Displaying 1-744 of 744 results
Wireless Steam Trap Monitor Eliminates Cabling
Spirax Sarco released STAPS Wireless, a wireless steam trap monitor designed to deliver accurate wireless monitoring and reporting of steam trap performance, without the need to install cabling.
Industrial Valve Enhances Fluid Control In Corrosive Environments
Flowrox launched the SKW (Slurry Knife Wafer) valve – a slurry knife gate product designed to enhance current pipeline equipment and processes using enhanced technology for fluid control.
High-Capacity Trickle Valve Improves Dust Collection
Aerodyne Environmental introduced the 10-inch Vacu-Valve Trickle Valve System, a constant discharge valve for dust collectors, hoppers, cyclones and other equipment operating under negative pressure.
Aerodyne
Cashco Introduces SLR-1/SLR-2 Self-Loading Regulator Valves
Cashco, Inc. updated and improved its SLR-1 and SLR-2 self-loading regulator valves.
Cashco
Emerson Introduces Rosemount 5708 Series 3D Solids Scanners
Emerson Process Management introduced the Rosemount 5708 Series of 3D Solids Scanners for the continuous measurement of level, volume and mass of bulk solids and powders in large vessels, bins and silos.
Product Type: Weighing
Siemens Introduces Integral Volume Booster
Siemens Industry introduced an Integral Volume Booster accessory for the Sipart PS2 electro-pneumatic valve positioner, designed for pneumatic actuators that require high flow for fast stroking times.
Armstrong Introduces Python 1500 Series Control Valve
Armstrong International expanded its line of pressure and temperature control products with the launch of Python 1500 series globe style control valve.
ProComSol Introduces Smart Device Communicator App
ProComSol, Ltd. released the Android based Smart Device Communicator application for HART instruments.
ProComSol, Ltd.
Pumps Offer Low Flow, Accurate Dosing
Moyno introduced a new range of dosing pumps for applications where low flow, accurate dosing is required.
Moyno
Heinkel Introduces Condry Cone Central Shaft Dryer
Heinkel introduced the Condry Cone Central Shaft Dryer.
Heinkel
Emerson Introduces CSI 9360 Vibration Transmitter
Emerson Process Management’s new CSI 9360 vibration/transmitter offers users and manufacturers an economical solution for extending basic protection to compressor, pump and fan assets.
ITT Launches Pure-Flo EnviZion Diaphragm Valves
ITT launched a line of hygienic diaphragm valves designed to reduce maintenance time and cost of ownership for BioPharm manufacturing facilities.
BelGAS Introduces Type 52SS NACE-Compliant Regulators
BelGAS introduced the Type 52SS, a family of NACE-compliant, stainless steel gas pressure regulators and filters.
Bonomi Introduces Valpres Series Ball Valves
Bonomi North America introduced wafer stainless steel, full-port ball valves, a flow-enhancing alternative to high-performance butterfly valves in OEM applications, skid-mounted systems or any tightly-confined area.
Alfa Laval Launches Screw Press
Alfa Laval launched a compact screw press featuring low power consumption.
Allegro Introduces Point-Of-Attachment Cooling System
Allegro Industries introduced the portable Point-of-Attachment Cooling System.
Allegro Industries
Spirax Sarco Introduces SX80/SX90 Controllers
Spirax Sarco introduced the SX80 and SX90 controllers.
Festo Introduces CMSX Closed Loop Position Controller
Festo introduced CMSX closed loop position controllers for quarter turn actuators.
Festo Corporation
Marsh Bellofram Introduces Type T289 Regulator
Marsh Bellofram introduced the Type 289 industrial gas back pressure regulator.
HiP Introduces Medium Pressure Line 1-1/2-Inch Fittings
High Pressure Equipment Company (HiP) expanded its medium pressure line with the addition of a 1-1/2" OD line of fittings, couplings, tubing and nipples that accommodate pressures up to 15,000 psi.
Ross Introduces Dual-Shaft Mixers
Ross Dual-Shaft Mixers enable efficient powder dispersion and batch temperature control for manufacturing low to high viscosity formulations.
Charles Ross & Son Company
FMI Introduces CeramPump QDX Hazardous Duty Metering Pump
Fluid Metering, Inc. introduced the valveless QDX metering pump for small and mid-size treatment facilities.
Clark Introduces MG200 Magnetic Drive Gear Pumps
Clark Solutions introduced MG200 Magnetic Drive Gear Pumps.
Alicat Releases Rechargeable Portable Mass Flow Meters
Alicat Scientific released rechargeable, portable gas mass flow meters.
Alicat Scientific Inc.
Garlock Introduces Style 5882 Valve Stem Packing
Garlock released Garlock Style 5882 low-friction valve stem packing materials.
Garlock Sealing Technologies
Watson-Marlow Introduces Qdos 60 Pump
Watson-Marlow Pumps Group introduced the Qdos 60, a larger version of the Qdos 30 peristaltic metering pump.
Yokogawa Introduces Enhanced YS1000 Controllers
Yokogawa enhanced its YS1000 series single loop controllers.
Meyer Introduces Universal Duty Valves
Meyer introduces Universal Duty Valves.
WM. W. Meyer & Sons Inc.
Cashco Introduces B7 Back Pressure Relief Regulator
Cashco introduced the B7 High Flow/High-Sensitivity Back Pressure Relief Regulator.
Cashco
seepex Introduces ALPHA Chemical Metering Systems
seepex introduced a new series of standard ALPHA chemical metering systems designed for simple plug-and-play installations.
seepex
Crane Launches Pacific Forged Valves
Crane ChemPharma & Energy launched the Pacific Forged line of valves.
Software Monitors Model Predictive Controls
Metso ExperTune PlantTriage software now includes model predictive control (MPC) monitoring.
Metso
CamFil Introduces Stinger Explosion Isolation Valve
CamFil introduces Stinger explosion isolation valve.
Pressure Reactor is Fully Automated
Syrris introduces Atlas Potassium Pressure System.
Product Type: Reactors
Syrris
Bellows Seal Designed For Valve Applications
Senior Operations introduces high-pressure bellows seal.
Senior Operations LLC Metal Bellows
Double Flange Slide Gate Valve Announced
Kemutec announces Mucon DSV Double Flange Slide Gate Valve.
Product Type: Seals & Packing
Kemutec
Rotary Airlock Feeder Is USDA Approved
Meyer introduces Klean-In-Place II Rotary Airlock Feeder.
Liquid Expansion Trap Provides Freeze Protection
Compact trap offers last line of defense against pipe freezing.
Product Type: Replacement components and materials
Miniature Pumps Designed for Applications Having High Humidity or Potentially...
Clark Solutions introduces CU15 Series Miniature Air Operated Diaphragm Pumps.
Stainless Steel Quick Couplings Are Non-Spill and High-Flow
Coupling series offers contamination-free transfer, fill and dispensing of DEF and other chemicals.
Acrylic Flow Meters Feature Interchangeable Direct Reading Scales
Scales offered for water, argon, oxygen, carbon dioxide, nitrogen and helium
Dakota Instruments, Inc.
New Tantalum Heat Exchangers for Highly Corrosive Applications
Alfa Laval Introduces New Tantalum Range
Software Reduces Fieldbus Device Commissioning Time Up to 80 Percent
Emerson Updates Asset Management Software
Sliding Motor Base Automatically Maintains Belt Tension
Emerson Introduces Browning Tenso-Set Auto-Tensioning Motor Base
Fittings Make Press Connections Between Copper and PEX Systems
Viega Transition Fittings Make Press Connections Between Copper and PEX Systems
Viega
Leak Diverter Kit Catches Nuisance Leaks Quickly
New Pig Launches Pig Spring-Open Roof Leak Diverter Kit
Product Type: Adhesives, sealants & chemicals
New Pig Corp.
Sanitary Butterfly Valve Meets FDA and USDA Standards
Valtorc Introduces Series 535-SN Sanitary Butterfly Valves
Valtorc
Control Valve Handles Energy and Hydrocarbon Processes
Metso Expands Neles Control Valve Line
Metso
Rounded Blade Gate Handles Abrasive Materials
Vortex Adds Rounded Blade Gate to Titan Series Valves
Vortex Valves
Vacuum Receiver Features Clamp-Together Design for Tool-Free Disassembly
Flexicon Launches Vacuum Receiver With Pneumatic Dump Valve
Product Type: Vacuum
Touchscreen Controller Handles All Functions of Industrial Dust Collectors
Camfil Air Pollution Control Launches Touchscreen Controller
Direct-Insertion Density Meters Handle Demanding Process Applications
Emerson Introduces Direct-Insertion Density and Concentration Meter
Vortex Valves Adds Rounded Blade Gate to Titan Series
Vortex Valves
Double Valve Includes Integrated Soft-Start Function
Ross Controls Announces M Dm2 Series C Double Valve
Ball Valves Are Suitable for Use in Potable-Water Applications
Viega Launches ProPress Zero Lead Ball Valves
Viega
Differential Pressure Switch Handles Room Pressure Monitoring
.Clark Solutions Launches Series 605 Differential Pressure Switch
Vibrating Fork Level Switch Provides Overfill Protection in Remote Tank ...
Emerson Introduces Rosemount 12V DC Vibrating Fork Level Switch
Electric Actuated Ball Valves Include NEMA 4X Enclosures
Clark Solutions Launches 8E Series Electric-Actuated Ball Valves
Chlorine Dioxide Analyzer Measures Residual Chlorine Dioxide Levels
GF Piping Systems Introduces Disinfectant Monitoring
Hydraulic Pressure Comparator and Pressure Gauge Include Leak-Free Crystal ...
Ametek Crystal Engineering Launches GaugeCalHP Pressure Comparator and XP2i Pressure Gauge
Universal Duty Valves are Suitable for Pollution-Control Applications
Wm. W. Meyer & Sons Launches UDV-Universal Duty Valves for Material Metering
Pressure Gas Regulator is Available in Five Body Sizes
Cashco Unveils PGR-1 Pressure Gas Regulator
Cashco
Valve Oven Ensures Purity of Fuel Products
Agilent Technologies Introduces New External Valve Oven for Gas Chromatograph
Control Valve Complies with ISO 15848 Fugitive Emissions Requirements
Flowserve Announces New Valtek GS and Logix 420 Control Valve System
Flowserve
Tubular Cable Conveyers Transfer Friable Materials
Flexicon Launches FLEXI-DISC 6-Inch Tubular Cable Conveyor
Dual-Valve Mass Flow Controllers Manage Flow Into and Out of a Process
Alicat Develops First Bidirectional Flow and Pressure Controller
Electric Linear Actuators Controls Steam Without Compressed Air
Spirax Sarco Introduces AEL6 Smart Electric Linear Actuators
Combustible Gas Leak Detector Finds Leaks in Industrial Systems
Spectronics Launches PRO-Chek CG Combustible Gas Leak Detector
Spectronics Corp.
Sludge Dewatering Optimizer Handles Industrial Wastewater Treatment
Metso Launches Advanced Optimizing Solution for Sludge Dewatering
Metso
Directed Combustible Dust Explosion Pressure Venting Protects Plant Workers
Rembe Launches TARGO-VENT Combustible Dust Explosion Pressure Venting
Tank-Cleaning Machine Minimizes Physical Effort During Clean-in-Place
Gamajet Launches Aseptic 8 Tank Cleaning Machine
TPE Diaphragms Designed to Reduce Installation Time
Wilden Offers Complete Line of EZ-Install TPE Diaphragms
Flameless Indoor Venting System Helps Reduce Combustible Dust Explosion Risks
Rembe Launches Q-Rohr Indoor Flameless Venting System
Pump System Includes Auto-Fill Option When Flooded Suction is Unavailable
Walchem Introduces Walchem Pump System in Four Configurations
Walchem
Rotary Airlock Valves Feature Tool-Less Access to the Rotor
ACS Drives Launches Rotary Airlock Valves With ACS RotorRail
ACS Valves
Electric Actuator Includes Valve Adaptor to Speed Installation
Spirax Sarco Offers New AEL5 Electric Actuator Range
Optical Dissolved Oxygen Sensor Offers Expanded Communication Capabilities
GE Piping Systems Launches Signet 2610-41 Dissolved Oxygen Sensor
Asset Health Technology Integrates With Latest Reliability Tools
Emerson Releases AMS Suite: Machinery Health Manager v5.6
Nuclear Pressure Transmitters Meet Latest Qualification Standards
Emerson Introduces New Series of Nuclear Pressure Transmitters
Air-Cooled Heat Exchanger Monitoring Solution Features Wireless Plug-and-Play...
