regarding the benefits of the technology. A primary misconception that “HART is only good for device setup, calibration and maintenance” was cemented in users minds because that’s how they initially used HART—with handheld communicators, the only HART host technology available at the time.
So even though handheld communicators and their ability to reprogram and diagnose HART devices has positioned HART as the most used field communications protocol in the industry today, they have also conditioned users to believe that this is the only viable use for HART Communication.  And, that misconception costs users of HART-enabled devices dearly everyday.
Field communications is one of the fastest growing technology areas within our industry, perhaps the only area experiencing growth. From Ethernet to wireless, protocols tout communication speed specifications as their number one advantage over HART, propagating the myth that “HART Communication is too slow for use in control systems”. This myth is quickly dispelled when we evaluate how the HART Communication technology works and all that it can do.
HART-enabled device’s provide two simultaneous communication channels transmitted via a single pair of wires. This technological approach offers the fastest possible data transfer of a single Primary Control Variable via the analog channel, which is backward-compatible with most existing analog I/O systems and faster than any other field communications protocol.  Response from the 4-20mA analog signal is almost instantaneous depending upon the signal dampening built into the system.
A HART device’s second communication channel, the digital channel, transmits intelligent device information on the same pair of wires as the Primary Control Variable.  The digital channel provides information on the physical device (i.e. tag, manufacture, model), device status (i.e. sensor failure, reset condition, configuration change), calibration (i.e. upper range value, lower range value, dampening) and additional device variables.
When using HART Communication’s digital channel, system I/O design is critical to the performance of a HART field network.  HART field networks can be configured in a point–to-point or a multi-drop topology, but most installation utilize the point-to-point topology.  A point-to-point topology takes advantage of the two simultaneous communication channels and eliminates any data speed reductions caused by “daisy-chaining” multiple devices on a single loop.  A point-to-point HART field network configured with a 1:1 modem ratio or one modem per device, responds with two to three updates per second.  In other words, it takes approximately 380 milliseconds to respond to a request for information.
In many cases may not be required, but to show how I/O design can affect performance, the same network configured using a multiplexer with an 8:1 modem ratio (8 devices to 1 modem) actually cuts the data throughput in half.  While designing a HART network using a remote I/O with a 1:1 (one modem: one device) modem ratio, you can achieve results as if there were only one device connected to the network.  Table 1 provides statistical information on system latency, the time that is required for the system to receive a response based on the HART I/O used.  It is important to note that not all HART I/O designs are equal.
Table 1 - HART I/O Latency (in seconds)
 Number of Channels
 Point-to-Point
(1:1 Ratio)
 Multi-Drop
(Ch #:1 Ratio)
 Multiplexed
(8:1 Ratio)
 1
 0.38
 0.38
 0.38
 4
 0.38
 1.51
 2.80
 8
 0.38
 3.02
 5.60
 16
 0.38
 6.04
 11.21
 32
 0.38
 12.08
 22.43
 256
 0.38
 179.42
As was discussed earlier, the intelligent information doesn’t stop with the analog Primary Control Variable signal. In addition to analog PV transmission, real-time status, diagnostics and multi-variable information are communicated via the digital channel on the same pair of wires with the analog signal.
Users be aware—intelligent data is no longer available only through the handheld communicator or a proprietary program, but can be monitored continuously 24 hours a day, 7 days a week.
Through the continuous monitoring of the HART Communication digital signal, potential control system failures can be easily detected at the device level. HART-detectable failure scenarios include in-range sensor failures, 4-20mA distortion (analog output does not equal PV measurement), incorrect setup or a device calibration mismatch (device span does not equal span on control system).
The continuous monitoring of HART data can be crucial to a plants operation.  Recently one major US chemical company could have averted a three-day shutdown due to an in-range failure of a level control loop that went undetected.  Investigation showed water had migrated into the level transmitter partially shorting out the analog output, resulting in erroneous level measurement signals being receive in the control room.  Had the control system been monitoring the HART Communication signal it would have detected this failure within seconds by comparing the digital value of the PV versus the represented analog value.  Determining a PV mismatch, the system could have alerted the operator and potentially saved over $300,000 in downtime.
By using a continuously monitored HART enabled-system, in addition to failures it is also possible to detect anomalies such as when a devices setup has been changed, a self-test run or a reset has been performed in the field, logging the information for audit trail purposes.
New control, safety and asset management systems capitalize on the intelligent information each HART-enabled device contains.  HART-enabled system solutions retrieve important status and diagnostics information helping keep your plant systems safe.  It is important to close the “information gap” that exists by using the 4-20mA analog signal without using the digital information available on every HART-enabled device.  Close the gap and “See What You Can Do” with the “Power of HART”.
Upcoming HART Connection articles will provide information on applying HART technology, application notes to help you implement new HART strategies and what to expect from a HART-enabled device or host system. For more information, contact the HART Communication Foundation or visit the website at http://www.hartcomm.org.
