AI in Chemical R&D: Define the Scientific Problem First
Key Highlights
- Standardized terminologies, ontologies, and expert curation are essential for ensuring data accuracy and interoperability in chemical databases.
- Cross-disciplinary collaboration among chemists, data scientists, and engineers enhances model relevance, accuracy, and scalability.
- High-quality curated datasets significantly improve AI prediction accuracy and reproducibility, supporting safer and more efficient chemical research.
Related Content
- Generative AI in the Chemical Industry
- AI in Chemical R&D: What's Holding Back Real-World Impact
- How AI and Machine Learning Are Transforming Plant Maintenance and Operations
- Energy Saver: AI + Automation Closes the Waste-Detection Loop
- BASF, Dow, Syensqo and 3M Speed R&D With AI, Robotics
- Chemical Plants Hit Automation Roadblocks on Path to AI
Scientific artificial intelligence (AI) initiatives typically fail when challenges that require science-specific approaches are addressed with generic solutions. Science-smart AI — tools and strategies tailored to the complexity of real-world science — demand different methods than standard business AI. Organizations often apply data practices that work in other industries without recognizing that scientific information requires different handling.
Scientific information must be represented with a rigorous consistency. The same term can carry entirely different meanings across sub-fields, and small details can fundamentally alter scientific interpretation. Standardized terminologies and ontologies are essential to structure and harmonize chemical data. The scientific community faces an unprecedented challenge as research data moves into digital space, requiring both machine-readability and human interpretation to ensure accuracy and completeness.
Adherence to these standards must extend across both historical backfiles and incoming new data. Data accuracy in scientific databases relies on manual curation by professional experts, with curated data requiring further review by the scientific community to ensure high accuracy. Chemical identifiers must be standardized, assay targets clearly defined and metadata harmonized to enable interoperability. Large language models cannot serve as exclusive solutions for data governance and quality assurance. While these tools assist with pattern recognition and data structuring, they cannot replace the domain knowledge required to ensure scientific integrity.
Data breadth, depth and quality determine model effectiveness. Quality in this domain extends beyond traditional cleanliness and standardization to include scientific accuracy and integrity. The best training sets include data on negative outcomes, recorded in consistent formats. Errors in stereochemistry, reaction conditions or atom mapping render predictions scientifically meaningless, regardless of statistical performance.
Even the highest-quality data requires accurate interpretation and use to build scientifically sound AI solutions. Expert guidance on how data is applied in AI solutions requires a deep understanding of both the science and the data. Domain experts ensure that models learn chemical principles rather than statistical artifacts, informing how information is interpreted and used throughout the development process.
Scientific Problem Definition is Essential for AI Success
AI cannot deliver meaningful results in chemical R&D without a clearly defined scientific objective. When models are built without a precise hypothesis or operational constraint, they often optimize for metrics that do not reflect real-world success. Accuracy alone is insufficient if the output cannot be translated into laboratory conditions or scaled for production.
In many cases, AI systems are trained to maximize statistical performance. However, this approach can lead to solutions that ignore physical limitations, safety requirements or material availability. A model may suggest a reaction pathway that appears efficient on paper but fails under actual lab conditions due to incompatible reagents or equipment constraints. These outcomes waste resources and erode confidence in technology.
Effective AI implementation begins with a well-structured question. Researchers must identify the specific scientific hypothesis being tested and define the boundaries within which the model must operate. This includes experimental constraints, regulatory considerations and known chemical principles. Without this framing, even sophisticated algorithms will struggle to produce actionable results.
Domain expertise plays a critical role in this process. Chemists and process engineers understand which variables influence outcomes and which are irrelevant. Their input ensures that models focus on meaningful relationships rather than statistical noise. When scientific knowledge guides model development, the likelihood of producing valid, reproducible results increases significantly.
Success metrics must also be aligned with operational goals. A model that performs well in validation tests but fails to improve yield, reduce cycle time or enhance safety doesn’t meet the needs of chemical R&D. Metrics should reflect the business outcomes that matter to researchers, engineers, and leadership teams.
Defining the right question is not a preliminary step to be rushed. It is the foundation of every successful AI initiative in science. Without it, even the most advanced tools will produce results that are technically impressive but scientifically irrelevant.
Collaborative Expertise is Required to Build Effective Chemical AI
Developing AI solutions for chemical R&D requires more than technical proficiency. Success depends on collaboration across disciplines that bring distinct but complementary capabilities. No single team can address the full range of scientific, computational, and data-related challenges involved in deploying AI in complex chemical environments.
Three types of expertise must be integrated to achieve reliable outcomes.