Emerson Releases Wireless Air-Cooled Heat Exchanger Monitoring Solution
Solenoid Valves Offer Improved SCADA System Drop-Out Current Performance
ASCO Introduces New Products at Emerson Global Users Exchange 2013
ASCO
Plants Can Save Up to $450,000 Annually With On-Line Monitoring of Cooling ...
Emerson Launches Cooling Tower Monitoring Solution
Gas-Specific Gravity Meter Directly Measures Modular Weight
Emerson Releases Micro Motion Specific Gravity Meter
New Pump Hoses for Food Applications Offer Enhanced Wear Resistance
Watson-Marlow Pumps Group Launches Food-Grade Hose for Use With Bredel Pumps
Rotary Valve Features High-Capacity Rotor Design
ACS Valves Introduces New SD Series of Rotary Valves
ACS Valves
Pleated Cartridges Extend Service Life
High flow surface area and particulate holding capacity help prolong service life.
Gauge Expands Psi-Test Capabilities
The XP2i pressure test gauge now comes in a 15,000-psi version.
Crystal Engineering
Backflush Screen Changers Meet Direct Recycling Demands
Maag Presents CSC-BFX Backflush Screen Changer
Maag
Dispensing System Provides Valveless Micro-Volume Fluid Control for Catheter ...
Fluid Metering Introduces PDS-100 Valveless Micro-Volume Fluid Control
Flow Monitor Features Various Enclosure Options for Liquid and Gas Applications
Badger Meter Introduces ER-500 Flow Monitor
ASME Pressure Vessel Handles up to 15,000 Gallons
Ross Engineering Offers ASME Pressure Vessels
Predictive Diagnostics Suite Available on Any Foundation Fieldbus System
Emerson's AMS Suite Available on any Foundation Fieldbus System
Semi-Automatic Valve Manifold Boxes Feature Rail-Mounted Stick Design
Semi-Gas Systems Simplifies Gas Distribution with Semi-Automatic Valve Manifold Box
Semi-Gas Systems
Leak Diverter Kit Quickly Catches Nuisance Leaks
New Pig Introduces Quick Deploy Leak Diverter Kit
New Pig Corp.
Digital Valve Controller’s Stainless Steel Housing Prevents Corrosion
Emerson Introduces Fisher Fieldvue DVC6200 Digital Valve Controller
Non-Contacting Level Transmitter is Suitable for Harsh Environments
Emerson Expands Rosemount 3100 Measurement Capabilities
Three-Way PTFE Ball Valve Targets Corrosive and Ultra-Pure Fluid Applications
Aalborg Introduces Three-Way PTFE Ball Valve
Flow Meters Measure Air and Gas
These insertion and inline mass thermal flow meters measure clean, dry gases and air using constant temperature sensing for fast response and low flow accuracy.
Transmitter Monitors Remote Locations
The Rosemount 3308 wireless guided wave radar transmitter provides accurate level monitoring for remote or difficult-to-reach locations where installing new cabling would be costly or impractical.
Controller Improves Inline Blending
Controller monitors up to five separate blending lines.
West Control Solutions
Shelters Protect Against Hydrocarbon Fires
The 1709 model fire-resistant shelters are designed to protect critical safety equipment from exposure to high-temperature fires in hazardous areas.
Intertec Instrumentation Inc.
Pinch Valve Comes With Sleeve Liner
Schubert & Salzer Launches 7078 Pinch Valve
Schubert & Salzer Control Systems
BTU Meter/Energy Meter Suitable for Energy Transfer and Heating/Cooling Systems
Clark Industries Introduces CS-EM BTU Meter/Energy Meter
High-Shear Mixers are Suitable for Frequent Formulation Changeovers
Charles Ross & Son Offers Inline High-Shear Mixers
Steam Trap Handles High-Pressure Drips and Light Process Applications
TLV Corp. Launches P65SRN PowerDyne Trap
Hazardous Location Relay Module Powers Actuators in Hazardous Locations
Wago Introduces Hazardous Location Relay Module
Product Type: Module
Wago
Rotary Airlock Feeder Includes Redesigned Two-Slide Bar Supports for Easy ...
Mini Peristaltic Pump Features Continuous-Duty 24 VDC Gear Motor
Aalborg Introduces TPT Mini Peristaltic Pump
Acrylic Flow Meter Includes Newly Designed Multi-Turn Valve
Aalborg Offers Built-In Needle Valve Option for Acrylic Flow Meters
Steam Traps Now Available in ASTM A182 F91 Material
TLV Releases New Material and Connection Options for HR150A and HR260A Steam Traps
Dust Collector Now Available in Skid Package for Easier Installation
Camfil Air Pollution Control Introduces Farr Gold Series Dust Collector
Slide Gate Valve Includes Self-Compensating Polymer Seal
Kemutec Introduces New Mucon Slide Gate Valve
Kemutec
2013
Smart Valve Positioners Help Processing Facilities Comply with Emissions ...
Badger Meter Introduces SRD Smart Valve Positioners
Heat-Shrink Tubing Protects Irregular Shaped Objects
Parker Hannifin Introduces TexLoc PTFE 4:1 Heat Shrink
New Trickle Valve System Can Withstand Temperatures of up to 500° F
Aerodyne Announces High Temperature Vacu-Valve
Aerodyne
Motorized Valve Actuator Achieves High Control Accuracy
Schubert & Salzer Introduces 2030 Series Motorized Actuator
Mobile Diagnostics Now Available for Fieldbus Network Control Valves
Emerson Offers Mobile Diagnostics for Foundation Fieldbus Network Control Valves
Lockout Valves Available in Body and Port Sizes
Parker Expands Offering for Pneumatic Lockout Valves
Pump Provides Linear, Repeatable Flow Performance
Watson-Marlow Launches ‘Qdos’ Range for Chemical Metering Applications
Parker Hannifin Introduces TexLoc PTFE 4:1 Heat Shrink Tubing
Flow Meter Measures Wide Flow Ranges
Badger Meter Expands Industrial Oval Gear Flow Meter Line
Double Flapgate Valve Operates in Temperatures Up to 750 Degrees Fahrenheit
Meyer & Sons Introduces Meyer Monster Double Flapgate Valve
Magnetic Drive Gear Pump Handles High-Tech, Medical and Cooling Systems ...
MG200 Gear Pumps from Clark Solutions Feature Pulsation-Free Operation
Conveyor Moves Fragile Food Products
Flexicon Introduces Flexi-Disc Tubular Cable Conveyors
Blower Health Monitoring Solution Mitigates Failure Threats
Emerson Introduces Blower Health Monitoring Solution
ATEX-IECx-Certified Inductive Sensors Handle Explosive Environments
Steute Xtreme Releases New Line of ATEX-IECx-Certified Inductive Sensors
Steute Xtreme
Control Applications Boost Usability of DNA Automation System
Metso Introduces New Applications for DNA Automation System
Metso
Piston Trap Station Minimizes Installation Area
TLV Corp. Launches V1P Piston Trap Station
Safety Relief Valve Handles Liquid, Steam, Air and Gas Services
Spirax Sarco Launches SV418 Bronze Safety Relief Valve
Tank-Cleaning Machine Removes Residues From Large Process Tanks
Gamajet Introduces EZ-8 Tank-Cleaning Machine
Product Type: Tanks and vessels
Multi-Gun Operates at Pressures Up to 24,000 PSI
NLB Introduces 24,000 PSI Multi-Gun Valve
NLB Corp.
Electronic Control Package Compatible With L120 Series Actuators
Flowserve Launches UEX Electronic Control Module for L120 Electric Actuators
Flowserve
Flow Meters are Available in Nine Line Sizes
Emerson Expands Line of Micro Motion Elite Series Coriolis Flow Meters
Forged Manifolds Include Built-In Piston Valve
TLV Corp. Releases MP-Series Piston Manifolds
Flow Meter Includes Compact Stem Accessory
Spirax Sarco Releases Gilflo ILVA Flow Meter with Compact Stem Accessory
Slide Gate Valve Features Dust-Tight Seal
Kemutec Introduces Mucon Slide Gate Valve
Kemutec
Slide Gate Valve Includes Unobstructed Full Bore Opening to Eliminate Jams
Kemutec Launches New Mucon Slide Gate Valve
Kemutec
Pump Heads Include Adjustable Features for User Flexibility
Aalborg Introduces TPU1 and TPU2 Pump Heads
Flow Meter Features Compact Wafer Design
Spirax Sarco Offers the Gilflo ILVA Flow Meter
Ejector Technology Available as Integrated Platform
Piab Offers COAX Technology in Integrated piCHIP Platform
Jacketed Tube Connector Eliminates Sleeves and Sealing Tape
Swagelok Launches Jacketed Tube Connector
Peristaltic Pump Line Handles Repeatable Liquid Transfer Applications
Aalborg Introduces TP Peristaltic Pump Line
Qdos Pump Range Features ReNu Pump Head Technology
Spill Kit in Cabinet Includes Lockable Drawers
New PIG Introduces PIG Spill Kit in a Cabinet
New Pig Corp.
Remote-Mount Digital Valve Controller Handles Extreme Temperatures
Emerson Introduces Remote-Mount Digital Valve Controller
Direct Bulk Flow Meter Handles Applications in Tight Spaces
Rembe Introduces C-LEVER Direct Bulk Flow Meter
Balancing Valve Maintains Set Flow Rate During Pressure Fluctuations
Bell & Gossett Introduces The Circuit Sentry Flo-Setter
Bell & Gossett
Ribbon Blender Features Clamps to Eliminate Dusting
Charles Ross & Son Introduces 42B Model Ribbon Blenders
Air Filter/Regulators Prevent Dirty Compressed Air from Impacting AODD Pump ...
Sandpiper Launches Line of Air Filter/Regulators and Lubricators
Warren Rupp
Low-Profile Pneumatic Conveyor Handles Pharmaceutical Applications
Volkmann Introduces Low-Profile Pneumatic Pharmaceutical Conveyors
New Instrumentation Valves are Available in Various Sizes and PSI Ratings
Brennan Industries Introduces New Selection of Instrumentation Valves
Brennan Industries
Flanged Valves Include OSHA Lock Out/Tag Out
SVF Flow Controls Introduces B41 Flanged Ball Valves
SVF Flow Controls
Pressure Transducer Used in High-Purity Applications Receives IECEx ...
