Displaying 1-348 of 348 results
Flow Meter Suits Various Pipe Diameters
Modular EE741 in-line flow meter from E+E Elektronik measures consumption of compressed air and technical gases.
E+E Electronik
Pump Control Improves Boiler Efficiency
Cognitive pump technology integrates the boiler firing rate with pump speeds to improve boiler and system efficiency while reducing electrical consumption.
Thermal Solutions Products
Intelligent Marshalling Improves Efficiency
Schneider Electric extends universal I/O capability for Foxboro and Triconex.
Pump Motors Feature High Thrust Capacity
Siemens introduces new high-thrust pump motors.
Connectors Improve Fluid Management
Users can connect, reconnect and disconnect even when flow path is wet and pressurized.
Membrane System Requires Less Air
Hollow-fiber membrane provides efficient separation of nitrogen from air.
Product Type: Membrane technology
Evonik
Bulk Bag Discharger Fits Restricted Areas
Low-cost frames of variable heights and offsets fit restricted areas previously used for dumping smaller containers such as sacks, pails, drums, boxes and bins.
Pumps Ensure Safe Operation
Watson-Marlow 530 peristaltic cased pumps are suited for metering and transfer applications such as surface coating, printing and lime addition.
Submersible Motor Uses Permanent Magnet Technology
Motor features higher efficiency at full and partial loads and lower thermal losses than asynchronous designs.
Flowserve
Catalyst Offers Increased Stability
PhosphonicS introduces Phos-Cat4 acid catalyst.
Product Type: Catalysts
PhosphonicS
MBR Lowers Aeration Energy Consumption
KMS MBR requires a smaller system footprint and reduces long-term operational costs.
Koch Membrane Systems
Ductless Fume Hoods Ease Installation
Purair 5 Ductless Fume Hoods feature a high level of operator protection where routine work is being carried out.
Filters Remove Extremely High Solids
Self-cleaning filters are available in convenient skid design.
Dow Water & Process Solutions
Separator Improves Metal Capture
Industrial Magnetics introduces a t-trap magnetic separator for liquid processors.
Product Type: Strainers
Industrial Magnetics, Inc.
System Detects Wastewater Leaks
GF Piping Systems introduces three new leak detection systems.
Flow Meter Combines Three Devices into One
Swirl technology enables very short upstream and downstream piping requirements.
System Helps Analyze and Manage Energy Use
Energy Advisor automates the process of monitoring and managing energy consumption.
Software Streamlines Workflows
The aspenONE V8.8 software release features user-friendly, streamlined workflow innovations that reportedly allow users to minimize capital costs, improve plant productivity and boost operational profitability.
Ductless Fume Hood Saves Energy
Purair ECO is designed for chemical and particulate protection for laboratory and industrial applications.
Siemens Introduces Integral Volume Booster
Siemens Industry introduced an Integral Volume Booster accessory for the Sipart PS2 electro-pneumatic valve positioner, designed for pneumatic actuators that require high flow for fast stroking times.
ProComSol Introduces Smart Device Communicator App
ProComSol, Ltd. released the Android based Smart Device Communicator application for HART instruments.
ProComSol, Ltd.
MYNAH Introduces Mimic Simulation Software v3.6
MYNAH Technologies announced the release of Mimic simulation software for plant life cycle business results.
MynahTechnologies
Bonomi Introduces Valpres Series Ball Valves
Bonomi North America introduced wafer stainless steel, full-port ball valves, a flow-enhancing alternative to high-performance butterfly valves in OEM applications, skid-mounted systems or any tightly-confined area.
Watson-Marlow Introduces Qdos 60 Pump
Watson-Marlow Pumps Group introduced the Qdos 60, a larger version of the Qdos 30 peristaltic metering pump.
BinMaster Introduces Flow Detect 2000
BinMaster introduced Flow Detect 2000 detection sensor.
BinMaster
Liquid Expansion Trap Provides Freeze Protection
Compact trap offers last line of defense against pipe freezing.
Product Type: Replacement components and materials
Stainless Steel Quick Couplings Are Non-Spill and High-Flow
Coupling series offers contamination-free transfer, fill and dispensing of DEF and other chemicals.
New Tantalum Heat Exchangers for Highly Corrosive Applications
Alfa Laval Introduces New Tantalum Range
Flow Meter Handles Harsh Environments
Invensys Launches Foxboro 84 Series MNPT Vortex Flow Meter
Invensys
Turbomolecular Pump Handles Large Capacities
Edwards Ltd. Launches STP-iXA4506 Large-Capacity Turbomolecular Pump
Direct-Insertion Density Meters Handle Demanding Process Applications
Emerson Introduces Direct-Insertion Density and Concentration Meter
Glass Bob Sensor Measures Silica Levels in Fracking Sand
BinMaster Launches Glass Bob Sensor for Measuring Silica Sand Level
BinMaster
Quaternary Diaphragm Pumps Feature Injected-Molded PE Pump Chambers
Quattroflow Releases 1200SU-M Series Single-Use Quaternary Diaphragm Pumps
Quattroflow
Control Valve Complies with ISO 15848 Fugitive Emissions Requirements
Flowserve Announces New Valtek GS and Logix 420 Control Valve System
Flowserve
Screw Blower Provides Potential Energy Savings of 30 Percent
Atlas Copco Extends ZS Screw Blower Range
Engineering Software Includes Expanded Activation Capability
Aspen One Technology Launches aspenONE Version 8.4
Directed Combustible Dust Explosion Pressure Venting Protects Plant Workers
Rembe Launches TARGO-VENT Combustible Dust Explosion Pressure Venting
Tank-Cleaning Machine Minimizes Physical Effort During Clean-in-Place
Gamajet Launches Aseptic 8 Tank Cleaning Machine
Drive Handles Water and Wastewater Applications
ABB Introduces ACQ550 Drive for Wastewater and Water Applications
Automation Controller Handles Extreme Conditions
Siemens Launches Siplus S7-1500 Automation Controller for Extreme Conditions
Air-Cooled Heat Exchanger Monitoring Solution Features Wireless Plug-and-Play...
