Displaying 1-54 of 54 results
Turbine Flow Meters Provide Accuracy
Blancett B1500 Series Turbine Flow Meters are designed to perform in harsh environments.
Ammonia Analyzer Promotes Regulatory Compliance
Endress+Hauser introduces the Liquiline System CA80AM ammonium analyzer for monitoring critical control points in water and resource reclamation facilities.
Software Simplifies Dynamic Plant Management
New release lets users modify, view and create consistent plans for process management.
ProSys
Pressure Transducer Display Enables Inverted Reading
360-degree marquee display provides visual cues signaling pressure, condition and readiness of a fluid power system.
Transducers Direct
Transducers Direct Introduces TDWLB Wireless Sensor
Transducers Direct introduced the TDWLB pressure/temperature sensor powered with a coin-cell battery, controlled with a smartphone app and certified as Bluetooth Smart.
Transducers Direct
Yokogawa Introduces DT450G Dust Monitor
Yokogawa Corporation of America introduced the model DT450G dust monitor.
Supply Chain Process Control Tower Helps Filter Big Data Overload
Elemica introduces new Business Process Control Tower application.
Elemica
Limit Controller Can Monitor Temperature of Plastics Extruder
Omega Introduces Temperature/Process Limit Controllers CNi-AL
App Provides Access To Alarms Via Mobile Devices
Exele Releases TopView Mobile Web App
Product Type: Alarm Management
Exele Information Systems
Transducers Handle Hazardous Environments
ControlAir Introduces P200 and P290 Transducers
Reporter Software Adds Excel Support
Matrikon Expands Reporter Support
Product Type: Data Logger
MatrikonOPC
Bulkhead Fittings Provide Constant Load On The Gasket
Hayward Flow Control Launches New Tank-Tite Compression Fittings
High-Integrity Pressure Regulator Provides Shutdown And Injury Safeguards
Midland-ACS Launches High-Integrity Pressure Regulator
Midland-ACS
Software Application May Simplify Instrumentation Management
Honeywell Releases Field Device Configurator
Category: Operations management
Product Type: Analytical technology
Gas Management System Provides Continuous Pressure And Flow
Concoa Unveils Integrated Gas Management System
Concoa
Differential Pressure And Air-Flow Gauges Replace Analog Instruments
Dwyer Instruments Offers Battery-Powered Air-Flow Gauge
Web-Delivered Reliability Software Streamlines Maintenance-Related Tasks
ChemSW Releases Enhanced Version Of IMCS Live
ChemSW
Differential Pressure Gauges Are Available In Bi-Directional Models
Mid-West Instrument Unveils Low DP Differential Pressure Gauges
Mid-West Instrument
Bi-Directional Low-Range Differential Pressure Gauges Are Available
Mid-West Introduces Differential Pressure Gauges
Mid-West Instrument
Thermal Conductivity Analyzer Features Integrated Sampling Pump
United Process Controls Announces The TCSmart
Particulate Monitoring System Promotes Safety
BinMaster
Titrator Is Designed For Basic Applications
Mettler Toledo Titration Line Expands
Mettler Toledo
Differential Pressure Gauges Have Several Applications
Mid-West Instrument’s Low DP Differential Pressure Gauges
Mid-West Instrument
Scale Terminals Are Easily Integrated
Mettler Toledo Feature Scale Terminals
Product Type: Weight
Mettler Toledo
Humidity/Temperature Transmitter Is Weather Resistant
Dwyer Instruments Weather-Resistant Humidity/Temperature Transmitter
Optical Gas Monitor Provides Real-Time Scanning
OXS Series In-line/On-line Optical Gas Monitor
Precisive LLC
Low-Range Differential Pressure Gauges Have Aluminum Housing
Mid-West Instrument
Electromagentic Flowmeter Serves Water, Wastewater Markets
ABB Introduces FlowMaster portfolio
Spectrophotometer Includes 3-D Optical System for Enhanced Flame and Furnace ...
The AA-7000 Series atomic absorption spectrophotometer from Shimadzu Scientific Instruments incorporates recently developed 3-D optics for enhanced flame and furnace analysis.
Software for Simplified Enterprise Manufacturing Intelligence
Wonderware, a business unit of Invensys, has announced the release of Wonderware Information Server 3.1 software with enhanced Web-based, enterprise-level reporting capabilities and support for Microsoft SharePoint 2007 and Windows Vista.
Wonderware
Electromagnetic Flowmeter Designed for Process Applications
ABB Instrumentation has launched a range of electromagnetic flowmeters specifically targeted at the chemical, power, oil and gas, pulp and paper, and metals and mining markets.
Explosion-Proof Current-to-Pressure Transducer Is Vibration and Position ...
ControlAir Inc. announces the introduction of the Type-595XP Explosion-Proof Current-to-Pressure I/P Transducer.
Pretreatment Water System Includes Filters
Siemens Water Technologies has developed the Vantage PTI family — a product line of complete, pretreatment water systems that includes multimedia filters, carbon filters and softener technologies.
Mobile Workforce and Decision Support System Includes Configurable Software ...
Wonderware, a business unit of Invensys, announces the availability of Wonderware IntelaTrac version 3.2, the latest version of its mobile workforce and decision support system.
Wonderware
Differential Air Pressure Transmitters Are Available in Three Models with ...
Amalgamated Instrument Co. (AIC) has unveiled a series of differential air pressure transmitters, the WS-TPDPT7.
Analyzer Measures the Level of Dust in Plastics Before and After Dedusting
Pelletron, in collaboration with ASTM, introduces the FineAlyzer for the measurement of fines and dust particles on plastic pellets.
Pelletron
NSX Analyzer Offers Improved Sample Introduction and Enhanced Oxidative ...
Thermo Fisher Scientific Inc. announces the launch of the TITAN 4000 Total Nitrogen/Sulfur/Chlorine (NSX) analyzer.
Software Incorporates Features and Tools for Vibration Analysis Professionals
Commtest Instruments Ltd. announces the availability of its Ascent 2008 R2 software.
Transit-Time Ultrasonic Flowmeter Offers an Alternative Choice for Mag-Meter ...
Sierra Instruments introduces the Innova-Sonic In-Line Model 206 Digital Correlation Transit-Time ultrasonic flowmeter
IP30-rated Wireless LAN Access Points Offer Enhanced Security Features
Siemens Energy and Automation, Inc. introduces the Scalance W784 line
Differential Pressure Transmitter Offers Full Over-Range Protection
Mid-West Instrument’s 4-20mA Differential Pressure Transmitter An Option on Model 240
Mid-West Instrument
Communications Interface Offers Real-Time Sample System Information
Parker Hannifin Introduces Pilot Pro
Differential Pressure Transmitter Calibrates At The Touch Of A Button
Dwyer Instruments offers transmitter that calibrates at the touch of a button.
Universal Wireless Network Improve Plant Safety, Reliability and Efficiency
Honeywell's universal wireless network increases productivity, uptime
Manual Dump to Rigid Bin Weigh Batching System Eliminates Dust
Manual dump to rigid bin weigh batching system eliminates dust
Software Uses MSn Data to Determine the Formula for Unknown Components
Shimadzu's formula predictor uses high mass accuracy MSn data
AdvantaPure
Now available exclusively from AdvantaPure is GammaTag, a read/write RFID (radio frequency identification) tag that's safely sterilizable by gamma radiation.
Product Type: RFID
AdvantaPure
Macro Sensors
Macro Sensors offers user-friendly digital controllers and indicators
GE Fanuc
An index to the latest chemical processing products.