Brooks Instrument’s SolidSense II Pressure Transducers Receive IECEx Rating
Air/Gas Flow Meter Reduces Energy Consumption
Fluid Components Launches ST75 Air/Gas Flow Meter
Combined Pump and Trap Removes Condensate
TLV Corp. Offers GT5C PowerTrap Pump and Trap
Filter Regulator Lube Packs Reduce Valve Operation Hazards
Smith Flow Control Launches Regulator Packs to Ensure Safe Operation of Valves
Smith Flow Control
Explosion Vent Provides Non-Fragmenting Opening
Fike Launches Rectangular CV-S Explosion Vent
Fike
SIL-Certified Valve Assembly Offers ‘Two Out of Three’ Protection
Norgren Introduces Redundant Valve Manifold
Norgren
Clean Steam Separator Features Enhanced Surface Finish
Spirax Sarco Launches CS10 Clean Steam Separator
Differential Pressure Transducer Features High-Line Pressure Design
AST Introduces New Differential Pressure Transducer
Product Type: Transducer
American Sensor Technologies
Asset Management Software Continuously Monitors Critical Systems
Emerson Integrates Industrial Uninterruptible Power Supplies With AMS
Catalog Features a Variety of Tube Fittings
CPV Manufacturing Catalog for Mark VIII O-SEAL Tube Fittings
CPV Manufacturing
Explosion Isolation Valve Prevents Spread of Flames
Rembe Adds the Ventex Passive Isolation Valve to its Product Offerings
Temperature Control Trap Suits Low-Temperature Heating Applications
TLV Introduces LEX3N-TZ Temperature Control Trap
Steam Trap Reduces Copper-Oxide Blockages
TLV Releases P21S PowerDyne Steam Trap
Thermoplastic Double Wall Piping System Meets EPA Requirements
Asahi/America Introduces Chem Prolok PE Double Wall Piping System
Asahi/America, Inc.
Valves Switch up to Four Times Faster With Pneumatic Volume Booster
Schubert & Salzer Offers 4090 Pneumatic Volume Booster for Faster Valve Switching
Batch Processing Controller Automates Dosing and Dispensing Procedures
Scaletron Introduces Corrosion-Resistant Scales
Scaletron Industries
Tank Blanketing Valve Maintains Non-Combustible Environment
Burling Valve Introduces Pressure Regulator for Blanketing Applications
Burling Valve Company
Compact Actuator Handles Heavy-Duty Service and Tight Spaces
Biffi Italia Launches Pneumatic Actuator Series
Biffi Italia
Wafer Check Valve Now Available in Additional Sizes
Ashi/America Expands PVC Wafer Check Valve Line
Asahi/America
Device Isolates Explosion Pressure
Rembe Inc. Introduces New Q-Flap Compact Inlet Isolation Devices
See-Through Container Enables Fast Hazmat Inspections
New Pig Corporation Launches Hazmat Spill Kit
New Pig Corp.
Wireless System Monitors Valves
Westlock Introduces Wireless Valve Monitoring System
Product Type: Hazard analysis
Westlock
Pump Scales to Suit Process Changes
Bredel APEX Hose Pump Handle Corrosive Fluids
System Eases Remote Valve Testing
Netherlocks Offers FAITH Partial Stroke Test System
Netherlocks
Bag Filters Enable Quick Removal
Hayward Flow Control Introduces FLV Series Bag Filters
Product Type: Strainers
Cabinets Extend Safe Shutdown
Intertec Cabinets Protect Against Temperature Fires
Hose Pump Offers Maximum Flow Of 440 GPM
Flowrox Launches LPP-T4 Hose Pump
Transmitter System Provides Users With Several Sensor Options
Pendotech Offers PressureMAT Transmitter System
Pendotech
Sealed Globe Valves Provide Fugitive Emissions Protection
Crane ChemPharma Offers WTA Bellows Sealed Globe Valves
Crane ChemPharma Flow Solutions
Ball Valve Provides Pressure Up To 600 PSI
Dwyer Introduces UBV Uni-Flange Ball Valve
Replacement Cartridges For Ball Valves Help Reduce Waste
Colonial Engineering Offers Replacement Cartridges For True Union Ball Valves
Steam Trap Station Includes Stainless-Steel Relief Valves
Flowserve Introduces New Gestra Products For Boiler Controls
Flowserve
Nonconductive Thermoplastic Hose Designed To Withstand Harsh Environments
Parker Hannifin Introduces New 518D Hose
IML Lock Ensures Valves Are Set In Failsafe Position
Smith Flow Control Introduces IML Lock
Smith Flow Control
Wireless Position Monitor Features On/Off Control For Discrete Valves
Emerson Introduces Wireless Position Monitor
Wireless System Provides Instant Plant Maintenance Data
Emerson Releases Mobile Worker Wireless System
Process Automation System Includes Expanded Electronic Marshalling Feature
Emerson Releases New DeltaV Process Automation System
Pipe Clamp Sensor Measures Temperature Without Intrusion
Emerson Introduces Nonintrusive Pipe Clamp Sensor
Temperature Transmitter Offers Users Modular Design
Emerson Enhances Rosemount 644 Transmitter
Metering Ball Valve Provides Flow Control For Various Chemical Processes
GF Piping Systems Offers New Metering Ball Valve
Pressing Technology Handles Black Iron Oil And Gas Applications
Viega Provides MegaPress System For Black Iron Pipe Installation
Viega
Vibration Analyzer Monitors Machine Conditions In Hazardous Environments
Emerson Introduces CSI 2125-IS Intrinsically Safe Vibration Analyzer
110-Gallon Vacuum Handles Big Cleanup Jobs
EXAIR Introduces New Chip Vac
Water Heater Offers Instant Temperature Control
Spirax Sarco Launches RediHeat Instantaneous Water Heater
Vacuum Conveyors Feature Receiver-Mounted EPV
Volkmann Introduces Electric Pump Options
Loader Conveys Powders In Sanitary Applications
K-Tron Introduces Venturi Loader
K-Tron
Valve Model Generator Performs Automatic Assembly
Metso Offers RapidDraw3D Valve Model Generator
Metso
Leak Detection Service Focuses On Valve Seats
Emerson Offers Valve Seat Leak Detection Services
Tank Weighing System Measures Air
Non-contact Weighing System Allows for More Consistent Weight Measurement
Float Trap Resists Corrosion
TLV Launches J3S-X Float Trap
Regulators Reduce Media Leakage
Rotork Fairchild Unveils High-Pressure Regulator Line
Metering Ball Valve Controls Flow
New design features V-notch ball with 180-degree turn rotation capability.
Software Delivers Advanced Plot Capabilities
Emerson Launches Machinery Health Manager v5.5
Pumps Include No Seals Or Valves
Watson-Marlow Launches Qdos Pump Range
Steam Trap Resists Corrosion
Replaceable module enables service without removing the trap body.
Trim Reduces Noise Levels
Metso Introduces Neles Q2-Trim
Metso
Transmitter Withstands Harsh Environments
Emerson Releases Stainless Steel Micro Motion Transmitters
Pumps Feature Reverse Vane Impeller
Flowserve Unveils Durco Mark 3 ISO Pumps
Flowserve
Diagnostics Wizard Extracts DCS Configuration
Real-time information is accessed for controller modes, set points, and process variables.
ExperTune
Hose Pumps Handle Corrosive Fluids
Watson-Marlow Bredel Releases Apex Range Pump Line
Flowmeter Features Built-In Computer
Spirax Sarco Unveils VLM10 Inline Vortex Flowmeter
Level Switch Fits NPT Coupling
SOR Introduces 1540 Level Switch
Analyzer Measures Oxygen In Flue Gases
Emerson Launches Rosemount 6888 O2 Analyzer
Rupture Disc Products Handle High Pressures
Continental Disc Enhances HPX Line
Continental Disc Corporation
Valve Position Monitors Provide cCSAus Certification
K Controls Introduces Two Valve Position Monitors
Pressure Regulators Offer Performance Boost
Witt Boosts Performance On Pressure Regulators
Controllers Handle Liquid Transport
Emerson Enhances DL8000 Preset Controller
Ball Valve Features Three-Piece Design
Viega Propress Introduces Three-Piece Ball Valve
Converter Adds Digital Precision To Analog Flowmeters
Aalborg Instruments Launches TIO Totalizer
Powder Delivery System Mixes Pharmaceutical Ingredients
Millipore Launches Mobius MIX 1000
Valves And Manifolds Handle Natural Gas Transmission
Parker Hannifin Introduces New Hand Valves And Manifolds
Sensors Measure Ammonium Activity
ECD Launches MVS10/MVS17 Ammonium pIon Sensors
Flowmeters Integrate Ethernet Module
Emerson Unveils Ethernet Module For Coriolis Flowmeter
Dump Station Handles Powders And Fines
Volkmann Introduces RNT-CON Dump Station
Reducing Valve Includes Air Service Capability
TLV Introduces DR20 With Air System Capability
Transmitters Offer Single-Channel Interface
GF Piping Unveils Signet 9900 SmartPro Transmitters
Strainers Feature Brass Construction
Dwyer Instruments Introduces BYS Brass Y-Strainers
Conical Strainers Remove Course Debris
Spirax Sarco Launches TP Conical Temporary Strainers
Discharging System Safely Inverts Material Drums
Material Transfer & Storage Offers Dust-Tight Drum Discharging System
Mass Flow Controller Offers Configurable Platform
Brooks Launches GF40/GF80 Thermal MFCs
Industrial Vacuum Handles High-Volume Material Recovery
Vac-U-Max Releases 1020 Industrial Vacuum
VAC-U-MAX
Vacuum Pump Filters Include Replaceable Elements
Parker Hannifin Expands Balston Line of Vacuum Pump Filters
Block Manifold Withstands Repeated Opening And Closing
Dwyer Unveils BBV-1 Three-Valve Block Manifold
Valve Manifold Adapts To Most Pneumatic Applications
Festo Releases MPA-L Valve Manifold
Festo Corporation
Control Booths Limit Impact Of Noise And Dirt
Tri-Mer Introduces Environmental Control Booths
Rotary Airlock Valves Enable Access To Internal Housing
ACS Adds New Rotary Airlock Valves
ACS Valves
Bolted Metallic Pumps Maintain Air Efficiency
Versa-Matic Launches E40 Model Pumps
New Variable Flow Meters Accommodate Higher Temperatures
Parker Hannifin Expands P-Series Flow Meter Line
Pneumatic Conveying System Weighs Bulk Solids
Flexicon Offers Pneumati-Con Conveying System
Pump/Tank Carts Handle Caustic and Acidic Chemicals
Vanton Introduces Mobile Pump/Tank Cart
Peristaltic Pumps Built For Heavy Industrial Applications
Flowrox Offers LPP-T Peristaltic Pumps
Specialized Filters Offer Real-Time Sampling
Parker Hannifin Introduces Balston Fast-Loop Filters
Compact Measurement Controllers Monitor Low Flow Rates
Bronkhorst Introduces Mini Cori-Flow Measurement Controllers
Bronkhorst USA
Screw Heat Exchangers Handle Powder Processing Applications
Kemutec Introduces New Line of Screw Heat Exchangers
Kemutec
Flat-Deck Screeners Handle Process Industry Applications
Kemutec Offers New Range Of Flat-Deck Screeners
Kemutec
Double-Diaphragm Pump Contains No Manifold Seals
Flotronic Pumps Offers Minichem Double-Diaphragm Pump
Flotronic Pumps
PTFE Reactor System Handles Fluorine Or Boron Chemistry
Ace Glass Launches New PTFE Reactor
Ace Glass
Transmitters Boast SIL Suitability
Emerson Introduces Rosemount 5400 Transmitter
Pneumatic Bulk Bag Discharging System Transfers To Silos
Flexicon Offers Pneumatic Bulk Bag Discharging System
Vacuum Conveyor Features Full-Bore Discharge Valve
Volkmann Adds Ultra Low Profile Vacuum-Conveying Unit To VS Series
Flow Meter Includes Inlet/Outlet Needle Valves
Brooks Instrument Introduces New Sho-Rate Flow Meter
Bulk Bag Discharging System Provides Dust-Tight Operation
Material Transfer Offers Material Master Bulk Bag Discharging
Automatic Gas Control Valves Respond To Multiple Process Signals
Severn Offers Capital Controls Automatic Gas Control Valves
Severn Trent Services
Controllers Handle Chlorine Dosing Levels
Severn Offers Captrol Series 1450 And 1451 Controllers
Detectors Can Monitor Chlorine Gas In Eight Different Locations
Severn Trent Services Provides Gas And Leak Detectors
Transmitters And Controllers Offer Automatic Thermocompensation
Severn Introduces MicroChem 2 Analyzer, Transmitter And Controller
Industrial Scrubbers Perform Emergency Gas Abatement
Severn Offers EST Scrubbers For Emergency Gas Abatement
Gas-Feed Disinfection Technology Features Automatic Gas Control Valves
Severn Trent Services Introduces Capital Controls Disinfection Technology
Chlorine Dioxide Generator Helps Kill Disease-Causing Pathogens
Lift Check Valves Prevent Reverse Flow In Pipelines
Spirax Sarco Unveils A New Range Of Lift Check Valves
New Electrochemical Sensors Measure PH And ORP
Invensys Introduces PH12 Series pH And ORP Sensors
Software Automatically Finds Root Cause Of Upsets
ExperTune Automates PlantTriage Software Analysis
ExperTune
New Smart Valve Actuator Utilizes Brushless Direct Current Voltage Motor
Flowserve Announces Limitorque QXM Smart Valve Actuator
Flowserve
Acrylic Flow Meters Handle Gas And Water Flow Applications
Brooks Instrument Launches Series 2500 Flow Meters
Drum Discharging System Provides 180-Degree Drum Rotation
Material Transfer Offers Dust-Tight Drum Discharging System
New Glass-Tube Flow Meter Includes Scale With Rotating Lens
Electronic Remote Sensor System Includes DP-Level Technology
Emerson Process Management Introduces Rosemount 3051S Remote Sensor
Dust-Tight Drum Discharging System Provides 180-Degree Drum Rotation
Rupture Disc Features Full-Open Relief Area
Continental Disc Unveils Sanitrx Rupture Disc
Pre-Torqued Holder Maintains Precise Rupture Disc Loading
Continental Disc Offers HPX-PT Pre-Torqued Holder
Brochure Includes Information About Rupture Discs
Continental Disc Launches HPX Product Literature
Profibus Offering Now Includes Pressure Transmitter
Emerson Expands Profibus Protocol With Rosemount 2051 Transmitter
Two-Way-Tight Option Available With New Valve Design
Metso Introduces New Valve Design Based On V-Port
Metso
Compressed Air Filters Offer Top-Load Design For Confined Spaces
Parker Introduces New Line Of Compressed Air Filters
Handheld Communicator Includes Icon-Based Interface
Emerson Introduces New Icon-Based Interface For The 475 Field Communicator
Proportional Relief Valves Handle Up To One-Inch Piping Systems
Swagelok Unveils RHPS Series PRV Valves
Weigh Batching System Simultaneously Weighs Multiple Ingredients
Flexicon Introduces Plantwide Weigh Batching System
Groove Couplings Are Available In Rigid And Flexible Styles
Anvil Unveils Two-Piece Large Diameter Gruvlok Couplings
Anvil International
Long-Range Wireless System Facilitates Tank-Level Supervision
Omega Engineering Unveils HPWS Long-Range Wireless System
Product Type: Wireless
Pre-Engineered Subsystems For Fluid Processing Available As Single-Ordering ...