Emerson Releases Wireless Air-Cooled Heat Exchanger Monitoring Solution
Plants Can Save Up to $450,000 Annually With On-Line Monitoring of Cooling ...
Emerson Launches Cooling Tower Monitoring Solution
Gas-Specific Gravity Meter Directly Measures Modular Weight
Emerson Releases Micro Motion Specific Gravity Meter
New Pump Hoses for Food Applications Offer Enhanced Wear Resistance
Watson-Marlow Pumps Group Launches Food-Grade Hose for Use With Bredel Pumps
Ductless Fume Hoods Exceed OSHA, ANSI Standards
Air Science Launches Purair 5 Ductless Fume Hoods
Level Sensor Provides Reliable Bin Level Data
BinMaster Launches BinMaster RL Level Sensor for Non-Contact Level Measurement in Bins
BinMaster
Dispensing System Provides Valveless Micro-Volume Fluid Control for Catheter ...
Fluid Metering Introduces PDS-100 Valveless Micro-Volume Fluid Control
Fluid Metering, Inc.
Semi-Automatic Valve Manifold Boxes Feature Rail-Mounted Stick Design
Semi-Gas Systems Simplifies Gas Distribution with Semi-Automatic Valve Manifold Box
Semi-Gas Systems
Transmitter Monitors Remote Locations
The Rosemount 3308 wireless guided wave radar transmitter provides accurate level monitoring for remote or difficult-to-reach locations where installing new cabling would be costly or impractical.
New Spray System Provides Automatic Control of Spray Nozzles
Spraying Systems Launches AutoJet Model 1550+ Modular Spray System
Spraying Systems Co.
Acrylic Flow Meter Includes Newly Designed Multi-Turn Valve
Aalborg Offers Built-In Needle Valve Option for Acrylic Flow Meters
MES Solution Integrates With Logix Control Platform
Rockwell Automation Extends Capabilities of PharmaSuite System
Range of Gas Generators Meets High Purity Standards
Atlas Copco Launches a Full Range of Nitrogen and Oxygen Generators
Product Type: Generator
GFEP Device Prevents Equipment Damage Related to Ground Faults
ABB LV Products Introduces the F200 GFEP Device
FDA-Compliant Material-Handling Hose Reinforced With Polyurethane Fabric
Kuriyama Introduces Tigerflex VLT-SD Dissipative Hose
Product Type: Hoses
Kuriyama
Pump Provides Linear, Repeatable Flow Performance
Watson-Marlow Launches ‘Qdos’ Range for Chemical Metering Applications
Blower Health Monitoring Solution Mitigates Failure Threats
Emerson Introduces Blower Health Monitoring Solution
Electronic Control Package Compatible With L120 Series Actuators
Flowserve Launches UEX Electronic Control Module for L120 Electric Actuators
Flowserve
Emissions Control Technology Manages VOCs, HAPs and Odors in Industrial ...
Envirogen Technologies
Flow Meter Includes Compact Stem Accessory
Spirax Sarco Releases Gilflo ILVA Flow Meter with Compact Stem Accessory
Variable Area Flow Meter Performs in Extreme Conditions
Brooks Instruments Introduces MT3809 Variable Area Flow Meter
Flow Meter Features Compact Wafer Design
Spirax Sarco Offers the Gilflo ILVA Flow Meter
Qdos Pump Range Features ReNu Pump Head Technology
Channel Grinder Increases Flexibility and Management of Channel and Flow ...
Moyno Launches Larger Models of Annihilator C3A Channel Grinder
Moyno
Gas Turbine and Transmitter System Measures Volumetric Flow
Omega Introduces Gas Turbine and Transmitter Systems
Clog-Resistant Nozzles Now Available in Larger Sizes
Spraying Systems Expands MFP FullJet Nozzle Line
Product Type: Nozzle
BPX Brazed Plate Heat Exchangers Withstand High Pressure and High Temperatures
Xylem Expands Its Line of Bell & Gossett BPX Brazed Plate Heath Exchangers
Xylem Inc.
Steel-Reinforced Pipe Handles Rugged Cyclic Loading Environments
FlexSteel Offers Steel-Reinforced Spoolable Onshore Pipe
FlexSteel Pipeline Technologies
Flow Meter Features ATEX Zone 1 Flameproof Approvals
Sage Metering Introduces Sage RIO Thermal Mass Flow Meter
Sage Metering
Electrochemical Sensors Measure pH and ORP
Invensys Introduces Foxboro Model PH12 Series pH and ORP Sensors
Pump Scales to Suit Process Changes
Bredel APEX Hose Pump Handle Corrosive Fluids
Software Boosts Quality Management
Flow Meter Boasts Reduced Footprint
Yokogawa Introduces ADMAG Flow Meter
Slurry Meter Replaces Obsolete Equipment
SCIAM Offers DM3 Density Meter
SCIAM Worldwide
Steam Trap Station Includes Stainless-Steel Relief Valves
Flowserve Introduces New Gestra Products For Boiler Controls
Flowserve
Flowmeter Measures Plant Utility Gases
Endress+Hauser Releases Proline T-mass 150 Flowmeter
Wireless Position Monitor Features On/Off Control For Discrete Valves
Emerson Introduces Wireless Position Monitor
Hydraulic Submersible Pumps Handle Sewage And Clean Water
Xylem Announces Addition To Godwin Range
Xylem Inc.
