Next >>
Displaying 1-10 of 53 results
Synchronous Reluctance Motor Boosts Efficiency
The 25 hp unit delivers 31-156 cfm with superior part-load efficiency, longer service life and reduced maintenance costs.
Motors Capture Operating Data For Analysis
Simotics SD low-voltage motors feature IoT-compatible technology.
Motor Starter Protects Electric Motors And Loads
Simatic ET 200SP motor starter is more powerful with four adjustment ranges up to 5.5 kilowatts.
Drive System Enables Efficient Cooling
Water-cooled Sinamics S120 converter and Simotics FD motors enable a shared cooling circuit for the entire drive system.
Drives Integrate Into Machine Designs
Mitsubishi Electric Automation introduces multi-network servo drives.
DCS Starters Eliminate Mechanical Strain
Nord Gear introduces new distributed control motor soft starters.
Nord
Sine Wave Filters Eliminate Motor Damage
Technology converts the rectangular PWM output voltage of motor drives into a smooth sine wave with low residual ripple.
Schaffner USA
Gear Reducer Minimizes Space
Baldor Electric introduces Baldor-Dodge Vertical GearMotor.
Siemens Introduces NEMA Premium SD661Motor
Siemens released a severe duty motor, the NEMA Premium SD661, for use in the petrochemical, energy and other similar industries and for specialized use in air- cooled heat exchanger applications.
Next >>