Swagelok Company Introduces Pre-Engineered Subsystems
Bulkhead Fittings Provide Constant Load On The Gasket
Hayward Flow Control Launches New Tank-Tite Compression Fittings
Air Release Valve Maintains System Fluidity
Larox Introduces Air Release Valve
Larox
Vent Heads Feature Internal Drain For Condensate Recovery
Spirax Sarco Introduces VHT Vent Head
New Line Of Rotary Airlock Valves May Reduce Service Cycle
ACS Valves Introduces New Line Of Rotary Airlock Valves
ACS Valves
New Valve Driver Manages Proportional Valves
Enfield Technologies Introduces DI PWM Valve Driver
Multichannel Data Logger Covers Measurements Over Wide Temperature Ranges
ITT Releases EBI Multichannel Data Logger
Product Type: Data Logger
Flow Transmitters Handle Water Glycol-Based Heat Exchange
Clark Introduces New Vortex Flow Transmitters
Actuator Offers Modular Air Cylinder Range
Crane ChemPharma Flow Solutions Launches New Products
Domeloaded Pressure Regulators Utilize Pressurized Chamber
Swagelok Introduces RHPS Series Domeloaded Pressure Regulators
Abrasion-Resistant Slide Gate Features Dust-Tight Seal
Vortex Valves Introduces Titan Series Slide Gate
Vortex Valves
Low-Flow Control Valve Withstands High Pressure
Badger Meter Introduces Research Control Valve
High-Integrity Pressure Regulator Provides Shutdown And Injury Safeguards
Midland-ACS Launches High-Integrity Pressure Regulator
Midland-ACS
Springless Diaphragm Valves Available In Integratred And Remote Coil ...
Dwyer Instruments Launches DCS/RDCS Springless Diaphragm Valves
Sample Filtration Filters Offer Real-Time Sampling
Parker Hannifin Introduces Balston Fast Loop Sample Filters
Filling Transmitter Handles Machine Applications
Emerson Introduces Micro Motion Filling Transmitter
Digital Pressure Test Gauges Span Wide Ranges
Palmer Instruments Debuts New Pressure Test Gauges
Palmer Wahl Instruments
Slurry Valve Suitable For Light, Medium Applications
ITT Introduces Fabri-Valve 33 PTD Slurry Valve
Universal Connector Handles Super-Heat Steam Lines
Armstrong Introduces 4-Bolt Universal Connector
Electronic Actuators Can Eliminate 90% Of Internal Wiring With Modular ...
ProMation Engineering Offers Electric Actuators
High-Pressure PTFE Hoses Handle Up To 5,500 PSI
Parflex Unveils High-Pressure PTFE Hose Assemblies
Pressure Regulator Handles Ultra-Pure Liquids
Plast-O-Matic Introduces Kynar Pressure Regulator
Ultrasonic Level Transmitters Offer 12-Meter Measurement Range
Emerson Extends Rosemount 3100 Series
Flow Meters For Water And Coolant Operate With NPT Ports
Parker Fluid Control Division Introduces New Flow Meter Line
New NSF Listed Rotary Vane Pumps Handle Wide-Ranging Applications
Clark Solutions Unveils PA Stainless Series Rotary Vane Pumps
4-Bolt Universal Connector Withstands Extreme Heat And High Pressure
Chemical Dosing System Utilizes Rotor Mounted On Eccentric Shaft
Vanton Pump Introduces Flex-I-Liner Model 12
High-Performance Metal Seat Ball Valves Handle Abrasive Fluids
A-T Controls Introduces M-Series Metal Seat Ball Valves
A-T Controls
Steam Trap Includes Cast Steel Cover With Socket Weld Connections
Spirax Sarco Announces FTC80-FB Ball Float Steam Trap
Industrial Vacuum Collects Combustible Dusts
VAC-U-MAX Releases Model 860/02 Combustible Dusts Vacuum
VAC-U-MAX
Float And Thermostatic Steam Trap Features Stainless-Steel Body
Spirax Sarco Redesigns Float And Thermostatic Trap
Push-Through Slurry Valve Handles Harsh Applications
Diaphragm Valve Suitable For Sterile Processes
Alfa Laval Introduces Line Of Diaphragm Valves
pH/ORP Sensor Handles Broad Range Of Industrial Applications
Emerson Releases Rosemount Analytical Model 3900 pH/ORP Sensors
Magnetic-Drive Rotary Vane Pump Handles Continuous Operation
Clark Solutions Introduces TSFR Series Rotary Vane Pump
Magnetic Drive Technology Can Improve Pump Motor Life
ITT Flojet Launches Magnetically Coupled Centrifugal Pumps
Gas Management System Provides Continuous Pressure And Flow
Concoa Unveils Integrated Gas Management System
Concoa
Bearing Isolator Handles Flooded And Oil Mist Applications
Garlock Sealing Technologies Introduces New Bearing Isolator
High-Lift Box, Container Dumper Allows Floor-Level Loading
Flexicon Introduces High-Lift Box/Container Dumper
Combination Bearing Isolator And Shaft Grounding Ring Offers Electrical ...
Garlock Unveils New Shaft Grounding Bearing Isolator
New Needle Valves Feature An Integrated Stem And PTFE Seat
Hayward Flow Control Releases NVA Series Needle Valves
Application Delivers Real-Time Plant Data To Mobile Devices
ExperTune's PlantTriage Available For Mobile Devices
ExperTune
Diaphragm Gas Pump Suits High-Temperature Monitoring Applications
Clark Solutions Unveils New Diaphragm Gas Pump
Pinch Valves Meet Stringent Customer Specs
Larox Flowsys Introduces New Pinch Valves
Larox
Control Valve Provides Liquid Cavitation Reductions
Yeary Controls Unveils Sharktooth Control Valve
Yeary Controls
Peristaltic Pump's Single-Roller Design Reduces Friction
Larox Flowsys Peristaltic Pump Features Single Roller Design
Larox
5-Valve Block And Bleed Manifold Features Precision-Machined Valve Stem To ...
Dwyer Introduces New BBV-2 5-Valve Block And Bleed Manifold
Advanced Software Tool Helps Speed Lifecycle Costing Of Air Filters
Camil Farr Releases LCC 2010 Lifecycle Costing Software
Reference Recorder Displays Differential Pressure To 0.025% Accuracy
Crystal Engineering Releases nVision Reference Recorder
Crystal Engineering
Tank-Gauging System Helps Refineries Handle Increasing Demands
Emerson Launches Fully Scalable Tank-Gauging System
Magnetically Coupled Centrifugal Pumps Eliminate Need For Motor Shaft Seals
ITT Flowjet Introduces New Magnetically Coupled Centrifugal Pumps
Cyclone Dust Collector Uses Compact Ground-Plate Design
Aerodyne Unveils A Compact High-Efficiency Dust Collector
Aerodyne
Process Filter Gage Determines State Of In-Line Filters
Dwyer Instruments Offers New Process Filter Gage
Full-Stroke PTFE Diaphragms Can Enhance AODD Pump Performance
Wilden Increases AODD Pump Performance
Calibration System Handles Flow Meters Used In Less-Precise Applications
Flow Dynamics Introduces FTS Continuous Loop Calibrator
Flow Dynamics
Purge And Pressurization System Operates In Highly Corrosive Environments
Pepperl+Fuchs Introduces 5000Q Series Purge and Pressurization System
Magnetic Gear Pumps Handle Food, Chemical And Industrial Applications
Clark Solutions Offers New Magnetic Drive Gear Pumps
AODD Pump Utilizes Flap Valves For Maximum Solids Passage
Wilden Pump & Engineering Introduces 51 MM Brahma Pump
New Pump Includes Flanged 76-MM Top Inlet And Bottom Discharge
Wilden Unveils 76-MM Brahma Pump
Vibrating Fork Level Switch Is Suitable For High And Low Level Alarms
Emerson Introduces Vibrating Fork Level Switch
Battery-Operated Mag Meter Offers 'Go-Anywhere' Design'
Badger Meter Announces New Additions To Mag Meter Line
Diaphragm Offers Longer Life
New Filter Fits Oval-Style Dust Collectors
Camfil Farr Launches New HemiPleat NoOval Filter
Intelligent Valve Controller Can Reduce Commissioning Time
Metso Implements Neles Intelligent Valve Controller Upgrade
Metso
Logistics Management Module Supports Marine, Rail, Truck Operations
Emerson Adds Module To Smart Operations Suite
Wrap Absorbs Valve Leaks
New Pig Introduces Oil-Only Valve Wrap
New Pig Corp.