Process Automation System Includes Expanded Electronic Marshalling Feature
Emerson Releases New DeltaV Process Automation System
Communication Interface Powers Thermal Mass Flow Controller Processing
Brooks Instrument Integrates EtherCat With Flow Controllers
Control System Maintains Consistent Phosphorus Level
RTC101 Phosphorus Control System provides real-time control of chemical dosing
Hach
Flowmeters Measure Fuel Flow
Hawk Measurement Releases Model 140 MX Flowmeters
Hawk Measurement
Pumps Include No Seals Or Valves
Watson-Marlow Launches Qdos Pump Range
Pumps Feature Reverse Vane Impeller
Flowserve Unveils Durco Mark 3 ISO Pumps
Flowserve
Hose Pumps Handle Corrosive Fluids
Watson-Marlow Bredel Releases Apex Range Pump Line
Software Performs Dynamic Simulations
Invensys Introduces Dynsim Version 5.0
Spray Nozzle Handles Alcohol, Solvents
Spraying Systems Unveils PulsaJet Nozzle
Ball Valve Features Three-Piece Design
Viega Propress Introduces Three-Piece Ball Valve
Sensors Measure Ammonium Activity
ECD Launches MVS10/MVS17 Ammonium pIon Sensors
Reducing Valve Includes Air Service Capability
TLV Introduces DR20 With Air System Capability
Nitrogen Generators Adjust To Capacity Needs
Titus Nitrogen Expands TNX Series Generators
Insulation Reduces Need For Joint Sealant
Pittsburgh Corning Expands Foamglas One Insulation Line
Peristaltic Pumps Built For Heavy Industrial Applications
Flowrox Offers LPP-T Peristaltic Pumps
Specialized Filters Offer Real-Time Sampling
Parker Hannifin Introduces Balston Fast-Loop Filters
Regenerative Blowers Comprise Cast Aluminum Housing
Ametek Offers Two New Rotron Regenerative Blowers
Ametek Technical and Industrial Products
Tank Cleaning Nozzles Handle Clean-In-Place Applications
Spraying Systems Introduces TankJet 9 Rotating Nozzles
New Electrochemical Sensors Measure PH And ORP
Invensys Introduces PH12 Series pH And ORP Sensors
New Smart Valve Actuator Utilizes Brushless Direct Current Voltage Motor
Flowserve Announces Limitorque QXM Smart Valve Actuator
Flowserve
Digital Flow Computer Handles Various Custody And Process Applications
Krohne Introduces Summit 8800 Digital Flow Computer
KROHNE
Acoustic Cleaner Helps Prevent Dry-Particulate Build-Up
Martin Engineering Introduces New Sonic Horn Acoustic Cleaner
Martin
Combustion Analyzer Measures Ambient Air Temperature
E Instruments Introduces E1100 Combustion Gas Analyzer
E Instruments
Texture Analyzer Provides Consistent Gelatin Analysis
Brookfield Engineering Offers CT3 Texture Analyzer
Ceramic Reactor Handles Industrial-Scale Chemical Production
Corning Introduces New Advanced Flow G4 Ceramic Reactor
Product Type: Plate reactor
Corning
Tank Cleaner Handles Medium-Impact Jobs
TankJet 75 Provides Small-Tank And Tote Cleaning
Solution Helps Design Fluid-Flow Systems
Invensys Introduces SimSci-Esscor Visual Flow 5.4
Tank Cleaner Removes Residues From Large Tanks And Reactors
Spraying Systems Launches TankJet 360 Tank Cleaner
Simulation Software Enhancements Include Thermodynamic Correlations Update
Invensys Releases SimSci-Esscor PRO II 9.0 Simulation Software
Bulk Bag Unloader Suitable For Low-Headroom Situations
Flexicon Offers New Single-Trip Bulk Bag Unloader
Flowmeter Utilizes Ceramic Ball Bearing System
Cox Flow Measurement Announces LoFlo Series Flowmeter
COX Instruments
Gas Management System Provides Continuous Pressure And Flow
Concoa Unveils Integrated Gas Management System
Concoa
Package Boiler Products Allow For Upgrades And Conversions
Hamworthy Provides Broad Range of Package Boiler Products
Hamworthy Peabody Combustion
Swirlchamber-Style Nozzles May Offer Longer Wear Life
Spraying Systems Introduces SV SprayDry Nozzles
HART-Enabled Migration Solution Facilitates DCS Upgrade
Invensys Introduces Fisher Provox HART Migration Solution
Product Type: Integration with IT systems
Tandem Diaphragm Pumps Suit Various OEM Applications
KNF Neuberger Releases Newest Pump Configuration For OEM Applications
KNF Neuberger Inc.
Wireless Adapter For HART Devices Provides Remote Asset Monitoring
ABB Unveils Wireless Adapter For HART Instrumentation
Product Type: Wireless
Diaphragm Offers Longer Life
Software Suite Extends Predictive Maintenance Capabilities
Emerson's AMS Suite Expands Scope With Profibus DP Support
Mobile Device Includes Oil And Gas Module
Invensys Releases Wonderware IntelaTrac 4.0
Programmable Automation Control System Provides Entry For Enterprise Control ...