1. Domain experts contribute scientific depth
These individuals understand the chemistry, biology or materials science relevant to the problem. They bring firsthand knowledge of laboratory workflows, experimental constraints and variables that influence outcomes. Their insights help ensure that models reflect real-world conditions and avoid assumptions that conflict with known principles.
2. Technology experts provide computational capabilities
Specialists in machine learning, algorithm design and software engineering build the systems that process data and generate predictions. Their role includes selecting appropriate model architectures, optimizing performance and ensuring scalability. Without this expertise, even high-quality data cannot be translated into actionable insights.
3. Content experts ensure data integrity and usability
These professionals focus on data modeling, curation and harmonization. They manage the structure, consistency and quality of scientific information across sources. Their work enables models to learn from accurate, connected data rather than fragmented or inconsistent inputs.
When these groups collaborate effectively, AI initiatives are more likely to produce measurable impact. Each discipline contributes essential knowledge that strengthens the others. Scientific relevance, computational precision and data reliability must all be present for AI to support decision-making in chemical R&D.
How Curated Data Improves AI Prediction Accuracy in Chemical R&D
The quality of input data directly influences the reliability of AI predictions. In chemical R&D, curated and connected datasets consistently outperform larger, unstructured sources. This is not a matter of volume. It is a matter of scientific integrity.
Internal experimentation by CAS, a division of the American Chemical Society, shows the impact of curated data. In one experiment, a model trained on a CAS-curated dataset for drug–protein binding achieved twice the prediction accuracy of a model trained on a large public dataset, despite using 50% fewer records. Another test in retrosynthesis planning showed more than a 30% improvement in generating valid pathways for complex molecules when models were trained on CAS data with verified atom mapping. These gains were driven by improvements in data quality, rather than algorithm changes.
Details matter. Verified stereochemistry, complete reaction conditions and accurate atom mapping allow models to learn chemical relationships rather than statistical noise. These elements are often missing from public datasets but are preserved in curated sources.
Curated data does more than improve accuracy. It reduces the risk of misleading outputs and supports reproducibility. In chemical R&D, these outcomes are essential. Models must reflect both the math and the science.
Building a Sustainable Foundation for Chemical AI
Artificial intelligence will not transform chemical R&D without a foundation built on scientific relevance and operational utility. Technology demands supporting infrastructure, expertise and data that reflect the complexity of chemical research.
Pilot projects often demonstrate technical capability yet fail to scale. Models that lack integration with laboratory workflows produce results disconnected from experimental reality. Adoption stalls. Even accurate predictions get dismissed when they do not align with defined scientific objectives.
Chemical knowledge evolves continuously. Our understanding of reaction mechanisms deepens with each new computational method and experimental technique. As compound classes expand, analytical techniques improve and replace older methods.
Curated datasets structured for scientific use allow models to reflect chemical behavior with greater precision. When organizations treat data as a strategic resource rather than a byproduct of research, they can apply AI across the full R&D lifecycle with real confidence.
Chemists, engineers and data scientists must contribute throughout the development and deployment phases. A data scientist working alone may build technically sophisticated systems that ignore physical constraints. A chemist working alone may understand the science deeply yet lack the tools to implement solutions on a large scale. Engineers know what can be built and operated.
Success gets measured by outcomes that matter to researchers and operations teams. Yield improvements justify investment. Reproducibility gains reduce wasted experiments. Safety enhancements protect people and facilities. Accuracy metrics alone fail to show whether a model advances discovery or simply performs well on test data.
Organizations approaching AI with discipline and scientific clarity will be better equipped to close the expectation gap. Aligning technology with the realities of chemical R&D requires time and investment in unglamorous work, such as data curation and governance. This approach enables systems to deliver measurable results over time rather than impressive demonstrations that fade into irrelevance.
Check out part 1 of this series, “AI in Chemical R&D: What's Holding Back Real-World Impact.”
Andrea JacobsAndrea Jacobs
senior manager, CAS Product Management
Andrea Jacobs is director of data analytics at CAS, a division of the ACS specializing in scientific knowledge management. In her current role, Andrea leads a team of data scientists, many of whom also have an educational background in a natural science discipline such as chemistry, biology and pharmacology, tasked with pioneering science-smart AI solutions to accelerate R&D workflows. In her 15-year tenure with CAS, she has held scientific, technical and business leadership roles spanning the organization’s end-to-end operations, including enterprise strategy, product development, partnerships, content licensing and data curation operations and infrastructure. Andrea earned her bachelor’s degree in chemistry and computer science from Wellesley College and an MBA from The Ohio State University.