CD Features Dust-Collection Products And Technologies
New Camil Farr CD Presents Dust-Collection Products
Software Suite Extends Predictive Maintenance Capabilities
Emerson's AMS Suite Expands Scope With Profibus DP Support
Steam Trap Handles High-Pressure Steam Lines
Spirax Sarco Updates Thermodynamic Steam Trap
Pneumatic Conveyor Can Save Energy And Labor
Hapman's MiniVac Features Side-Door Access
Hapman
Magnetic Mixers Operate Safely When Dry
Alfa Laval Magnetic Mixers Deliver Friction-Free Mixing
Three-Way Shut-Off Valve Offers Handle With 180-Degree Rotation
Dwyer Instruments Launches Three-Way Shut-Off Valve
AODD Pumps Utilize Accu-Flo Technology
Wilden Introduces Advanced Plastic Series A100P AODD Pumps
Filter Removes Water From Diesel Fuel And Hydraulic Oils
Serflico Trans-O-Filter Includes Media Options
Serfilco
Non-Contact Transmitter Penetrates Froth And Measures Pulp Height
Hawk Measurement Develops A Non-Contact Transmitter
Hawk Measurement
Gap Gages Help Tighten Fittings In Hard-To-Reach Locations
Brennan Industries Introduces Gap Gages
Brennan Industries
New Control Valves Can Help Plants Meet Environmental Regulations
Metso Introduces New Line of Control Valves
Metso
Electronic Steam Boiler Controllers Include 'Inter-Controller' Communication ...
Spirax Sarco Introduces Electronic Steam Boiler Controllers
Axial Piston Pump Aims To Increase The Productivity Of Heavy-Duty Machines
Parker Hannifin Announces New PV360 Axial Piston Pump
Fieldbus Digital Level Controller Stores Up To 30 Logs
Emerson Introduces Fisher Fieldbus Digital Level Controller
Vacuum Pump Exhaust Filter Can Help Reduce Safety Violations
Parker Expands Balston Vacuum Pump Inlet And Exhaust Filter Line
Flow Controller Features Advanced Core Sensor Technology
Sierra Introduces New High Performance Flow Controller
Dump Hopper Provides A Dust-Free Dumping Option
Metalfab's Dump Hopper Features A Baffle And Bin Vent
Metalfab Inc.
Ball Valves Include Seating Options For Varying Temperature Ranges
Tyco Flow Control Launches the Series 300 Ultra-Seal Ball Valves
Tyco Flow Control
Higher Control-Valve Range Provide More Options For Various Applications
Spirax Sarco Releases The New Spira-Trol Range
O-Ring Feed-Through Can Prevent Leaks Into Enclosures
Parker Introduces Captured O-Ring Feed-Through and Bulkhead Fitting
Wireless Vibration Transmitter Sends Direct Alerts
Emerson Expands Smart Wireless Predictive Maintenance Capabilities.
Vertical Multistage Pumps Feature Stainless-Steel Construction
ITT Introduces e-SV Vertical Multistage Goulds Pumps
Tune Cascade Loops From A Web Browser
ExperTune Offers Web-Based Tuning Of Cascade Loops
ExperTune
AODD Pump Technology Is Designed Energy Savings
Warren Rupp Launches The AirVantage AODD Pump
Warren Rupp
Customers Can Select Valve Features With Online-Configuration Tool
ASCO Introduces Two- and Three-Way Valves With Online-Configuration Tool
ASCO
Intelligent Control Valve Now Includes High-Pressure Classes
Neles RotaryGlobe Expands Metso’s iCV Offering
Metso
Centrifugal Sifter's Fully Cantilevered Shaft Designed For Easy Cleaning
Kemutec Launches The K1100C Centrifugal Sifters
Kemutec
Seals-Free Pumps May Reduce Maintenance Costs
Watson-Marlow’s Bredel SPX Pump Is Designed For Harsh Environments
Dry Compressed Air Can Maintain Inks At Consistent Level
Kaeser Cooling Air Provides Dryers For Industrial Processes
Sanitary Disc Can Be Pressurized Up To 95% Of Rated Burst Pressure
Continental Disc Releases The Sanitrx HPX Rupture Disc
Temperature Controller Comes Equipped With Position Feedback
Dwyer Instruments Launches New Valve Temperature Controller
Pumps Come With Quick-Disconnect
Minimize Overspray And Quality Problems With Modular Spray System
Spraying Systems’ New Model Offers Precision Spraying
Product Type: Nozzle
Spraying Systems Co.
Filter Fits New And Existing Cartridge Dust Collectors
Camfil Farr Introduces New HemiPleat Nano Filter
Polypro Ball Valve Is Ideal For Chemical Applications
Plast-O-Matic Introduces Electrically Actuated Ball Valve
Metal-Seated Ball Valves Include Self-Cleaning System
ChemPharma Introduces Krombach Ball-Valve Line
Automated Overfill Protection Reduces Potential Hazards
SIS-TECH Introduces Automated Overfill Protection System
SIS-TECH Solutions
New Dust-Collector Filter Is Designed To Save Energy
HemiPleat Nano Filter May Increase Filtration Efficiencies
Two-Way Ball Valve Can Handle Up To 1,500 PSI
Dwyer Instruments Introduces MSV Two-Way Ball Valves
Optical Dissolved Oxygen Sensor Features Increased Fouling Resistance
Emerson Introduces RDO Sensor And Analyzer
Compact Sensors Broadens Range Of 2-Wire Applications
Flow | Emerson Expands Application Range Of Micro Motion Flowmeters | Chemical Processing
iESD Valves Can Improve Plant Safety
Metso Launches SIL 3-Certified Ball Valves
Metso
New Cavity Pump Handles Demanding Applications
Larox Flowsys Introduces Progressive Cavity Pump
Larox
Emergency Breathing System Features Integrated Rescue Hose
MSA Introduces ExtendAire II Breathing System
Product Type: Personnel protective equipment
MSA
MVD Technology Enables Faster Transmitter Performance
Emerson Upgrades Micro Motion Coriolis
Progressive Cavity Pump Utilizes 2-Lobe Rotor for Tighter Pumping
Larox
High-Flow Diaphragm Valve Designed for Improved Flow Performance And Reduced ...
GF Piping Introduces Diaphragm Valve
Safety Valve Controller Is Designed For Emergency Shutdown, Venting
New Neles ValvGuard VG9000 increases safety cost-efficiently
Metso
Software Monitors Instruments, Valves, Controls
ExperTune’s PlantTriage Control System Monitoring Software
ExperTune
Electronic Latching Valve Suited For Green Designs
ITT-Alcon Electronic Latching Valve Ideal for Green Designs
Portable And Fixed Mount Mixers Use Modular Assembly Design
Nettco i-Series Portable and Fixed Mount Mixers
Gas Flow Control Valve Automates Chemical Feed Process
Peristaltic Hose Pumps Handle Range of Liquids
Condition Monitoring Kit Includes Four Machine Assessment Tools
Rupture Discs Offer Performance In Excess Of A Quarter Million Cycles
Continental Disc Launched HPX and HPX SANITARY Rupture Discs
Sanitary Pumps Prove Ideal Where Bacteria, Contamination Must Be Avoided
Moyno Sanitary Pumps Offer Superior Performance Features
Moyno
Flowmeter Designed To Increase Plant Availability, Enhance Safety
Emerson unveils Rosemount Vortex Flowmeter
Bulk Bag System Weighs And Dumps
V-1063 Bulk Bag and Manual Weigh Batch System from Flexicon
Product Type: Weighing
Valveless Chemical Treatment System Delivers Caustic Soda
Flow Conditioner SignifiReduces Flow Meter Straight-Run Requirements
Vortab Co. Introduces VIP Flow Conditioner
Vortab Company
Emergency Relief Vent Is Available In Top-Guided And Hinged Configurations
VCI Introduces Emergency Relief Vent Series
Cashco
Rupture Disc Holders Can Be Torqued To Correct Static Load Level
Fike Adds to Line of Pretorqueable Rupture Disc Holders
Fike
WirelessHART Level Switch Enables Detection Anywhere
Emerson Adds Rosemount Vibrating Fork Liquid Level Switch
Technology Delivers Online Verification Of Meter Performance
Emerson Introduces Performance verification for Micro Motion Coriolis meters
System Transports Multiple Samples
Swagelok Showcases SSV Series Analyzers
Transmitters Are Designed For High Static/Low DP Applications
Dwyer Instruments' 655A Series differential pressure transmitters
High Pressure Pumps Feature Three Chamber Configuration
Flojet Triplex High Pressure Pumps
Pump System Optimizes Tank Cleaning And Spray Nozzles
Fluid Delivery System Introduced by Spraying Systems Co.
Wireless Transmitter Identifies The Most Efficient Communication Path
Emerson's Rosemount Analytical Model 6081-C Transmitter
Fan Motors Tout Operational And Energy Savings
Farr's Gold Series Cartridge Dust Collectors
Flowmeter Is Suitable For Long-Distance Transmission
GF Piping Systems' Flexible Flowmeter Configuration
Flowmeter Measures Via Tapered Tube And Float
Swagelok's Custom-Calibrated Flowmeters
Critical Control Functions Easily Changed On Flowmeter
Sierra Instruments' Next-Gen Flowmeters, Controllers
Compressors Tout Capacities Ranging From 457 To 980 acfm
Sullair Redesigns its 200 HP compressors
Sullair
Dirty Service Control Valve Solutions Serve Severe Applications
Emerson Expands Dirty Service Control Valve Solutions
Transmitters Convert Measurements Into Wireless Sensor Signals
Honeywell Adds Universal I/O Transmitters to OneWireless
Industrial Vacuum Minimizes Clogs
Camfil Farr APC Introduces Industrial Vacuum
Explosion-Proof System Inverts Drums Safely
MTS hydraulic Lift & Seal System
Flowmeter Features Stainless Steel Transmitter Housing
Emerson Process Management Expands Rosemount 8800D Series
Tank Level Gauges Designed For Cryogenic/Liquefied Gas
Mid-West Instrument Introduces Cryogenic/Liquefied Gas Level Indication
Mid-West Instrument
Compact Gauge Valve Reduces Need for Supports
Rotary Disc Valve Touts Leak Tight Shut Off
Larox Flowsys Introduces Rotary Disc Valve
Larox
Filter Regulators Feature Rolling Diaphragm For Fast Response
Parker Hannifin Introduces A New Line Of Filter Regulators
Pumps Handle Abrasive Liquids
Blackmer
Explosion Isolation Pinch Valve Prevents Deflagration Propagation
Fike Introduces Explosion Isolation Pinch Valve
Fike
Tank Gauging Systems Include Wireless Functionality
Emerson introduces Rosemount TankRadar Rex and Pro
Product Type: Data handling and archiving
Flow Sensor Permits Hot-Tap Access To The Pipe Stream
GF Piping Systems Metal Magmeter
Multi-Port Selector Valve Is Suitable For Corrosive Environments
Guided Wave Radar Boasts Thicker Rod For Longer Measurement Lengths
Emerson's Rosemount Single Lead Guided Wave Radar Level Transmitters
Multi-Variable Flow Meter Monitors Steam, Gas
Spirax Sarco Introduces MassTracker
Measuring Cells Are Reliable In Many Environments
Field Communicator Features Valve Diagnostic Capabilities
Half-Inch Needle Valve Boosts Reliability
Parker Hannifin Introduces Half-Inch Needle Valve
Pneumatic And Electric Actuated Ball Valves Minimize Backlash
Omega's Pneumatic and Electri c Actuated Ball Valves--BVP70/BVP80
Fiberglass Pump Is Efficient, Energy Friendly
Goulds Showcases Nonmetallic Pump
Software Accelerates Tuning Time
ExperTune Introduces PlantTriage Version 9
ExperTune
Pressure Sensors Prevent Overflow Of Tanks
Red Valve Co. Inc.