Invensys' Foxboro PAC System Offers Integrated Hybrid Control
New Submersible Wastewater Pumps Are Designed To Reduce Maintenance
Grundfos Unveils SL Submersible Pump Range To Handle
Grundfos
Flow Controller Features Advanced Core Sensor Technology
Sierra Introduces New High Performance Flow Controller
Higher Control-Valve Range Provide More Options For Various Applications
Spirax Sarco Releases The New Spira-Trol Range
Flexible Screw Conveyer Equipped With Integrated Bag Compactor
Hapman Introduces A New Mobile Flexible Screw Conveyor
Hapman
AODD Pump Technology Is Designed Energy Savings
Warren Rupp Launches The AirVantage AODD Pump
Warren Rupp
Seals-Free Pumps May Reduce Maintenance Costs
Watson-Marlow’s Bredel SPX Pump Is Designed For Harsh Environments
New Pump Is Suited For High-Solids Content Materials
Moyno Introduces The 2000 CC Pump
Moyno
Minimize Overspray And Quality Problems With Modular Spray System
Spraying Systems’ New Model Offers Precision Spraying
Optical Dissolved Oxygen Sensor Features Increased Fouling Resistance
Emerson Introduces RDO Sensor And Analyzer
Compact Sensors Broadens Range Of 2-Wire Applications
Flow | Emerson Expands Application Range Of Micro Motion Flowmeters | Chemical Processing
Screw Vacuum Pumps Require Low Maintenance
Edwards Introduces GXS Dry Screw Vacuum Pumps
Flexible Screw Conveyor Processes Sluggish Materials
Hapman Introduces Flexible Screw Conveyor
Hapman
New Cartridge Filters Can Improve Particle Retention
Gore Releases Cartridge Filters For Semiconductor Industry
W.L. Gore
U.S.-Built Transmitters Are Competitively Priced
Endress+Hauser Announces New Transmitter Lines
High-Flow Diaphragm Valve Designed for Improved Flow Performance And Reduced ...
GF Piping Introduces Diaphragm Valve
Bulk Bag Unloader Offers Maximum Dust Containment
Hapman Introduces Bulk Bag Unloader
Hapman
Chute Box Dumper Discharges Bulk Solid
X-0735 Open Chute Box Dumper Introduced by Flexicon
Bearingless Sump Pump Expands Flow Range
Peristaltic Hose Pumps Handle Range of Liquids
Acoustic Wave Transmitter Measures Two Applications At Once
Hawk Measurement
Tank Cleaning Machine Boasts Easy Maintenance
BETE
Flowmeter Designed To Increase Plant Availability, Enhance Safety
Emerson unveils Rosemount Vortex Flowmeter
Temperature Control Features Variable-Speed Pump
Huber launches the Unistat 905w
Huber
Flow Conditioner SignifiReduces Flow Meter Straight-Run Requirements
Vortab Co. Introduces VIP Flow Conditioner
Vortab Company
Multi-Stage Suction Pumps Feature Plug-And-Play Solution
Grundfos
WirelessHART Level Switch Enables Detection Anywhere
Emerson Adds Rosemount Vibrating Fork Liquid Level Switch
Technology Delivers Online Verification Of Meter Performance
Emerson Introduces Performance verification for Micro Motion Coriolis meters
Pump System Optimizes Tank Cleaning And Spray Nozzles
Fluid Delivery System Introduced by Spraying Systems Co.
Magnetic Flowmeter Employs Dual-Frequency Excitation
Yokagawa's Two-Wire Magnetic Flowmeter
Flowmeter Is Factory Configured
Brooks Instrument's Digital Communication
Dirty Service Control Valve Solutions Serve Severe Applications
Emerson Expands Dirty Service Control Valve Solutions
Flowmeter Features Stainless Steel Transmitter Housing
Emerson Process Management Expands Rosemount 8800D Series
Switch Detects Fly Ash Levels
Hawk Measurement's Gladiator Switch Product Line
Hawk Measurement
Biometric Switch Enables Fingerprint Recognition Technology
Schneider Electric Introduces Biometric Switch For Fingerprint Recognition
Combustion Gas Analyzer Performs Many Functions
E Instruments Introduces E2200 Combustion Gas Analyzer
E Instruments
Water Jet Converts To 40,000 PSI
NLB unit is 400 hp and 40,000 psi
NLB Corp.
