Equipment & Services: June
Share Print Related RSS
Page 1 of 2 « Prev 1 | 2 View on one page
Dewatering-drying system features circular fluid bed
This dewatering-drying system consists of a circular vibratory screener integrated with a circular fluid-bed dryer to remove oversize and undersize particles while dewatering and drying on-size material. The screener, a 30-in. (762-mm) diameter Vibroscreen model K30-2-SS, together with the 40-in. (1,016-mm) diameter model K40/48-1FBD-SS dryer, removes up to 50 gallons (189 liters) of water per minute, and dries up to 700 lbs (318 kg) of on-size particles per hour. It’s equipped with an imbalanced-weight gyratory motor that vibrates the screening chamber, which is suspended on springs.
Kason Corp., (973) 467-8140, www.kason.com
Compressors boast high efficiency
The GA range of oil-injected compressors achieves efficiency through, among other things, state-of-the-art compression elements based on asymmetric rotor profiles, which drastically reduce volumetric losses. Through the optimization of oil injection, flow and temperature, the compression process is kept at the coolest possible temperature, thereby minimizing thermodynamic losses. Other design features to further reduce energy consumption include the use of radial fans with variable speed drive (VSD) regulation, high-efficiency motors and no-loss drains. Extra energy-saving options such as an integrated energy recovery system and VSD for the main motor can provide even greater benefits.
Atlas Copco, (413) 493-7290, www.atlascopco.com
Metal detector suits hazardous locations
The Phantom HL-AT model metal detector is certified with ATEX compliance for use in hazardous location zones 21 and 22. The ATEX approval validates the detector’s intrinsic safety in potentially explosive dust atmospheres, typically found in powder handling plants. It is now available in gravity units for freefalling bulk product, or in standard horizontal units for products transported via conveyor.
Fortress Technology, (888) 220-8737, www.fortresstechnology.com
Switch checks liquid levels in tanks
The Gladiator Conductivity Smart Switch Series offers a simple, reliable way of sensing levels of conductive liquids. This type of switch is suitable for any situation where it is necessary to check the level of a liquid in a tank, including high or low level alarms, constant level control, pump control, and empty tank detection. A low-voltage AC signal is applied between the probe electrode and the tank wall (or reference electrode in case of a non-metallic tank). When the liquid comes in contact with the electrode tip, a conductive path is established between the sense electrode and the metallic tank wall/reference electrode. Current flow due to the conductive path is sensed, amplified and used to switch a relay for indication or control purposes.
Hawk Measurement, (888) 429-5538, www.hawkmeasure.com
Operator interfaces include intuitive development package
The PowerView 8000 Series of operator interfaces are said to provide an enhanced, easy to use, and intuitive development package, ViewBuilder 8000. This series directly replaces the current version. The series provides four LCD sizes to fit different applications, 5.6-in. QVGA, 8.0-in. VGA, 10.4-in. VGA, and now 12.1-in. SVGA. All units have vibrant 65K Color TFT LCD displays with analog resistive touchscreens. The ViewBuilder 8000 software provides increased functionality including, advanced object libraries, historical and real time trending, alarm and recipe management, Windows True Font multi-language text display, support for BMP, JPG and GIF files, as well as online and offline simulation.
What are your comments?
Comments
