Displaying 1-169 of 169 results
Pump Control Improves Boiler Efficiency
Cognitive pump technology integrates the boiler firing rate with pump speeds to improve boiler and system efficiency while reducing electrical consumption.
Thermal Solutions Products
Tower Provides High Cooling Capacity
Cooling system offers alternative to field-erected towers.
Blower Supports Simple Installation
Tuthill introduces MPAC 2000 blower package.
Intelligent Marshalling Improves Efficiency
Schneider Electric extends universal I/O capability for Foxboro and Triconex.
Pump Motors Feature High Thrust Capacity
Siemens introduces new high-thrust pump motors.
Emissions Monitoring System Provides Alternative To CEMS
Nationwide Boiler Inc. introduces the DataStak.
Nationwide Boiler
Diaphragms Improve Hygiene
Pure-Fuse Diaphragms offer easier cleanability for hygienic applications.
Gas Analyzer Optimizes Combustion
Oxygen and combustibles analyzer measures the efficiency of fossil-fired boilers and process heaters.
Explosion-Proof Lighting Saves Energy
Explosion-proof high bay LED light fixture provides operators with a powerful and energy efficient alternative to traditional hazardous location luminaires.
Larson Electronics
Device Monitors Water Treatment Issues
The monitoring system provides 24/7 remote monitoring of environmental conditions at unattended water treatment operations.
Sensaphone
Pumps Improve Energy Efficiency
Clamped design offers ease of maintenance and convenient cleanup.
Filtration Modules Lower Water Cost
Dow increases water treatment efficiency with new XP fiber.
Dow Water & Process Solutions
Water System Controls High Heat
Mokon introduces redesigned Duratherm MAX Water System.
Sine Wave Filters Eliminate Motor Damage
Technology converts the rectangular PWM output voltage of motor drives into a smooth sine wave with low residual ripple.
Schaffner USA
Ductless Fume Hood Saves Energy
Purair ECO is designed for chemical and particulate protection for laboratory and industrial applications.
Single-Axis Drive Features Easy Setup And Operation
Siemens introduces Sinamics V20 AC Drive.
Heat Transfer Fluid Exhibits Durability
Hydrogenated terphenyl chemistry expands temperature range for processing applications.
Diaphragm Pumps Reduce Downtime
The advanced flanged range now includes five sizes that are certified to ATEX Zone 1.
VSDs Feature Embedded Intelligent Services
Applications perform more efficiently through embedded process knowledge, configurable on-board dashboards and a graphical HMI display designed to deliver information specifically oriented to the customer’s application.
Combustion System Simplifies With Single, Modular Pla
Honeywell launched the SLATE Integrated Combustion System designed to simplify the engineering of combustion equipment controls in a single platform.
Software Suite Delivers Safety And Efficiency
Aveva launched Control of Work, a suite of products designed to help deliver safety and efficiency when planning and performing routine maintenance and in-plant engineering operations in potentially hazardous plant environments.
Aveva
Dow Introduces Water Application Value Engine
Dow Water & Process Solutions (DW&PS) introduced the Water Application Value Engine (WAVE)—a new digital modeling tool for evaluating components and designing water treatment systems.
Product Type: Software Solution
AMETEK Rotron Introduces MIL-901XP Cooling Fan
AMETEK Rotron introduced the MIL-901XP cooling fan qualified for use in hazardous industrial applications.
Ametek Rotron
GE Introduces AnMBR Membrane Technology
GE introduced a membrane-based wastewater treatment technology combining anaerobic digestion technology with its ZeeWeed 500 membranes to create anaerobic membrane bioreactor (AnMBR).
Ingersoll Rand Introduces ARO Controller
The ARO Controller from Ingersoll Rand delivers touch-and-walk-away automation.
Siemens Introduces NEMA Premium SD661Motor
Siemens released a severe duty motor, the NEMA Premium SD661, for use in the petrochemical, energy and other similar industries and for specialized use in air- cooled heat exchanger applications.
Ingersoll Rand introduced the ARO Controller.
AAF Introduces VariCel 2+ Filter
American Air Filter introduced the VariCel 2+ filter line.
AAF
Schneider Releases Wonderware InTouch Machine Edition
Schneider Electric released a new HMI software product as part of its Wonderware InTouch portfolio.
Schneider Introduces Foxboro Compact 200 Series
Schneider Electric introduced Foxboro Compact 200 Series.
