Process Puzzler: Master a Musty Mess
THIS MONTH’S PUZZLER We feed grain via a screw conveyor from a silo to a mill. After grinding the material is conveyed by a pressurized pneumatic conveyor up six stories to cereal cookers. The pneumatic lines are bare pipe and run indoors. The mill room has fans but the air is humid in central Ohio in the summertime. Eventually, cereal is rolled into breakfast flakes. Unfortunately, the cereal often takes on a musty smell, which is worse in the winter. The cookers sometimes fail bacteria screening — the contamination has been traced back to the mill. Operators have seen water dripping from the conveyor ducts, although the moisture levels in the silo are only in the 8–9% range. What’s the source of the mysterious water and how can we eliminate or reduce the odor problem? How would you approach this problem? IDENTIFY WATER SOURCES The problem most likely arises from air being introduced into the process. The first question to ask is: what is the moisture content of the air streams introduced into the system? If air is being changed in the silos with fans then the moisture content measured there is not providing any useful data. The likely sources of water are: 1. Condensing water in either the mill or from the pneumatic conveyor due to Joules-Thompson effect; this tends to tie in with “it’s worse in winter.” Drying or reheating the air should address this cause. Renting an air dryer for a period is a first step.2. Are the [blowers] water cooled? It is possible that saturated air is being carried forward.3. Failing all these, look for places where any source of water may come in contact with the process: flushing lines, cleaning, cooling water, etc. Ed Fish, senior consultant
Haztech Consultants, Winsford, U. K. COOL THE AIRDehumidify the pneumatic transport air by cooling below dew point before air enters the blower. Eckehard Fuhrmann, engineer
SGL Technic, Valencia, Calif. CHECK THE DEW POINT The problem is most likely caused by high dew point in the conveying air used. Assuming the user is making its own compressed air using compressors, I would suggest that the air dryers on the system be checked to ensure that the dew point is sufficiently low for the intended use to prevent condensation inside the equipment (-40°C should be sufficient). The condensation along with the grain is giving the bacteria all it needs to replicate and create the musty smell. Chuck Cutler, maintenance engineer
Wyeth Vaccines, Sanford, N.C. INSTALL AN AIR DRYERIt sounds like moisture is getting in the system via the compressed air used in the pneumatic conveyor. Perhaps an air dryer between the air compressor and the pneumatic conveyor would benefit the process. Robert Walker, laboratory technician
Mosaic, Mulberry, Fla. FOCUS ON THE SILODripping of water from the duct indicates that the water source is the silos. Water vapor in the air is condensing in the silo during winter. High pressure and low ambient temperature will facilitate water condensation inside the silo. Proper insulation of silo and conveyor ducts will eliminate the problem. Another option is to maintain the silo under nitrogen pressure. R. Gunasankar, senior process engineer
Chiyoda Malaysia SDN. BHD., MalaysiaDRY THE AIR Try drying out the compressed air to the air transport system. George R. Strickland, consultant
Woodville,TexasSHERLOCK HOLMES WAS RIGHTJust such a mystery baffled Ralston Purina for years. I put together a test plan and it failed! I expanded my search; I looked at every source of water. The solution astonished me — but, as Sherlock Holmes said, “When you have eliminated the impossible, whatever remains, however improbable, must be the truth.” That’s how it was for this puzzle. I measured the air humidity, poured over weather data, reviewed years of silo moisture tests, looked at maintenance records and ran calculations of the heat loss from the duct. The dripping water from the duct did not make sense but there it was. And then it dawned on me. What is the moisture content of the seeds, i.e., the grain? A trip to the library showed that seeds protect a layer of moisture inside a resin barrier. I theorized that grinding released the moisture. So, I had the seeds ground and then measured the moisture in the trapped air in the container. The psychrometer jumped off the scale. In my report I recommended insulation and heat tracing. Because the duct was exposed to cold ambient air in its climb to the sixth floor, I recommended steam tracing rather than electric because of the heat demand. Also, electric tracing is four to six times more expensive to operate; actual costs depend on the source of electricity and the source of steam. Dirk Willard, senior process engineer
Swenson Technologies, Monee, Ill. NOVEMBER’S PUZZLER
A Difficult Balance
Figure 1. Accuracy issues with seven flow meters hamper getting a good material balance. Our company has been taken over. The new management wants to improve our energy efficiency and accuracy of our material balance (see Figure 1). They’d like to bring the balance to ±1% accuracy. Several flow meters yield questionable data: 1) an orifice meter measuring a wet gas (A in the figure); a vortex shedding meter with a tendency for fouling (B); a meter with a competing recycle line (C); a Coriolis meter with a gas problem (D); a vortex meter with startup difficulties because of gas entrainment (E); a Coriolis meter that measures product successfully (F); and a venturi tube meter that occasionally suffers plugged taps (G). The turndown on the process is about 3:1. How can we reduce our energy consumption and tighten our material balance? Send us your comments, suggestions or solutions for this question by October 9, 2009. We’ll include as many of them as possible in the November 2009 issue and all on CP.com. Send visuals — a sketch is fine. E-mail us at mailto:[email protected] or mail to Process Puzzler, Chemical Processing, 555 W. Pierce Road, Suite 301, Itasca, IL 60143. Fax: (630) 467-1120. Please include your name, title, location and company affiliation in the response. And, of course, if you have a process problem you’d like to pose to our readers, send it along and we’ll be pleased to consider it for publication.Sponsored