Tank Gauging Systems Include Wireless Functionality
Emerson introduces Rosemount TankRadar Rex and Pro
Product Type: Data handling and archiving
Flow Sensor Permits Hot-Tap Access To The Pipe Stream
GF Piping Systems Metal Magmeter
Multi-Variable Flow Meter Monitors Steam, Gas
Spirax Sarco Introduces MassTracker
Shaft Alignment Tool Guides Users, Reduces Errors
Ludeca
Certified Service Facilities Feature Fluid Handling Support
Moyno Certified Service Facilities
Moyno
Half-Inch Needle Valve Boosts Reliability
Parker Hannifin Introduces Half-Inch Needle Valve
Valve Maintains Set Flow Regardless Of Fluctuations
ITT Bell & Gossett Introduces Optiflo Control and Ultraset Valves
Bell & Gossett
Hand-Held Combustion Gas Analyzer Is Pre-Calibrated, Rugged
E Instruments E1100 Combustion Gas Analyzer
E Instruments
Pleated Filter Cartridge Eases Filter Replacement
Argonide Corporation
Large Butterfly Valve Features An Off-Center Shaft
GF Piping Systems Expands Butterfly Valve Offering
Liquid Vortex Flow Sensor Features High Accuracy and Low Cost
Clark Solutions Showcases Liquid Vortex Flow Sensor
Position Monitor Uses WirelessHART Communications
Emerson Process Management Fisher® 4320
Product Type: Communication
Data Logger Promises Corrosion Inhibitor Savings
Rohrback Cosasco Systems
Temperature Controllers Simplify Automated Control Processes
Schneider Electric Zelio REG Controllers
Compressor Control System Features Web-Enabled Monitoring
Maestro Universal Compressors
Cameron Compression Systems
Cartridge Filters Intended For Semiconductor Applications
Gore Introduces 40nm-rated Cartridge Filters
W.L. Gore
Reverse Osmosis System Reduces Complexity, Footprint, and Installation Time
Koch Membrane Systems To Showcase Megamagnum Reverse Osmosis System
Particle Imaging and Analysis System Provides Visual Documentation
New FlowCAM V-1000 Particle Imaging and Analysis System
Fluid Imaging Technologies
WirelessHART Conductivity Transmitter Well Suited For Many Applications
Emerson's Smart Wireless Conductivity Transmitter
Flow Meter Is FM And CSA Approved
FCI Showcases ST50 Mass Flow Meter
Rugged Hand-Held Combustion Analyzer Is Pre-Calibrated
E Instruments
Software Solution Tracks Discrete Manufacturing Operations
Proficy Tracker 8.0 Delivers Lean Production Control
GE Fanuc
Mechanically Cleaned Strainer Conserves Process Fluids
New Eaton High Flow MCS Series
Eaton Corporation
Optical Gas Monitor Provides Real-Time Scanning
OXS Series In-line/On-line Optical Gas Monitor
Precisive LLC
Flow Meter Is Designed To Measure Thermal Energy Flow Rate
Sierra Introduces Ultrasonic Thermal Energy/ BTU Flow Meter
Pump Technology Boasts Reduction In Water Usage
Nash introduces its Eco-Flo CL upgrade line
Gardner Denver Nash
Electro-Pneumatic Positioners Offer Reliable Control
Bray Electro-Pneumatic Positioners with Reliable, High Performance Control
Bray International Inc.
Variable Speed Pump Controller Manages Up To Four Pumps
Bell & Gossett Introduces Variable Speed Pump Controller
Bell & Gossett
Air Filter Regulator Handles Harsh Environments
ControlAir Inc. Introduces Air Filter Regulator Type 330
Machinery Monitoring Solution Helps Predict Performance Of Assets
Emerson introduces AMS Performance Advisor
Desuperheater Promotes Rapid Water Absorption
Pick Desuperheater Series DS
Pick Heaters, Inc.
Liquid Transport Containers Are ISTA Approved
Meissner Introduces One-Touch Product Portfolio
Product Type: Tanks and vessels
Meissner Filtration Products
Conveyor System Ties Directly Into Existing Plumbing
Hapman Introduces SolidQuid System
Hapman
Guided Wave Radar Transmitter Eliminates Accuracy Errors
Emerson Introduces Vapor Option for Rosemount Sensors
Polypropylene Filter Cartridges Ensure Process Compatibility
Pentair Introduces Versaflex Series Filters
Pentair Industrial
Electromagentic Flowmeter Serves Water, Wastewater Markets
ABB Introduces FlowMaster portfolio
Flow Switches Offer High Repeatability
Omega Introduces FSW300 Flow Switches
Flow Meters Feature More Control And Flexibility
Sierra Introduces Next Generation Flow Meters and Controllers
Magmeter Designed for Hygienic Applications
ABB Instrumentation has launched a range of electromagnetic flowmeters.
Electromagnetic Flowmeter Designed for Process Applications
ABB Instrumentation has launched a range of electromagnetic flowmeters specifically targeted at the chemical, power, oil and gas, pulp and paper, and metals and mining markets.
Low-Cost Tube Pumps for Liquids of Low to Medium Viscosity
Aalborg’s Model TPU tube pumps are suitable for liquids of low to medium viscosity.
Explosion-Proof Current-to-Pressure Transducer Is Vibration and Position ...
ControlAir Inc. announces the introduction of the Type-595XP Explosion-Proof Current-to-Pressure I/P Transducer.
Filtration System Saves Equipment Costs, Floor Space and Labor Costs
Pentair Industrial introduces the Aqualine Liquid Filtration System, a cost-saving solution for high-flow-rate applications.
Pentair Industrial
Chambers for the External Mounting of Process Level Instrumentation
Emerson Process Management has introduced a range of chambers that allow for the external mounting of level measurement and control instrumentation on process vessels
Product Type: Chambers
Suite of Services Helps Customers Reduce Costs and Improve Production-System ...
Rockwell Automation has announced the availability of its InSite Services, a suite of managed services that helps manufacturers reduce costs, improve production-system performance and increase operating cash flow.
Variable Area Flow Meters with Foundation Fieldbus Option
Brooks Instrument has released the Foundation Fieldbus option on its variable area flow meters.
Pressurized Membrane System Meets Global Water Challenges
The pressurized ZeeWeed 1500 module offers cost-effective, skid-mounted solutions that can be installed for water treatment, tertiary filtration and pretreatment for brackish and seawater desalination.
Wedge Flow Meter Can Be Installed In Any Full-Pipe Orientation
Omega Engineering Inc. introduces its FW1000 series
Control Module for Use in Conventionally Wired Applications
Emerson Process Management announces a FieldQ control module for use in conventionally wired applications.
Product Type: Module
Oxygen Probe Expands Combustion Gas Analysis Capabilities
Featuring a revised sensor design and an increased choice of probe lengths up to 13.12 feet (4 meters), the Endura AZ20 expands ABB’s offering to a new range of high temperature applications up to 800°C.