Electric Motor With Brush Protects Bearings
Baldor introduces Super-E Motor with Baldor Shaft Grounding Brush.
VFD Inverter Provides Energy-Efficient Motor Control
Mitsubishi A800 Series inverter combines traditional induction and permanent magnet motors into a single solution
Mitsubishi Electric Automation
Manifold-Mounted Ejector System Reduces Energy Consumption
Piab Updates piCompact Manifold-Mounted Ejector System
eat Exchanger Features Upgraded USDA Hygienic Design
Terlet Launches Terlotherm Delta Range
Terlet
Heat-of-Compression Desiccant Dryers Produce Guaranteed Dew Point of -40 ...
Atlas Copco Introduces XD+ 550-3600 Range of Heat-of-Compression Desiccant Dryers
Rotary Screw Compressor Increases Free-Air Delivery by Up to 13 Percent
Atlas Copco Compressors Extends GA VSD+ Range to 50 Horsepower
Screw Blower Provides Potential Energy Savings of 30 Percent
Atlas Copco Extends ZS Screw Blower Range
Industrial Energy Management System Integrates Existing, Disparate Energy ...
GE Releases PMCS v7.0 Power Management Control System
GE
New Heat Oil Transfer Systems Provide Efficient Temperature Control
Mokon Introduces HTF NPS Positive and Negative Pressure Heat Transfer Oil System
Web-based Energy Data Collection Solution Simplifies Energy Management in ...
Mitsubishi Electric Automation Launches EcoWebServer III
Diaphragm Pumps Boost Safety
ARO electronic interface air-operated diaphragm pumps offer accurate, electronically controlled dosing for chemical processing applications.
Packaged Boilers Include Energy-Efficiency Features
Indeck Launches New Packaged Boilers
Indeck
Process Automation System Optimizes Production and Energy Efficiency
Schneider Electric Announces PlantStruxure PES
Product Type: Integration with IT systems
BPX Brazed Plate Heat Exchangers Withstand High Pressure and High Temperatures
Xylem Expands Its Line of Bell & Gossett BPX Brazed Plate Heath Exchangers
Xylem Inc.
Preconfigured Inverter Includes Preset Speed Selections
Hitachi Introduces NE-S1 Inverter
Hitachi
Motor Line Expands Ratings
Baldor Super-E Motors Include 98 New Ratings
Water-Injected VSD Compressors Offer Potential Energy Savings
Atlas Copco Introduces Water-Injected VSD Compressors
Circular Fluid Bed Dryer Features Rigid Processing Chamber
Kason Offers Vibro-Bed Circular Fluid Bed-Drying System
Pumps Feature Rotary Design
Edwards Releases STP-iXR1606 Pump Series
Software Monitors Energy Costs And Consumption
Iconics Lauches Energy AnalytiX 10.61
Iconics
Power Monitors Measure Energy Consumption
Rockwell Automation Introduces Allen-Bradley PowerMonitor W250 & 500
Dry Vacuum Pumps Feature Tapered Screw Technology
Edwards Launches CXS Dry Pump Line
HOC Dryers Focus On Energy Efficiency
Ingersoll Rand Releases New Line Of HOC Dryers
Heat Transfer Fluid Systems Reduce Space Requirements
Mokon Adds HTF ST Series Heat Transfer Fluid Systems
Servo Provides Alternative To Traditional Stepper Technology
Yaskawa Releases Junma AC Servo
Regenerative Blowers Comprise Cast Aluminum Housing
Ametek Offers Two New Rotron Regenerative Blowers
Ametek Technical and Industrial Products
White Paper Features Reactor Temperature Control Tips
Huber White Paper Offers Information About Products
Huber
Screw Blowers Use Internal Compression
Atlas Copco Introduces Line Of ZS Screw Blowers
Centrifugal Air Blowers Are 100% Oil Free
Atlas Copco Unveils ZB 5-120 VSD Centrifugal Air Blowers
High-Horsepower Motor Comes In NEMA And IEC Frame Sizes
Baldor Expands RPM AC Permanent Magnet Line
Compressed Air Filters Offer Top-Load Design For Confined Spaces
Parker Introduces New Line Of Compressed Air Filters
Engineering Software Offers New Conceptual Design Builder
AspenTech Releases aspenONE V7.3 Engineering Software
Compact Cooling Thermostats Suitable For Tight Spaces
