Displaying 1-110 of 169 results
Pump Control Improves Boiler Efficiency
Cognitive pump technology integrates the boiler firing rate with pump speeds to improve boiler and system efficiency while reducing electrical consumption.
Thermal Solutions Products
Tower Provides High Cooling Capacity
Cooling system offers alternative to field-erected towers.
Blower Supports Simple Installation
Tuthill introduces MPAC 2000 blower package.
Intelligent Marshalling Improves Efficiency
Schneider Electric extends universal I/O capability for Foxboro and Triconex.
Pump Motors Feature High Thrust Capacity
Siemens introduces new high-thrust pump motors.
Emissions Monitoring System Provides Alternative To CEMS
Nationwide Boiler Inc. introduces the DataStak.
Nationwide Boiler
Diaphragms Improve Hygiene
Pure-Fuse Diaphragms offer easier cleanability for hygienic applications.
Gas Analyzer Optimizes Combustion
Oxygen and combustibles analyzer measures the efficiency of fossil-fired boilers and process heaters.
Explosion-Proof Lighting Saves Energy
Explosion-proof high bay LED light fixture provides operators with a powerful and energy efficient alternative to traditional hazardous location luminaires.
Larson Electronics
Device Monitors Water Treatment Issues
The monitoring system provides 24/7 remote monitoring of environmental conditions at unattended water treatment operations.
Sensaphone
Pumps Improve Energy Efficiency
Clamped design offers ease of maintenance and convenient cleanup.
Filtration Modules Lower Water Cost
Dow increases water treatment efficiency with new XP fiber.
Dow Water & Process Solutions
Water System Controls High Heat
Mokon introduces redesigned Duratherm MAX Water System.
Sine Wave Filters Eliminate Motor Damage
Technology converts the rectangular PWM output voltage of motor drives into a smooth sine wave with low residual ripple.
Schaffner USA
Ductless Fume Hood Saves Energy
Purair ECO is designed for chemical and particulate protection for laboratory and industrial applications.
Single-Axis Drive Features Easy Setup And Operation
Siemens introduces Sinamics V20 AC Drive.
Heat Transfer Fluid Exhibits Durability
Hydrogenated terphenyl chemistry expands temperature range for processing applications.
Diaphragm Pumps Reduce Downtime
The advanced flanged range now includes five sizes that are certified to ATEX Zone 1.
VSDs Feature Embedded Intelligent Services
Applications perform more efficiently through embedded process knowledge, configurable on-board dashboards and a graphical HMI display designed to deliver information specifically oriented to the customer’s application.
Combustion System Simplifies With Single, Modular Pla
Honeywell launched the SLATE Integrated Combustion System designed to simplify the engineering of combustion equipment controls in a single platform.
Software Suite Delivers Safety And Efficiency
Aveva launched Control of Work, a suite of products designed to help deliver safety and efficiency when planning and performing routine maintenance and in-plant engineering operations in potentially hazardous plant environments.
Aveva
Dow Introduces Water Application Value Engine
Dow Water & Process Solutions (DW&PS) introduced the Water Application Value Engine (WAVE)—a new digital modeling tool for evaluating components and designing water treatment systems.
Product Type: Software Solution
AMETEK Rotron Introduces MIL-901XP Cooling Fan
AMETEK Rotron introduced the MIL-901XP cooling fan qualified for use in hazardous industrial applications.
Ametek Rotron
GE Introduces AnMBR Membrane Technology
GE introduced a membrane-based wastewater treatment technology combining anaerobic digestion technology with its ZeeWeed 500 membranes to create anaerobic membrane bioreactor (AnMBR).
Ingersoll Rand Introduces ARO Controller
The ARO Controller from Ingersoll Rand delivers touch-and-walk-away automation.
Siemens Introduces NEMA Premium SD661Motor
Siemens released a severe duty motor, the NEMA Premium SD661, for use in the petrochemical, energy and other similar industries and for specialized use in air- cooled heat exchanger applications.
Ingersoll Rand introduced the ARO Controller.
AAF Introduces VariCel 2+ Filter
American Air Filter introduced the VariCel 2+ filter line.
AAF
Schneider Releases Wonderware InTouch Machine Edition
Schneider Electric released a new HMI software product as part of its Wonderware InTouch portfolio.