Thermocouple with a Gas-tight Sapphire Protective Tube
Emerson Process Management has introduced a Rosemount thermocouple with a gas-tight sapphire protective tube for use in gasification reactor applications.
Multi-Parameter System Offers Simultaneous Determination
Mettler Toledo has launch version 2.0 of its LiQC multi-parameter system for simultaneous determination of density, refractive index, pH/conductivity and color.
Product Type: Density
Mettler Toledo
Multi-Parameter Paddle Wheel Flow Meter
Aalborg's Paddle Wheel Flow Meters offer cost-effective, high-accuracy solutions to low-flow liquid applications.
Configurable Industrial PCs Provide Flexibility
Phoenix Contact has introduced a line of competitively priced, configurable industrial PCs.
Product Type: PC Component
Phoenix Contact
UV-Resistant Clear PVC Piping
Harvel Plastics, Inc. announces the launch of EnviroKingUV, a clear PVC piping that is suitable for exposure to sunlight.
Category: Materials of construction
Product Type: Plastics
Flowmeter Can Cut Installation Costs
ABB Offers Orifice Flowmeter – Cuts Installation Costs
Mass Flow Controller Is Insensitive to Fluctuations
Brooks Instrument has released the B-Series mass flow controller, a family of mass flow products designed to be insensitive to fluctuations in pressure and temperature.
Wireless Transmitter for High Density Temperature Measurement
Emerson Process Management announces the expansion of its Smart Wireless solutions with the introduction of its Rosemount 848T wireless temperature transmitter for high density temperature measurement.
Random Packing Cuts Pressure Drop
Product Type: Insulation and jacketing
Koch Knight LLC
Expanded Coriolis Meter Features Loop-Powered Transmitter
Emerson's Micro Motion 2200S transmitter is now available on ELITE Coriolis meters for line sizes ranging from 1/8 inch (3 millimeters) to 6 inches (150 millimeters).
User Interface Provides Central Access to Critical Information
Infor MyDay is a dynamic Web 2.0 user interface for Infor applications that provides central access to the critical information users need to excel in their daily work.
Infor
Enhancements Improve Standardization and Asset Optimization
ABB has released the latest version of its IndustrialIT cpmPlus Enterprise Connectivity (ECS).
Microfluidic Chips Save Time and Money
Cole-Parmer introduces Micronit Lab-on-Chip products for creating microfluidic experiments.
Product Type: Microfluidics
Cole Parmer
Continuous-Duty Compressors Deliver Air Without The Noise
Quincy Compressor Launches its New Xtreme Piston Compressors
Ultrasonic Flow Transmitters Eliminate the Need for Calibration
Clark Solutions has introduced the CSLFC Liquid Ultrasonic Flow Transmitter.
Energy Management Solution Also Reports on Greenhouse Gases
Schneider Electric announces the availability of Greenhouse Gas (GHG) reporting with its Square D PowerLogic ION enterprise energy management (EEM) solution.
Piston Compressors Packaged For Quiet Operation
Quincy Compressor unveils the QT-Xtreme and the PLT-Xtreme, continuous-duty reciprocating compressors with a canopy for delivering reliable shop air without all the noise.
Flowmeter Equipped with Temperature Sensor
Siemens Energy & Automation, Inc. has announced the U.S. introduction of the Sitrans FX300 vortex flowmeter series, which is equipped with a temperature sensor and an optional pressure sensor.
Three-Input Intelligent Analyzer Includes Four 4-20mA Current Outputs
To meet the need for multiple liquid measurements and lower costs per measurement loop required by industrial OEMs and other analytical customers, Emerson Process Management presents the Rosemount Analytical Model 1057 three-input intelligent analyzer.
Asset Manager Reduces Costs and Improves Uptime Through Predictive Diagnostics
Flowserve Corporation has launched the Flowserve ValveSight, an asset management solution for integrated control valves and automated quarter-turn valve packages.
Flowserve
Electronic Valve Actuator Is Designed to Enhance Safety and Reduce Downtime
Flowserve Corporation introduces the Flowserve Limitorque QX valve actuator to its family of electronic actuators
Flowserve
Purified Water Sanitation System Generates Ozone and Dissolves It into Water
MKS Instruments, Inc. has introduced the Liquozon Ultra, a clean, safe and efficient water sanitization alternative to chemical water treatment systems
NSX Analyzer Offers Improved Sample Introduction and Enhanced Oxidative ...
Thermo Fisher Scientific Inc. announces the launch of the TITAN 4000 Total Nitrogen/Sulfur/Chlorine (NSX) analyzer.
Safety System Solution Can Be Tailored To Optimize Efficiency
ABB Integrated system provides protection while it optimizes process efficiency and cost
Remote Mountable Thermal Mass Flow Meter Is Designed for Hazardous Areas and ...
The ST75 Flow Meter from Fluid Components International (FCI) is now available in a remote mountable configuration for applications in hazardous areas or hard-to-reach locations.
Leak-free PFA Fittings Are Now Stocked in Twelve Styles
Immediately available from plastic tubing manufacturer NewAge Industries is a line of PFA fluoropolymer compression fittings in a dozen styles.
Positive Displacement Pump Improves Plant Efficiency
As companies within the processing industries seek ways of improving plant efficiency in response to economic challenges, SPX Process Equipment has responded with the introduction of a Bran + Luebbe positive displacement pump, namely the ProCam Smart.