Valve Maintains Set Flow Regardless Of Fluctuations
ITT Bell & Gossett Introduces Optiflo Control and Ultraset Valves
Bell & Gossett
Packaged Blowers Feature Integrated Controller
Vacuum Conveyors Meet Traceability Requirements
PIAB Presents Compliant Vacuum Conveyors
Large Butterfly Valve Features An Off-Center Shaft
GF Piping Systems Expands Butterfly Valve Offering
Transmitter Improves Productivity And Energy Management
Emerson Introduces a New Rosemount Multivariable Transmitter
Liquid Vortex Flow Sensor Features High Accuracy and Low Cost
Clark Solutions Showcases Liquid Vortex Flow Sensor
Portable Dust And Fume Collector Has Three-Stage Filtration
Control-Valve Actuators Provide Precise Operation
Position Monitor Uses WirelessHART Communications
Emerson Process Management Fisher® 4320
Product Type: Communication
Mini Collector Quietly Removes Dust, Fumes
PvDF Valve Protects Media Purity
Sampling System Valves Feature Direct In-Line Closed-Loop Design
Sure Seal, Inc.
Wireless Monitoring Offers Unique Approach To Redundancy
Emerson Unveils Smart Wireless Monitoring
Polyethlyene Piping Handles Low Temperatures
Variable Speed Pump Controller Matches Hydraulic Needs
Reversing Electric Actuators Good For Valve Automation Applications
Hayward 's New Line of Reversing Electric Actuators
WirelessHART Conductivity Transmitter Well Suited For Many Applications
Emerson's Smart Wireless Conductivity Transmitter
Self-Priming Pump Can Handle Harsh Materials
New KNF Pump for Liquids
KNF Neuberger Inc.
Dust Collector Uses Centrifugal Force
Aerodyne announces the new "S" Series Dust Collector
Aerodyne
Humidity/Temperature Transmitters Are Explosion Proof
Dwyer Instruments Introduces Explosion-Proof Humidity/Temperature Transmitter
Compact Pressure Sensor Is Small And Easy To Operate
Festo Corporation Introduces SPAB Pressure Sensor
Festo Corporation
Transducers Offer Improved Control Accuracy
Eurotherm’s IP Series Offers Two New Transducers
Eurotherm
Humidity/Temperature Transmitter Is Weather Resistant
Dwyer Instruments Weather-Resistant Humidity/Temperature Transmitter
Thermometers Boast External Reset for Field Calibration
Swagelok Thermometers Boast External Reset for Field Calibration
Ammonium Sensors Deliver Economical Analytical Measurement Solution
Dust Collector Separates Fine Particles Beginning At 20 Microns
Aerodyne Presents the "S" Series Dust Collector
Aerodyne
Pressure, Strain and Force Handbook Features Hundreds Of Products
Pressure Strain and Force Handbook Features Hundreds Of Products
Drum Dumper Seals, Tips, Mates And Discharges Materials
X-0607 Drum Dumper From Flexicon
Flow Meters Display Flow Rates Of Five Routine Gases
Aalborg Instruments Introduces xV Multi-Gas Glass Tube Flow Meters
Guided Wave Radar Level Transmitters Feature Failure Modes
Emerson Introduces Rosemount Guided Wave Radar Level Transmitters
Flowmeter System Handles High-Pressure Applications With Only Two Moving Parts
PD Flowmeter System
Flow Technology
Portable And Fixed-Mount Mixers Can Be Configured Numerous Ways
LIGHTNIN Nettco S-Series Mixer
Flow Meter Features Venturi Profile
Dwyer Instruments Inc. Introduces Venturi Flow Meter
Electro-Pneumatic Positioners Offer Reliable Control
Bray Electro-Pneumatic Positioners with Reliable, High Performance Control
Bray International Inc.
Variable Speed Pump Controller Manages Up To Four Pumps
Bell & Gossett Introduces Variable Speed Pump Controller
Bell & Gossett
Air Filter Regulator Handles Harsh Environments
ControlAir Inc. Introduces Air Filter Regulator Type 330
Machinery Monitoring Solution Helps Predict Performance Of Assets
Emerson introduces AMS Performance Advisor
Handheld Communicator Delivers Field Diagnostic Capabilities
Emerson Showcases Handheld Communicator
Valve Position Sensor Based On Proven Sensing Technology
Honeywell Adds Valve Position Sensor to OneWireless Portfolio
Desuperheater Promotes Rapid Water Absorption
Pick Desuperheater Series DS
Pick Heaters, Inc.
Relief Valve Good For Low Emission, Overpressure Monitoring
Groth Corp. Introduces 1800A Series Full Lift Type Valve
Lockout/Tagout Device Secures Plug Valve
Brady Worldwide Introduces Lockout/Tagout Device
Brady Corporation
Guided Wave Radar Transmitter Eliminates Accuracy Errors
Emerson Introduces Vapor Option for Rosemount Sensors
Asset Management Software Manages Machine Health
Emerson Introduces New AMS Suite
Flow Meters Feature More Control And Flexibility
Sierra Introduces Next Generation Flow Meters and Controllers
Ball Valve Delivers Consistent Sealing
Swagelok Introduces FKB Series Ball Valve
Plate Reactor Also Functions as Heat Exchanger
Product Type: Plate reactor
Air Blender Lifts And Turns Dry Materials
Dynamic Air Introduces Blendcon Blender
Dynamic Air
Metal-Free Chemical Dispensing System Enhances Safety
Metal-Free Chemical Dispensing System Contains Hazardous Fumes
Colder Products Co.
Rotary Actuator Reduces Valve/Actuator Dimensions
Emerson Process Management Introduces Fisher 2052 Rotary Actuator
Butterfly Valves Offer Superior Chemical Resistance
Valve Status Monitors with DC, AC or Bus Network Signaling
Bray Controls has expanded and improved its Series 52 2N1 ProxSensor line of valve status monitors.
Bray Controls
Software Capabilities Increase Productivity and Project Acceleration
Intergraph has released the latest version of its 3-D design solution, SmartPlant 3D, with expanded functionality.
Product Type: Drawing and layout software
Intergraph
Field Starter Kit Features Discrete Switches, Vibration and pH Transmitters
Emerson Process Management has added discrete switches as well as vibration and pH transmitters to the range of components available in its Smart Wireless field starter kit.
Two-Way Valves with Improved Performance and Online Configuration Tool
ASCO has unveiled its 8262/8263 Series two-way, direct-acting solenoid valves with increased AC and DC pressure ratings and real-time online configuration and ordering.
ASCO
Flame Arrester Also Protects Against Detonations
Groth Corp.
Low–High ESV System Isolates Upstream Flow
Buckling Pin Technology
Basic LPP-M Pump Is More Economical Than Smart Version
Larox Flowsys has introduced a basic version of its LPP-M pump in addition to the current smart version.
Larox
Low-Cost Tube Pumps for Liquids of Low to Medium Viscosity
Aalborg’s Model TPU tube pumps are suitable for liquids of low to medium viscosity.
Explosion-Proof Current-to-Pressure Transducer Is Vibration and Position ...
ControlAir Inc. announces the introduction of the Type-595XP Explosion-Proof Current-to-Pressure I/P Transducer.
Horizontal Batch Mixer Features Adjustable Paddle Blades
Marion Mixers Inc. has unveiled a custom-designed horizontal batch mixer with adjustable paddle blades.
Marion Mixers
Remote Gas Calibrator Expedites Maintenance
Product Type: Detector
General Monitors
Seated Butterfly Valves Target Corrosive Applications
Seated Butterfly Valves Designed For Corrosive Applications
Sampling Valves Utilize a Rack and Gear Combination
Strahman Valves has announced the availability of its "Quick Advance" (QA) sampling valve.
Strahman Valves
Single and Double Block and Bleed Needle Valves
High Pressure Equipment Company has developed a line of block and bleed needle valves that deliver safe, reliable operations up to 20,000 psi.
Chambers for the External Mounting of Process Level Instrumentation
Emerson Process Management has introduced a range of chambers that allow for the external mounting of level measurement and control instrumentation on process vessels
Product Type: Chambers
Sensors and Analyzers Feature SMART Functionality
Emerson Process Management has added SMART functionality to its PERpH-X pH sensor, Model 6081 wireless analyzer, Model 1056 dual-input analyzer and Model 1057 multi-parameter analyzer.
Point Level Sensor with Fault Monitoring/Self-checking Diagnostics
Emerson Process Management has launched an extreme temperature version of its Rosemount 2130 vibrating fork liquid level switch, which is designed for use in extreme temperatures from -94 to +500 °F ( -70 to + 260 °C).
High Pressure Pumps Feature a Five-Chamber Design
ITT Corporation has introduced its Flojet Pentaflex Series 7.0 GPM High Pressure Pumps.
Filtration System Saves Equipment Costs, Floor Space and Labor Costs
Pentair Industrial introduces the Aqualine Liquid Filtration System, a cost-saving solution for high-flow-rate applications.
Pentair Industrial
Rotary Valve Uses Special Seal Technology
Rotary Valve Uses Special Seal Technology -- POSI-SEAL rotary valve ensures shutoff against maximum rated pressure drop, regardless of flow direction
Rupture Disc Offers Proven Performance
Continental Disc Corporation has introduced the Sanitrx MP rupture disc, which features cycling technology and severe service application capabilities.
Interface Tool Simplifies Modbus Programming and Commissioning of Coriolis ...
Emerson Process Management now offers a complimentary support utility for all Micro Motion customers who use Modbus protocol to interact with their Coriolis meters.
Control Module for Use in Conventionally Wired Applications
Emerson Process Management announces a FieldQ control module for use in conventionally wired applications.
Flow Meters Feature Direct-Reading Scales
Aalborg Instruments has introduced direct-reading scales for Models P, S and T flowmeters.
Thermocouple with a Gas-tight Sapphire Protective Tube
Emerson Process Management has introduced a Rosemount thermocouple with a gas-tight sapphire protective tube for use in gasification reactor applications.
Retractable pH Sensor for Tough Industrial Applications
ABB has released the Endura TBX587 Retractable pH sensor.
Temperature Humidity Data Logger with Display
Dwyer Instruments' Model GDL Graphical Display Data Logger can record and instantly display trends for temperature, humidity and dew point.
Stainless Steel Solenoid Valve Available In New Size
Magnatrol Valve Corp.
Multi-Parameter Paddle Wheel Flow Meter
Aalborg's Paddle Wheel Flow Meters offer cost-effective, high-accuracy solutions to low-flow liquid applications.
Submersible, Compact Temperature Data Logger
Dwyer Instruments, Inc. announces the release of its Model STDL-10 Submersible Temperature Data Logger.
Mass Flow Controller with ANSI or DIN Flanges
Sierra Instruments' Max-Trak Model 180 Industrial Mass Flow Meters and Controllers are now available with 316 stainless steel (ANSI or DIN) flange mounting for gas flow rates up to 1000 SLPM.
pH Sensor Offers Increased Stability
Emerson Process Management has unveiled a new autoclavable and steam-sterilizable pH sensor designed for stability in life science applications.
Wireless Transmitter for High Density Temperature Measurement
Emerson Process Management announces the expansion of its Smart Wireless solutions with the introduction of its Rosemount 848T wireless temperature transmitter for high density temperature measurement.
Mass Flow Controller Is Insensitive to Fluctuations
Brooks Instrument has released the B-Series mass flow controller, a family of mass flow products designed to be insensitive to fluctuations in pressure and temperature.
Wye Line Diverter Directs Dry Bulk Material
Vortex Valves North America introduces its Quantum Series 3-Way Wye Line Diverter specifically engineered to handle dry bulk solids in pneumatic conveying systems with vacuum or positive pressures up to 15 PSIG (1 barg).
Vortex Valves
Shaft Seal System “Floats” on Water
With the addition of the Water Mizer, Inpro/Seal now offers a number of shaft-sealing systems for use in applications where wet or dry particulates, powders and slurries are handled, processed, packaged and stored.
