Case Study: Instruments Tame Troublesome Slurry
Two-step approach allows resin plant to more accurately dose additive.
Oct. 16, 2009
6 min read
Lubrizol Advanced Materials’ Louisville, Ky., plant produces chlorinated polyvinyl chloride (CPVC) resin by reacting chlorine and PVC. To transport resin from vessel to vessel, the CPVC is mixed with water. A centrifuge later dewaters the slurry. Some CPVC grades then require dosing a very small amount of an additive chemical before going to a fluid-bed dryer to produce the final resin powder.
The CPVC particles are porous in structure and no two are exactly alike. This poses processing challenges. In particular, the % solids in the slurry can vary from run to run and from one type of resin to another —which made achieving the target additive dosage very difficult and resulted in manufacture of excessive non-prime product.
So, the plant set out to find a controllable and reproducible dosing method.
Originally, it relied on a simple ratio calculation based on the torque reading of the centrifuge. This method only succeeded about 60% to 80% of the time; the low success rate stems from inherent variability of the ratio calculation. First, the torque reading isn’t an exact measurement of the amount of mass going through the centrifuge. General use and wear on the centrifuge can shift the torque reading, resulting in inconsistent measurements from one run to the next. Second, the calculation uses a constant that’s, at best, a rough estimate.
The Challenge
The amount of CPVC determines the quantity of additive required (which is a wt. % of dried resin). So, it’s necessary to know the CPVC slurry’s flow rate and its % solids. It’s tough, however, to obtain accurate measurements with two-phase flow.
Faced with this challenge, Lubrizol engineers worked with their counterparts at FCX Performance, a flow control products distributor, to devise a cost-effective and accurate two-part solution. First, we chose a device to measure the slurry’s volumetric flow rate. Second, we found an instrument to measure its % solids.
Consistency Analyzer
Figure 1. Devices measures microwave travel time, which relates linearly to % solids.
Source: Metso Automation.
We couldn’t use Coriolis technology to measure flow because such meters require the same mass in two tubes. Since the CPVC particles vary in size and shape, it’s impossible to ensure the same mass in both tubes. Flow meters that use infrared technology proved unsuccessful because the slurry’s solids level (typically greater than 25%) was too high to allow an effective reading. The plant also tried ultrasound devices but that technology couldn’t cope with the porous nature of the CPVC particles. The possible presence of gas particles trapped inside resin particles means the flow actually could have three phases — solid, liquid and gas.
We opted for the FSM4000 magnetic flow meter (magmeter) from ABB to measure volumetric flow rate. With no moving parts, magmeters are nearly maintenance free. They use small electrodes that protrude into the media stream — and so are ideal for slurries, dirty liquids, wastewaters and applications requiring small pressure drops. However, such meters generally won’t work with nonconductive fluids such as hydrocarbons. The volumetric flow rate measured by the magmeter goes to the distributed control system.
Next, the search began for an instrument that could accurately measure % solids. We tried infrared technology but it proved unsuccessful. The high percentage of solids made the slurry too noisy to get an accurate reading. We also tried a turbidity meter but it couldn’t handle the conditions either.
We discussed the problem with Lubrizol engineers; a few days later when Joe was meeting Metso factory personnel he raised the idea of using a Metso kajaaniMCA Consistency Analyzer (Figure 1). This device uses patented microwave “time of flight” technology. Flight time of the microwave sent across the pipe depends on the dielectric constant of the material in the medium. Because solids typically have a lower dielectric constant than water, the microwave signal travels faster through solids than water. This travel time across the pipe bears a linear relationship with % solids. The technology has served for years to measure stock consistency at paper mills and solids in process streams at municipal sewage plants.
Trial Runs
The analyzer never had been used on CPVC slurries; so, Lubrizol suggested trial runs to prove its validity for that service; Metso agreed and FCX Performance arranged for the trials. Metso personnel assisted with the initial instrument installation and set up. Lubrizol staff then tested the device from June to September 2007. Slurries of various resin grades were sampled and laboratory measurements for % solids were compared to the kajaaniMCA Consistency Analyzer’s readings.
The analyzer gave steady, repeatable results over a sustained time period that corresponded closely with lab data. Readings fluctuated with feed tank level.
The plant historically had observed that % solids varied with tank level. One contributing factor had to do with tank agitation. The tank agitator has dual blades. When tank level is near or slightly above the top agitator blade, mixing is more uniform. Another contributing factor is that when tank level is low, water in the slurry is more likely to pump out first, leaving more CPVC in the tank and raising the % solids. Measurements from the analyzer proved this theory.
The kajaaniMCA readings allowed calculation of mass flow rate and, thus, much tighter regulation of additive dosing. The process stayed in control as the slurry’s flow rate and % solids shifted.
Due to the dynamics of the dryer, there typically tends to be a three-to-four-hour delay from when a change is made in additive dosing to when a change is seen in the end product. Using the kajaaniMCA Analyzer, the change appears only two hours after switching from ratio control to mass flow control. This indicates the accuracy of CPVC measurement and the improvement using measured-mass instead of ratio control.
Historically, 5% of all material treated with the additive was produced out of spec. The first two runs in which the kajaaniMCA Consistency Analyzer was used for process control yielded no out-of-spec material. Lubrizol Advanced Materials targets an off-spec limit of less than 1% for additive-treated resins.
Collaboration among Lubrizol, FCX Performance and Metso Automation has truly created a win-win-win situation. The plant now has achieved accurate measurement of slurry % solids while FCX, which sells Metso products, and Metso itself have opened up a new market for the analyzer.
Kerry Haight is a process engineer for Lubrizol Advanced Materials, Inc., Louisville, Ky., a subsidiary of The Lubrizol Corporation. Joe LaPoint is a chemical engineer and account manager for FCX Performance, Indianapolis, IN. E-mail them at [email protected] and [email protected].
Kerry Haight