Mass Flow Meter Can Withstand Air/Gas Temperatures up to 850°F
Fluid Components International (FCI) unveils the Model ST98HT Mass Flow Meter, which can withstand air/gas temperatures up to 850°F (454°C) while providing accurate flow measurement with improved repeatability.
Smart Switches Are Pre-configured to Work Within the DeltaV Network
Emerson Process Management has unveiled a line of smart network switches specifically designed to plug and play within the DeltaV digital system network.
Ethernet Adapter Provides Remote Access
ABB SREA-01 ethernet adapter provides remote access
Explosion-proof Liquid Density Meter Does Not Require Barriers or Galvanic ...
Emerson Process Management introduces an explosion-proof/flame-proof version of its Micro Motion 7835 custody transfer density meter.
Extended Range Antenna Expands the Reach of Smart Wireless Networks
Emerson Process Management expands its Smart Wireless solutions with the release of the Extended Range Antenna
Membrane Bioreactor Supplies Irregular Pulses of Air
Siemens’ Pulsed Air MBR System Decreases Energy Usage
Transit-Time Ultrasonic Flowmeter Offers an Alternative Choice for Mag-Meter ...
Sierra Instruments introduces the Innova-Sonic In-Line Model 206 Digital Correlation Transit-Time ultrasonic flowmeter
Explosion-Proof Compressed-Air Dryers Deliver Without Electricity
Parker Hannifin’s Explosion-Proof Compressed-Air Dryers Deliver Without Electricity
Chemical Instrumentation | Gems Introduces UCL-510 Ultrasonic Continuous ...
Gems Introduces UCL-510 Ultrasonic Continuous Liquid Level Sensor
Gems Sensors & Controls
Thin Client Provides Secure, Real-time Access to Automation Systems Via Any ...
ABB releases the IndustrialIT cpmPlus Smart Client for System 800xA
Shear Pump Technology Gets The Lumps Out For Less
Quadro Launches Advanced Shear Pump Technology
Quadro Engineering Corp.
Two-Wire Coriolis Meter Provides a Solution for Loop-powered Flow Points ...
Emerson Process Management's two-wire Micro Motion Coriolis meter provides a solution for loop-powered flow points throughout the plant
Communication Interface Introduced for Coriolis Flow Transmitters
Model 2400S transmitters are now available with DeviceNet and PROFIBUS DP communications, increasing the versatility of ELITE Coriolis meters
Alarm Thermometer Offers Simultaneous Freezer and Refrigerator Monitoring
The Dickson Alarm Thermometer offers simultaneous freezer and refrigerator monitoring.
Dickson
X-ray Equipment Detects Food Contamination in Challenging Production Lines
Mettler-Toledo's AdvanChekPlus X-ray equipment detects food contamination in challenging production lines
Mettler Toledo
Cost-effective Metal Detector Introduced for Bulk Flow Products
Mettler-Toledo Safeline introduces its new cost-effective metal detector.
Mettler Toledo
Gore Products Covers a Range of Sealing and Fluid Handling Requirements
W. L. Gore offers wide range of sealing products
W.L. Gore
Two-Wire, Loop-Power Level Switch Offers Tank Monitoring and Interface Control
Fluid Components International announces the NuTec LS2000 two-wire, loop-power level switch for tank monitoring and interface control.
Flow and Liquid Level Interface Switch Receives SIL-2 Compliance Rating
Ideal for Heavy Industrial Environment & Pump Protection
Enhanced Digital Valve Controller Is SIL3 Certified
Emerson's Fisher Fieldvue DVC6000 digital valve controller is SIL3 certified
Lifecycle Support Strategy Extends and Protects Automation System Life
ABB's Evolution for Life extends, protects automation system life
Wireless Vibration Transmitter Delivers Predictive Diagnostics for Improved ...
Emerson's wireless vibration transmitter increases reliability, safety
Peristaltic Pump Offers Increased Capacity and Tighter Flow Control
Pump offers increased capacity, tighter flow control
Space-saving Flow Meter Measures Process Gas or Air Flows
FCI introduces space-saving flow meter
High-Pressure Metering Pump Covers a Wide Range of Applications
Watson-Marlow launches high-pressure metering pump
Metering Pump Offers Precise Control in Low-Flow Applications
Metering pump offers precise control in low-flow applications
Moyno
Flow Sensor Installs Without Shutdown
GF Piping System's flow sensor installs without shut-down
Membrane Air Dryers Provide Pure, Dry, Compressed Air at a Guaranteed Dewpoint
Membrane air dryers provide pure, dry compressed air at a guaranteed dewpoint
Self-cleaning Filters Prolong Component Life
Schroeder's self-cleaning filters prolong component life
Schroeder Industries
High-Temperature Bulk Powder Cooling System Features Water-cooled Tubing
High-temperature bulk powder cooling system features water-cooled tubing
Bulkflow Technologies
Mass Flow Meter Features an Advanced “U” Tube Flow Sensor Design
With an advanced “U” tube flow sensor design, the new Model CMU Coriolis Mass Flow Meter from Fluid Components International now delivers more than twice the industry standard flow rate than previously available to set a new benchmark when compared to other coriolis devices in its class.
Peristaltic Pumps Are Designed for the Metering, Dosing and Transferring of ...
Watson-Marlow Bredel introduced its 520/620/720 family of peristaltic pumps are designed for the accurate metering, dosing and transferring of sensitive fluids in sanitary environments, making them ideal for accurate filtration, fermentation, dispensing, coating and seamless integration into ...
FCI releases coriolis flow meter for harsh acidic, caustic fludids
Flowserve Corp.