Inpro Seal
Shaft-sealing Systems Handle Shaft Run-outs and Deflections
Inpro/Seal now offers two shaft-sealing systems for the containment of powders, abrasives, liquids and toxic vapors; the Air Mizer-PS and the Articulating Air Mizer- PS.
Product Type: Seals & Packing
Inpro Seal
Filtering Centrifuge Is Designed for Solids/Liquid Separation
The Western States Machine Company's Laboratory Filtering Centrifuge is designed for solids/liquid separation.
Product Type: Centrifugation
Supply Sticks Strengthen, Simplify Process Piping
Expanded Coriolis Meter Features Loop-Powered Transmitter
Emerson's Micro Motion 2200S transmitter is now available on ELITE Coriolis meters for line sizes ranging from 1/8 inch (3 millimeters) to 6 inches (150 millimeters).
Updated Rupture Discs Feature a 95% Operating Ratio
New versions of Continental Disc Corp.’s Star X and Ultrx rupture discs have been released, each featuring a 95% operating ratio.
New Line of Filter Regulators, Regulators and Mini Filters
Parker Hannifin has introduced a line of filter regulators, regulators and mini filters which are designed for OEM applications and in-plant applications.
Direct Drive Compressor Is Quiet And Easy To Maintain
Quincy Compressor Releases New Direct Drive Rotary Screw Compressor
High-Pressure Flange Kit Is NSF Certified
Lubrizol Introduces High-Pressure Flange Kit for reliability and maintenance
Product Type: Replacement components and materials
Lubrizol
Snap-Action, Air Relay Pressure Switches Can Be Fine Tuned
K-TEK Introduces Air Relay Pressure Switches from BETA
K-TEK
Ultrasonic Flow Transmitters Eliminate the Need for Calibration
Clark Solutions has introduced the CSLFC Liquid Ultrasonic Flow Transmitter.
Acrylic Rotometers Are Easy to Disassemble
Omega's FL-2500 series direct read rotometer kits offer versatility at a low cost.
AMS Optimizes Plant Assets, Features WirelessHART Support
Emerson’s AMS Suite delivers WirelessHART support, robust alert management, advanced diagnostics, and enhanced usability
Harsh Environment Filters Remove 99.99% Of Particles From Compressed Air
Parker Hannifin Filters Remove 99.99% Of Particles From Compressed Air
Trunnion Mounted, Metal Seated Ball Valves Are Designed for High Temperature,...
Strahman's Trunnion Mounted, Metal Seated Ball Valves have been specifically designed for severe service applications such as those found in oil and gas, petrochemical, refining, polymer, steam, catalyst, DCU (delayed coking unit) and coal gasification industries.
Strahman Valves
Control-Disk Valve Has Double the Control Range
Emerson Process Management introduces the Fisher Control-Disk valve.
Emerson's FloBoss Customers Can Create Custom Programs
Emerson Process Management's DS800 Development Suite is now available for its FloBoss Flow Manager family of natural gas and liquid flow computers.
Diaphragm Pumps Available in Single or Dual Pump Configurations
Designed for pressure or vacuum applications where low current and reliability are the prime requirements, Clark Solutions' Boxer 5100 and 5200 diaphragm pumps are engineered for use with compatible liquids and gases
Cryogenic Seal Enables Accurate Measurement of Gasses
Emerson Process Management has introduced a cryogenic seal for its Rosemount 5300 Series of Guided Wave Radar (GWR) level transmitters.
Product Type: Adhesives, sealants & chemicals
Three-Input Intelligent Analyzer Includes Four 4-20mA Current Outputs
To meet the need for multiple liquid measurements and lower costs per measurement loop required by industrial OEMs and other analytical customers, Emerson Process Management presents the Rosemount Analytical Model 1057 three-input intelligent analyzer.
Non-metallic Valves Will Operate in Highly Caustic Environments
Groth Corporation announces a line of relief valves designed for environments too corrosive for metallic or fiberglass valves.
Groth Corp.
Compact Control Valves Feature Reversible Actuator
Samson’s 3525 Series Valves Designed For On-Off Service
Samson Controls Inc.
Asset Manager Reduces Costs and Improves Uptime Through Predictive Diagnostics
Flowserve Corporation has launched the Flowserve ValveSight, an asset management solution for integrated control valves and automated quarter-turn valve packages.
Flowserve
Electronic Valve Actuator Is Designed to Enhance Safety and Reduce Downtime
Flowserve Corporation introduces the Flowserve Limitorque QX valve actuator to its family of electronic actuators
Flowserve
Industrial Pump Features a Kalrez Perfluoroelastomer Diaphragm
ITT-Flojet has introduced the G57C, an air-operated, industrial pump with a Kalrez perfluoroelastomer diaphragm from DuPont Performance Elastomers
ITT Industries
Digital Peristaltic Pump May Maximize Productivity
Thermo Fisher Scientific Introduces Peristaltic Pump
Thermo Fisher Scientific Inc.
LCD Touchpad Makes Information Retrieval, Configuration, Tuning and ...
Emerson Process Management has introduced an easy-to-use panel-mounted LCD Touchpad interface for its FloBoss Flow Manager family of natural gas and liquid flow computers
Mid-West Instrument Offer New Line Of Gauges
Mid-West Instrument
Real-Time Concentration Monitor Designed For Biopharm Industry
Swagelok Launches Concentration Monitor
Sensors Offer Chemical Compatibility and Many Mounting Options
GF Piping Systems Introduces Next Generation DryLoc pH and ORP Sensors
Relief Valve Is Designed For Corrosive Processes
Groth Corp. Introduces Relief Valve For Corrosive Processes
Groth Corp.
Disposable Adsorption Filters Remove Vapors
Parker Introduces Disposable Adsorption Filters That Remove Vapors
Product Type: Adsorption
Tank Level Gauges Work With Cryogenic/Liquefied Gas
Mid-West Instrument Introduces Tank Level Gauges
Mid-West Instrument
Software Pinpoints Plant Interactions
Software pinpoints plant interactions, enables engineers to pinpoint the root cause of process interactions.
ExperTune
Smart Switches Are Pre-configured to Work Within the DeltaV Network
Emerson Process Management has unveiled a line of smart network switches specifically designed to plug and play within the DeltaV digital system network.
Indicating Alarm Annunciator Provides Visible and Audible Alarms for Eight ...
Dwyer Instruments introduces the Series AN2 Indicating Alarm Annunciator
Complete Turbomachinery Solution Adds Value to Retrofit and Upgrade Projects
Emerson Process Management introduces the CSI 6500 Machinery Health Monitor, the latest advancement of its Smart Machinery Health Management capabilities.
Spring-energized Seals Are Designed for High-Performance Aerospace Applications
CoorsTek introduces the redesigned MetaPlast II spring-energized seal
CoorsTek, Inc.
Scalable Technology Platform Offers Application Flexibility and HMI ...
Emerson Process Management introduces a scalable technology platform for its FloBoss family of flow computers
Explosion-proof Liquid Density Meter Does Not Require Barriers or Galvanic ...
Emerson Process Management introduces an explosion-proof/flame-proof version of its Micro Motion 7835 custody transfer density meter.
Extended Range Antenna Expands the Reach of Smart Wireless Networks
Emerson Process Management expands its Smart Wireless solutions with the release of the Extended Range Antenna
Software Suite Simplifies the Setup and Management of Smart Wireless Networks
Emerson Process Management announces its AMS Suite: Intelligent Device Manager 9.5 applications for planning and managing scalable wireless networks to support the growing demand for wireless solutions in the process automation industry.
Piping Software Features New Look
Engineered Software, Inc. Releases PIPE-FLO Professional 2009
Explosion-Proof Compressed-Air Dryers Deliver Without Electricity
Parker Hannifin’s Explosion-Proof Compressed-Air Dryers Deliver Without Electricity
Product Type: Membrane technology
Peristaltic Pump Meters a Range of Media
Larox unveils the LPP-M peristaltic pump for metering
Larox
Remote Sensor Humidity/Temperature Transmitter Good For Small Spaces
Dwyer Introduces RH-R Remote Sensor Humidity/Temperature Transmitter
Chemical Instrumentation | Gems Introduces UCL-510 Ultrasonic Continuous ...
Gems Introduces UCL-510 Ultrasonic Continuous Liquid Level Sensor
Gems Sensors & Controls
Ball Valve Features a Locking Handle for Added Security
Asahi/America, Inc. introduces a locking handle for their Type 21 Ball Valves
Asahi/America, Inc.
Local Operator Interface Is Available for Mass Flow Meters and Controllers
Brooks Instrument releases local operator interface for its 4800 Series Mass Flow Meters and Controllers
Ultrasonic Flow Transmitters Bring “Sing Around” Technology to a Range of ...
Clark Solutions unveils the ClarkSonic Ultrasonic Flow Transmitters
Solid-Liquid Separation Solutions Process Edible Oils
Larox offers multiple solid-liquid separation solutions for processing edible oils.
Larox
Acrylic Flow Meters Feature Dual Interchangeable Scales
Dakota Instrument unveils its ACR Clear Acrylic Flow Meter
Dakota Instruments, Inc.
Enhanced Mass Flow Meters/Controllers Offer Digital Communications and a ...
Brooks Instrument Enhances Its 4800 Series of Mass Flow Meters/Controllers with Digital Communications and a Downport Connection Option.
Differential Pressure Transmitter Offers Full Over-Range Protection
Mid-West Instrument’s 4-20mA Differential Pressure Transmitter An Option on Model 240
Mid-West Instrument
Three-Way Valve Improves Temperature Control
Emerson’s Fisher GX 3-way valve improves temperature control
Communications Interface Offers Real-Time Sample System Information
Parker Hannifin Introduces Pilot Pro
Fluid Handling Instrument | Plast-O-Matic Valves Introduces Spigot Ends for ...
Plast-O-Matic Valves Introduces Spigot Ends for Valves and Regulators
Product Type: Spigots
Bulk Bag Discharging Application Increases Batch Accuracy
National Bulk Equipment Offers Bulk Bag Discharging Application
National Bulk Equipment, Inc.
Differential Pressure Transmitter Calibrates At The Touch Of A Button
Dwyer Instruments offers transmitter that calibrates at the touch of a button.
New Spray Nozzle Promotes Process Productivity
Delavan Spray Technologies Showcases SDX spray Drying Nozzles
Stainless Steel Valve With Inflatable Seat Offers Leak-Proof Seal
Posi-flate
Variable Area Flowmeters Offer Custom Calibration
Swagelok variable area flowmeters offer custom calibration and a 10:1 turndown ratio.
Oxygen Analyzers Improve Efficiency of Boilers and Furnaces and Provide ...
Emerson Process Management's enhanced Rosemount Analytical X-stream Oxygen Analyzers improve the efficiency of large boilers and furnaces and provide immediate reduction of carbon dioxide emissions
Two-Wire Coriolis Meter Provides a Solution for Loop-powered Flow Points ...
Emerson Process Management's two-wire Micro Motion Coriolis meter provides a solution for loop-powered flow points throughout the plant
Communication Interface Introduced for Coriolis Flow Transmitters
Model 2400S transmitters are now available with DeviceNet and PROFIBUS DP communications, increasing the versatility of ELITE Coriolis meters
Sanity V-Blenders Can Be Customized to Fit Your Intimate Dry Blending Needs
Ross V-Blenders can be customized to fit your intimate dry blending needs
Charles Ross & Son Company
Enclosed Filters Offer New Promise for Chemically Produced Toner
Larox' DS and PF Series filters meet the needs for processing chemically produced toner
Larox
Redesigned Clean Agent Fire Suppression Systems Will Continue to Meet UL and ...
Fike's clean agent fire suppression systems with DuPont FM-200 will continue to meet UL and FM approvals.