Schneider Introduces Foxboro Compact 200 Series
Schneider Electric introduced Foxboro Compact 200 Series.
Electric Motor With Brush Protects Bearings
Baldor introduces Super-E Motor with Baldor Shaft Grounding Brush.
VFD Inverter Provides Energy-Efficient Motor Control
Mitsubishi A800 Series inverter combines traditional induction and permanent magnet motors into a single solution
Mitsubishi Electric Automation
Manifold-Mounted Ejector System Reduces Energy Consumption
Piab Updates piCompact Manifold-Mounted Ejector System
eat Exchanger Features Upgraded USDA Hygienic Design
Terlet Launches Terlotherm Delta Range
Terlet
Heat-of-Compression Desiccant Dryers Produce Guaranteed Dew Point of -40 ...
Atlas Copco Introduces XD+ 550-3600 Range of Heat-of-Compression Desiccant Dryers
Rotary Screw Compressor Increases Free-Air Delivery by Up to 13 Percent
Atlas Copco Compressors Extends GA VSD+ Range to 50 Horsepower
Screw Blower Provides Potential Energy Savings of 30 Percent
Atlas Copco Extends ZS Screw Blower Range
Industrial Energy Management System Integrates Existing, Disparate Energy ...
GE Releases PMCS v7.0 Power Management Control System
GE
New Heat Oil Transfer Systems Provide Efficient Temperature Control
Mokon Introduces HTF NPS Positive and Negative Pressure Heat Transfer Oil System
Web-based Energy Data Collection Solution Simplifies Energy Management in ...
Mitsubishi Electric Automation Launches EcoWebServer III
Diaphragm Pumps Boost Safety
ARO electronic interface air-operated diaphragm pumps offer accurate, electronically controlled dosing for chemical processing applications.
Packaged Boilers Include Energy-Efficiency Features
Indeck Launches New Packaged Boilers
Indeck
Process Automation System Optimizes Production and Energy Efficiency
Schneider Electric Announces PlantStruxure PES
Product Type: Integration with IT systems
BPX Brazed Plate Heat Exchangers Withstand High Pressure and High Temperatures
Xylem Expands Its Line of Bell & Gossett BPX Brazed Plate Heath Exchangers
Xylem Inc.
Preconfigured Inverter Includes Preset Speed Selections
Hitachi Introduces NE-S1 Inverter
Hitachi
Motor Line Expands Ratings
Baldor Super-E Motors Include 98 New Ratings
Water-Injected VSD Compressors Offer Potential Energy Savings
Atlas Copco Introduces Water-Injected VSD Compressors
Circular Fluid Bed Dryer Features Rigid Processing Chamber
Kason Offers Vibro-Bed Circular Fluid Bed-Drying System
Pumps Feature Rotary Design
Edwards Releases STP-iXR1606 Pump Series
Software Monitors Energy Costs And Consumption
Iconics Lauches Energy AnalytiX 10.61
Iconics
Power Monitors Measure Energy Consumption
Rockwell Automation Introduces Allen-Bradley PowerMonitor W250 & 500
Dry Vacuum Pumps Feature Tapered Screw Technology
Edwards Launches CXS Dry Pump Line
HOC Dryers Focus On Energy Efficiency
Ingersoll Rand Releases New Line Of HOC Dryers
Heat Transfer Fluid Systems Reduce Space Requirements
Mokon Adds HTF ST Series Heat Transfer Fluid Systems
Servo Provides Alternative To Traditional Stepper Technology
Yaskawa Releases Junma AC Servo
Regenerative Blowers Comprise Cast Aluminum Housing
Ametek Offers Two New Rotron Regenerative Blowers
Ametek Technical and Industrial Products
White Paper Features Reactor Temperature Control Tips
Huber White Paper Offers Information About Products
Huber
Screw Blowers Use Internal Compression
Atlas Copco Introduces Line Of ZS Screw Blowers
Centrifugal Air Blowers Are 100% Oil Free
Atlas Copco Unveils ZB 5-120 VSD Centrifugal Air Blowers
High-Horsepower Motor Comes In NEMA And IEC Frame Sizes
Baldor Expands RPM AC Permanent Magnet Line