Flowserve Corp. launched the Flowserve Logix 3400IQ Foundation Fieldbus digital valve positioner. The 3400IQ features a new FISCO-compliant user interface board, improved potentiometer, piezoelectric technology, and host interoperability to provide operating versatility and fast, easy and ...
Flowserve
A new design of thermocouple assembly from the Partek division of Parker Hannifin provides a reliable temperature monitoring sensor for high-purity fluid systems that traditionally use fluoropolymer components.
Blackmer
Blackmer, a supplier of positive displacement rotary vane, eccentric disc, peristaltic hose and centrifugal pump technologies, announced the addition of the SX3 Series to its line of stainless steel sliding vane pumps.
Blackmer
ABB Group
ABB introduced the reported world's first field-mountable videographic data recorder. ABB's SM500F is a four-channel recorder that takes recording and monitoring out of the control room and offers users localized access to operational data wherever the process may be.
Emerson Process Management launched its in-plant Smart Wireless solutions that enable manufacturers to boost mainstream applications to the next level of reliability and operational performance.
Flow Technology, Inc.
Flow Technology, Inc. announced the release of its Model SLF-500 ultrasonic liquid flow meter.
Flowserve
Phoenix Contact
Phoenix Contact introduces two embedded controller platforms, the S-MAX 50xx VLC and ILC 350 VLC. The products provide powerful control features and easy Steeplechase VLC flow-chart programming for low-cost control applications.
Phoenix Contact
FCI
FCI introduces wireless air/gas flow meter
Accsense
Flowserve
Flowserve introduces its smallest pump yet
Flowserve
Fluid Handling | Micro Motion | Chemical Processing
Micro Motion offers intergral transmitter for ELITE coriolis flowmeter
Micro Motion
Rosemount introduces multi-variable transmitter
GF Piping offers paddlewheel flowmeter line
Athena Controls
Athena Controls offers thermocouple assemblies for both high and low temperature applications
Stedman
McCrometer
McCrometer
Adalet Wireless
Symbion Systems
Orange Research
Wonderware
Raytek
Diamondback Technology
Diamondback Technology plate hopper promises hangup-free flow
ChemFlux
Adalet Wireless
Rotex
Dow Corning
Bionomic
Seepex
GE Fanuc
Watlow
Comsol
Supercritical Fluid Technologies
Watlow
temperature controller
ABM Sensor Technology
ASI Instruments
Kin-Tek Laboratories
Avery Dennison
Goulds Pumps
Ametek
George Fischer
Drexelbrook
Parker Hannifin
The new MaxGuard high capacity cartridge product line from the Parker Process Filtration Division provides a cost-effective alternative to bag media or standard 2.5-inch cartridges for high flow applications.
ITT industries
An innovative dual-stage membrane bioreactor (MBR) for advanced treatment of industrial wastewater delivers a higher quality effluent in less space and with lower operating costs than are normally associated with conventional activated sludge processing system.
Moyno
Russell Finex
General Monitors
Scientific Technologies
Scientific Technologies, Inc., Automation Products Group introduces NLS Pneumatic Level Sensors. Featuring a minimum number of moving parts, these cost-effective sensors are designed for operational reliability and long life.
Dresser-Rand
Dresser-Rand is offering a new line of single-stage steam turbines, providing API application clients and general industry markets with a rugged and versatile low-horsepower turbine, designed to be equally suited for new or retrofit applications.
Phoenix Contact
As an enhancement to its point-to-point two-way wireless device (RAD-ISM-900-BD-BUS) for analog and digital signals, Phoenix Contact Inc. now offers the RAD-ISM-900-XD-BUS, a bi-directional multipoint-to-point wireless I/O system.
Danaher
Superior Electric XCE Series Hazardous Duty Synchronous Motors from Danaher Motion now satisfy ATEX standards for use in potentially explosive atmospheres as defined by CE directive 94/9/EC.
GE Fanuc Automation
GE Fanuc Automation Americas, Inc., a unit of GE Infrastructure, has announced the new Proficy(tm) Change Management Version 5.0 - a major new version of the company's plant-wide advanced automation management and control software - which allows users to increase productivity, quality, security ...
George Fischer
George Fischer, Inc. has introduced the economical H2O Type 374 Valve designed specifically to provide superior performance in water applications. NSF 61 certified for potable water applications, the new true union valve offers a number of safety and convenience features in a compact size that ...
Gems Sensors
The PS41 Series of pressure switches, now available from Gems Sensors, incorporates two design principles to achieve excellent performance characteristics. PS41 switches utilize an internal piston to allow high proof pressure, while gaining sensitivity and accuracy from a diaphragm media interface.
Adalet Wireless
Adalet Wireless now offers a multi-channel wireless base radio solution as part of their industrial wireless product offering. Designed for installations requiring multiple field transmission points, the Adalet Wireless multi-channel system allows up to sixty field transmitters to communicate ...
Tarby
Tarby has launched a new line of replacement parts and pumps that are interchangeable with the seepex BN series. This new general purpose industrial pump, the Titan C22 progressing cavity (PC) pump, is designed as a drop-in replacement for seepex BN series pumps and all internal components are ...
TechniKrom, Inc.
TechniKrom, Inc. has announced a new line of Bioprocess LC system upgrades. It is now possible to take any existing chromatography skid and upgrade it using TechniKrom's patent pending Adaptive PAT technology.
Woodhead Industries Inc.
Danaher Industrial Controls Group
Accutech
Noveon IP Holdings Corp.
TAH Industries Inc.
Woodward Industrial Controls
Fauske & Associates
Burkert
The Hilliard Corporation
2017
An index to the latest chemical processing products.
2010