Peter Huber Introduces Ministats Cooling Thermostats
Huber
Vent Heads Feature Internal Drain For Condensate Recovery
Spirax Sarco Introduces VHT Vent Head
CE Compliant Control Minimizes Compressed Air Use
Exair Introduces Digital ETC Cabinet Cooler
Heat Transfer Systems Feature Integrated Circulation Pump
New Heat Transfer Systems From Huber Available
Product Type: Cooling water
Huber
Heat Transfer Fluid Systems Offer Reduced Space Requirements
Mokon Introduces New Stationary Heat Transfer Fluid Systems Line
Universal Connector Handles Super-Heat Steam Lines
Armstrong Introduces 4-Bolt Universal Connector
Armstrong International
Outdoor Air-Cooled Chillers Help Free Indoor Floor Space
Mokon Introduces New Line Of Outdoor Air-Cooled Chillers
Low NOx Optimization Kit Retrofits Existing Burners
Hamworthy Peabody Offers New Low NOx Q-jet Optimization Kit
Hamworthy Peabody Combustion
4-Bolt Universal Connector Withstands Extreme Heat And High Pressure
Steam Trap Includes Cast Steel Cover With Socket Weld Connections
Spirax Sarco Announces FTC80-FB Ball Float Steam Trap
Heat Transfer Oil Systems Line Offers Combined Heating And Cooling
Mokon Expands HTF 350 Series
Float And Thermostatic Steam Trap Features Stainless-Steel Body
Spirax Sarco Redesigns Float And Thermostatic Trap
Temperature Control System Offers Rapid Response Times
Huber Introduces Unistats Temperature Control System
Huber
Package Boiler Products Allow For Upgrades And Conversions
Hamworthy Provides Broad Range of Package Boiler Products
Full-Stroke PTFE Diaphragms Can Enhance AODD Pump Performance
Wilden Increases AODD Pump Performance
New Pump Includes Flanged 76-MM Top Inlet And Bottom Discharge
Wilden Unveils 76-MM Brahma Pump
AODD Pump Utilizes Flap Valves For Maximum Solids Passage
Wilden Pump & Engineering Introduces 51 MM Brahma Pump
Catalyst Filters Capture Particulate At Low Levels
Tri-Mer UltraCat Catalyst Filters Are Available For Boilers
Automation Drive Includes Energy-Saving Features
Danfoss Unveils VLT Automation VT Drive
Danfoss
Steam Trap Handles High-Pressure Steam Lines
Spirax Sarco Updates Thermodynamic Steam Trap
Stainless-Steel Plunger Pumps Provide Corrosion Resistance
Cat Pumps Offers Stainless-Steel Plunger Pumps
CAT Pumps
Heatless Desiccant Dryers Handle Demanding Industries And Applications
Atlas Copco Launches Desiccant Air Dryer Ranges
AODD Pumps Utilize Accu-Flo Technology
Wilden Introduces Advanced Plastic Series A100P AODD Pumps
Heavy-Duty Industrial Fans Handle Heavy-Dust Jobs
Airlanco's New Industrial Fans Available For Extreme Conditions
Airlanco
Programmable Automation Control System Provides Entry For Enterprise Control ...
Invensys' Foxboro PAC System Offers Integrated Hybrid Control
Digital Thermostat Is Suited For Process Temperature Maintenance And Freeze ...
Chromalox Announces Digital Thermostat For Heat Trace System Control
Electronic Steam Boiler Controllers Include 'Inter-Controller' Communication ...
Spirax Sarco Introduces Electronic Steam Boiler Controllers
Modular Frequency Inverter Is Designed For Energy-Efficient Operations
Siemens Industry Launches Modular Frequency Inverter
Vacuum Pump Exhaust Filter Can Help Reduce Safety Violations
Parker Expands Balston Vacuum Pump Inlet And Exhaust Filter Line
Cooling Water Technology Is Designed For Harsh Conditions
GE's Next-Gen Cooling Water Technology Offers Potential Savings
Dry Compressed Air Can Maintain Inks At Consistent Level
Kaeser Cooling Air Provides Dryers For Industrial Processes
Premium Efficient Motors Exceed New Regulatory Standards
Baldor Expands Super-E Motor Line
Feed Water Heaters Maximize Heat Recovery
Cannon Boiler Works
Pumps Come With Quick-Disconnect
New Motors Provide Energy-Efficient Options
New WEG Electric Motors Energy Efficient
WEG Electric Corp.