Fike
Self-Dumping Hopper Simplifies the Disposal of Dust Captured by ...
Farr Air Pollution Control's Self-Dumping Hopper simplifies the disposal of dust captured by cartridge-style collection systems
Product Type: Waste management services
Horizontal Cartridge Dust Collector Provides Efficient Filtration in a ...
MikroPul's MikroFlo horizontal cartridge dust collector provides efficient filtration in a compact size.
MikroPul
Cost-effective Metal Detector Introduced for Bulk Flow Products
Mettler-Toledo Safeline introduces its new cost-effective metal detector.
Mettler Toledo
Gore Products Covers a Range of Sealing and Fluid Handling Requirements
W. L. Gore offers wide range of sealing products
W.L. Gore
Metal-seated Valve Design Introduced for Critical Service Applications
Metal-seated valve design introduced for critical service applications
Hemiwedge Valve Corporation
Gas-tight Filters Are the Accepted Way to Process Carboxy Methyl Cellulose
Pannevis GT gas tight filters from Larox are a proven technology for filtering carboxy methyl cellulose
Larox
Blower Package Features the Qx Blower and a Noise Enclosure
The Qube by Tuthill is a quiet and low-cost solution for pneumatic conveying, wastewater aeration and more.
Product Type: Blower
Cast Iron and Stainless Steel Pump Models Expand Diaphragm Pump Portfolio
Ingersoll Rand announces expanded its ARO Pro Series portfolio of diaphragm pumps by enhancing the 2- and 3-inch ported metallic pump models to include additional materials of construction.
Diaphragm Metering Pump Offers a Built-in DFD Leak Detection System
Omega Engieering's PHP-800 Series diaphragm metering pump has PVDF double ball valves, can pump up to 42 GPH (2700 ml/min), and handle output pressures up to 12.1 bar (175 psi).
Visual Modeling Tools Offer Drag-and-Drop Modeling
PlantTriage's new visual modeling tools result in better dynamic process models.
ExperTune
Enhanced Digital Valve Controller Is SIL3 Certified
Emerson's Fisher Fieldvue DVC6000 digital valve controller is SIL3 certified
Clamping Device Fits Sanitary Specifications
Continental Disc Corporation's Sani-Torq makes sanitary Clamping easy
Plate Reactor Combines the Properties of a Continuous Chemical Reactor with ...
Alfal Laval's plate reactor combines the properties of a continuous chemical reactor with those of a plate heat exchanger
Analyzer Offers Single- or Dual-Sensor Input with an Unrestricted Choice of ...
Emerson's Model 1056 analyzer offers single- or dual-sensor input with an unrestricted choice of dual measurements
Weigh Batching System De-Lumps the Product and Feeds It Gravimetrically into ...
Flexicon's weigh batching system de-lumps the product and feeds it gravimetrically into rigid bins
Miniature Solenoid Valves Isolate Fluid Hermetically
Omega's solenoid valves isolate fluid hermetically
Multipurpose Ball Valves Offer Positive, Quarter-Turn Shutoff
Swagelok valve family expands with multipurpose ball valves
Wireless Vibration Transmitter Delivers Predictive Diagnostics for Improved ...
Emerson's wireless vibration transmitter increases reliability, safety
Manual Dump to Rigid Bin Weigh Batching System Eliminates Dust
Manual dump to rigid bin weigh batching system eliminates dust
Peristaltic Pump Offers Increased Capacity and Tighter Flow Control
Pump offers increased capacity, tighter flow control
Small-scale Contained Filter Dryer Provides Efficiency and Versatility
Contained filter drying designed for R&D
Powder Systems Limited
Flanged Ball Valve Is Fire Tested to Ensure High-Temperature Performance
Flanged ball valve from Assured Automation passes fire test
Assured Automation
High-Pressure Metering Pump Covers a Wide Range of Applications
Watson-Marlow launches high-pressure metering pump
Space-saving Flow Meter Measures Process Gas or Air Flows
FCI introduces space-saving flow meter
Quick-Access Screener Speeds Cleaning, Inspection and Screen Changes
Quick-access screener speeds cleaning, screen changes
Precision Epoxy Protects, Seals and Reconditions Surfaces
Ceramic-filled epoxy protects, repairs surfaces
Category: Materials of construction
Product Type: Coatings/linings
Devcon
Gear and Lube Oil Filtration System Is Designed for Higher Viscosity Fluids
Portable gear and lube oil filtration system from Trico fills major void
Trico Corporation
Miniature Rotary Batch Mixer Blends with 100% Uniformity
Munson's miniature rotary batch mixer blends with 100% uniformity
Dry Vacuum Pump Valve Features a Wedge Sealing System
Dry vacuum pump valve features wedge sealing system
BOC Edwards
Metering Pump Offers Precise Control in Low-Flow Applications
Metering pump offers precise control in low-flow applications
Moyno
Flow Sensor Installs Without Shutdown
GF Piping System's flow sensor installs without shut-down
Tank Level Gauges Are Suite for Cryogenic/Liquefied Gas Applications
Mid-West releases tank-level gauges for cryogenic, liquefied gas
Mid-West Instrument
Hydrogen Gas Generator Can Support up to 20 Instruments
Balston's hydrogen gas generator eliminates need for cylinders
Product Type: Generator
Membrane Air Dryers Provide Pure, Dry, Compressed Air at a Guaranteed Dewpoint
Membrane air dryers provide pure, dry compressed air at a guaranteed dewpoint
Booster Compressors Provide Pressures up to 650 Psig
Kaeser expands compressor line to 650 psig
MVGT Trays Provide Increased Capacity
Sulzer Chemtech's MVGT trays provide increased capacity
Product Type: Distillation
Sulzer Chemtech
Peristaltic Pumps Are Designed for the Metering, Dosing and Transferring of ...
Watson-Marlow Bredel introduced its 520/620/720 family of peristaltic pumps are designed for the accurate metering, dosing and transferring of sensitive fluids in sanitary environments, making them ideal for accurate filtration, fermentation, dispensing, coating and seamless integration into ...
APC releases retrofit cartridges with updgraded dust collector performance
Garlock Sealing Technologies, a supplier of fluid sealing technology, introduced its 104GS general service elastomeric expansion joints.
Mid-West Instrument, Inc.
Mid-West Instrument, Inc. introduces a new line of tank level gauges for cryogenic/liquefied Gas for both stationary and mobile applications.
Mid-West Instrument
Flowserve Corp.
Flowserve Corp. launched the Flowserve Logix 3400IQ Foundation Fieldbus digital valve positioner. The 3400IQ features a new FISCO-compliant user interface board, improved potentiometer, piezoelectric technology, and host interoperability to provide operating versatility and fast, easy and ...
Flowserve
Lasso Technik
Lasso Technik announced the patented Stop-Silent Check Valve Series to the U.S. market.
Lasso Technik
The Proximity Division of Dwyer Instruments is offering a new capacitive level switch, the CLS2. Sensing technology in the CLS2, using impulse RF admittance measurement combined with an active guard, provides level measurement and stability while being insensitive to material buildup.
A new design of thermocouple assembly from the Partek division of Parker Hannifin provides a reliable temperature monitoring sensor for high-purity fluid systems that traditionally use fluoropolymer components.
Conval, Inc.
Conval a supplier of high-temperature, high-pressure valves recently announced the addition of ASME III, Class 1, 2, 3 and NPT certifications to its list of quality credentials. The N-stamp certifications are now available on the company's Clampseal globe and check valves, Swivldisc gate valves, ...
Blackmer
Blackmer, a supplier of positive displacement rotary vane, eccentric disc, peristaltic hose and centrifugal pump technologies, announced the addition of the SX3 Series to its line of stainless steel sliding vane pumps.
Blackmer
Emerson Process Management launched its in-plant Smart Wireless solutions that enable manufacturers to boost mainstream applications to the next level of reliability and operational performance.
Flow Technology, Inc.
Flow Technology, Inc. announced the release of its Model SLF-500 ultrasonic liquid flow meter.
Flowserve
Veriflo
Veriflo offers miniature point-of-use pressure regulator
Rithmware Technologies Releases Drying-centered Simulation Software
Rithmware Technologies releases drying-centered simulation software
Metso Automation
The ND9000 intelligent valve controller from Metso Automation, designed to operate with most control valve actuators, allows users to benchmark control performance on rotary and linear valves.
Metso
Flowserve Corp
Flowserve Corp. announcces the Limitorque MX smart electronic valve actuator
Midland Manufacturing
Midland Manufacturing presents a new ball valve seat designed to provide higher dimensional stability and improved sealind in low and high temperatures
Flowserve
Flowserve introduces its smallest pump yet
Flowserve
NLB
NLB offers high-flow multi-gun valve
NLB Corp.
Garlock Sealing Technologies launches self-loading gasketing material
Rosemount introduces multi-variable transmitter
GF Piping offers paddlewheel flowmeter line
McCrometer
Macro Sensors
Macro Sensors offers user-friendly digital controllers and indicators
Donaldson
Donaldson introduces fully tested containment system
McCrometer
Sullair
Sullair
Neptune
Waukesha Cherry-Burrell
Norcross
Cyclonaire
Cyclonaire phase conveyors can handle abrasive materials
Flowserve
Cyclonaire
Moore
Martin
IEDCO
Neptune Chemical Pump
Pelletron
Kleentek
Macro Sensors
Leistritz
Milwaukee Valve Company
George Fischer
Drexelbrook
Pelletron
Hansen Technologies
George Fischer
Asahi/America
General Monitors
ExperTune PlantTriage Assesses Batch Process Performance
ExperTune's new release of PlantTriage software assesses the performance of batch processes. It pinpoints areas where improvements can increase yields, throughput, and decrease turnaround times.
ExperTune
Kaeser Compressors announces the new H Series dryers – the latest addition to its comprehensive line of refrigerated dryers. Available in flows from 12 to 123 scfm, these non-cycling refrigerated dryers use Kaeser's proven heat-exchanger technology to consistently produce dew points as low as 35ºF.
Asahi
Asahi/America, Inc. introduces the Quarter-Bloc PVC True-Union Ball Valve. The NSF-61 certified valve features all-thermoplastic construction with no metallic parts, and offers excellent flow characteristics due to the full orifice opening, which is equivalent to the inside diameter of the ...
Its angled vent valve is easy to actuate, even when the Swagelok® remote-mount two-valve manifold is panel mounted. This compact manifold features a non-rotating, hardened needle design to minimize seal wear, protect the seat from galling, and promote long service life and leak-tight shutoff.
George Fischer
George Fischer, Inc. has introduced the economical H2O Type 374 Valve designed specifically to provide superior performance in water applications. NSF 61 certified for potable water applications, the new true union valve offers a number of safety and convenience features in a compact size that ...
Jacob Tubing
The new Jacob Tubing USDA valve is designed specifically for low pressure/vacuum conveying, bulk material handling and air flow systems for the dairy, food and pharmaceutical industries where equipment must meet USDA Dairy sanitary levels or equivalent.
Asahi/America Inc.
These globe control valves are designed for precise flow control and are available in both pneumatic (air to spring) or electric (115vac 1ph supply voltage), in body materials of PVC, PP, PVDF and PTFE, and in sizes from ½-inch to 4-inches.
ISL-USA
Kaeser Compressors announces the BSD 60
Compressor offers zero-loss transmission efficiency
Flowserve Corp.
Burkert
ITT Industries Engineered Valves Group
CPV Manufacturing
ZOOK Enterprises LLC
Red Valve Co. Inc.
Noveon IP Holdings Corp.
Woodward Industrial Controls
Roto-Disc Company
Asahi/America Inc.
Fauske & Associates
An index to the latest chemical processing products.
2014
2007
2015
2006
2009
2012
2004
2005
2008
2010
2011
Displaying 1-744 of 744 results