Compressed Air Filters Offer Top-Load Design For Confined Spaces
Parker Introduces New Line Of Compressed Air Filters
Engineering Software Offers New Conceptual Design Builder
AspenTech Releases aspenONE V7.3 Engineering Software
Compact Cooling Thermostats Suitable For Tight Spaces
Peter Huber Introduces Ministats Cooling Thermostats
Huber
Vent Heads Feature Internal Drain For Condensate Recovery
Spirax Sarco Introduces VHT Vent Head
CE Compliant Control Minimizes Compressed Air Use
Exair Introduces Digital ETC Cabinet Cooler
Heat Transfer Systems Feature Integrated Circulation Pump
New Heat Transfer Systems From Huber Available
Product Type: Cooling water
Huber
Heat Transfer Fluid Systems Offer Reduced Space Requirements
Mokon Introduces New Stationary Heat Transfer Fluid Systems Line
Universal Connector Handles Super-Heat Steam Lines
Armstrong Introduces 4-Bolt Universal Connector
Armstrong International
Outdoor Air-Cooled Chillers Help Free Indoor Floor Space
Mokon Introduces New Line Of Outdoor Air-Cooled Chillers
Low NOx Optimization Kit Retrofits Existing Burners
Hamworthy Peabody Offers New Low NOx Q-jet Optimization Kit
Hamworthy Peabody Combustion
4-Bolt Universal Connector Withstands Extreme Heat And High Pressure
Steam Trap Includes Cast Steel Cover With Socket Weld Connections
Spirax Sarco Announces FTC80-FB Ball Float Steam Trap
Heat Transfer Oil Systems Line Offers Combined Heating And Cooling
Mokon Expands HTF 350 Series
Float And Thermostatic Steam Trap Features Stainless-Steel Body
Spirax Sarco Redesigns Float And Thermostatic Trap
Temperature Control System Offers Rapid Response Times
Huber Introduces Unistats Temperature Control System
Huber
Package Boiler Products Allow For Upgrades And Conversions
Hamworthy Provides Broad Range of Package Boiler Products
Full-Stroke PTFE Diaphragms Can Enhance AODD Pump Performance
Wilden Increases AODD Pump Performance
AODD Pump Utilizes Flap Valves For Maximum Solids Passage
Wilden Pump & Engineering Introduces 51 MM Brahma Pump
New Pump Includes Flanged 76-MM Top Inlet And Bottom Discharge
Wilden Unveils 76-MM Brahma Pump
Catalyst Filters Capture Particulate At Low Levels
Tri-Mer UltraCat Catalyst Filters Are Available For Boilers
Automation Drive Includes Energy-Saving Features
Danfoss Unveils VLT Automation VT Drive
Danfoss
Steam Trap Handles High-Pressure Steam Lines
Spirax Sarco Updates Thermodynamic Steam Trap
Stainless-Steel Plunger Pumps Provide Corrosion Resistance
Cat Pumps Offers Stainless-Steel Plunger Pumps
CAT Pumps
Heatless Desiccant Dryers Handle Demanding Industries And Applications
Atlas Copco Launches Desiccant Air Dryer Ranges
AODD Pumps Utilize Accu-Flo Technology
Wilden Introduces Advanced Plastic Series A100P AODD Pumps
Heavy-Duty Industrial Fans Handle Heavy-Dust Jobs
Airlanco's New Industrial Fans Available For Extreme Conditions
Airlanco
Programmable Automation Control System Provides Entry For Enterprise Control ...
Invensys' Foxboro PAC System Offers Integrated Hybrid Control
Digital Thermostat Is Suited For Process Temperature Maintenance And Freeze ...
Chromalox Announces Digital Thermostat For Heat Trace System Control
Electronic Steam Boiler Controllers Include 'Inter-Controller' Communication ...
Spirax Sarco Introduces Electronic Steam Boiler Controllers
Modular Frequency Inverter Is Designed For Energy-Efficient Operations
Siemens Industry Launches Modular Frequency Inverter
Vacuum Pump Exhaust Filter Can Help Reduce Safety Violations
Parker Expands Balston Vacuum Pump Inlet And Exhaust Filter Line
Cooling Water Technology Is Designed For Harsh Conditions
GE's Next-Gen Cooling Water Technology Offers Potential Savings