Grounding Ring Diverts Shaft Currents Around Bearings
Product Type: Isolator
Electro Static Technology
Peristaltic Hose Pumps Handle Range of Liquids
Air Compressor Is Energy Efficient
Ingersoll Rand Launches Nirvana R190-225ne Air Compressors
Temperature Control Features Variable-Speed Pump
Huber launches the Unistat 905w
Huber
Air Compressor Helps Reduce Operating Costs
Quincy Compressor's QGV Air Compressors Reduce Energy Bills
Air Dryer Saves Energy
Sullair Introduces SSRC Compress Air Dryer
Sullair
Fan Motors Tout Operational And Energy Savings
Farr's Gold Series Cartridge Dust Collectors
Compressors Tout Capacities Ranging From 457 To 980 acfm
Sullair Redesigns its 200 HP compressors
Sullair
Inverter Duty Motors Meet NEMA Premium Efficiencies
AutomationDirect's Marathon XRI inverter duty motors meet or exceed NEMA Premium efficiencies
AutomationDirect
Biometric Switch Enables Fingerprint Recognition Technology
Schneider Electric Introduces Biometric Switch For Fingerprint Recognition
Motor Offers Full Torque From Zero RPM
Motor Offers Full Torque At Zero RPM
WEG Electric Corp.
Shell And Tube Heat Exchangers Tout Ultrahigh Purity
Ametek Offers Shell and Tube Heat Exchangers
Ametek Fluoropolymer Products
Packaged Blowers Feature Integrated Controller
Magnet Drive System Touts A Reduction In Weight And Volume
WEG Electric Corp. Introduces W Magnet Drive System
WEG Electric Corp.
Temperature Controllers Simplify Automated Control Processes
Schneider Electric Zelio REG Controllers
Motors Meet International Standards
Baldor Motors Meet International Standards
Hydrotherm Water System Heats Up To 24 kW
Mokon Offers Expanded Hydrotherm Water System
Software Enables Users To Evaluate Energy Efficiency
Baldor Introduces Energy Savings Tool
Motor Management System Contains Network Communication Capabilities
WEG Introduces SRW01 Motor Control Series
WEG Electric Corp.
Reverse Osmosis Systems Suitable For High-Efficiency Water Treatment
Pentair HighPure RO Reverse Osmosis Systems
Pentair Industrial
Air Filter Regulator Handles Harsh Environments
ControlAir Inc. Introduces Air Filter Regulator Type 330
Blower Application Software Can Be Downloaded
Energy Management Solution Helps Reduce GHG
Honeywell Introduces Energy Management Solutions
Filtration System Saves Equipment Costs, Floor Space and Labor Costs
Pentair Industrial introduces the Aqualine Liquid Filtration System, a cost-saving solution for high-flow-rate applications.
Pentair Industrial
Pressurized Membrane System Meets Global Water Challenges
The pressurized ZeeWeed 1500 module offers cost-effective, skid-mounted solutions that can be installed for water treatment, tertiary filtration and pretreatment for brackish and seawater desalination.
Circulation Heater for Reliable Indirect Heating
Watlow introduces the CAST-X 3000 circulation heater — an economically priced heater offering high flow volumes at the required temperature through a single, compact product.
Watlow Electric
“Superheater” Supports Alternative Energy Systems
Chromalox has improved the heating capability and corrosion resistance of its horizontal electric vaporizers to create “superheater” technology to support production of materials for alternative energy systems.
Direct Drive Compressor Is Quiet And Easy To Maintain
Quincy Compressor Releases New Direct Drive Rotary Screw Compressor
Continuous-Duty Compressors Deliver Air Without The Noise
Quincy Compressor Launches its New Xtreme Piston Compressors
Water-Cooled Motors Utilize Wasted Heat
Stainless Motors Inc. Introduces Water-Cooled Motors
Energy Management Solution Also Reports on Greenhouse Gases
Schneider Electric announces the availability of Greenhouse Gas (GHG) reporting with its Square D PowerLogic ION enterprise energy management (EEM) solution.
Motors with Aluminum Rotors Meet the Efficiency Requirements of Many States’ ...
Siemens Energy & Automation, Inc. announces a line of NEMA Premium efficient motors with aluminum rotors.
Pulse Control Module Mounts to Input Terminals
Omega's PCM series pulse control module facilitates conversion of a 4 to 20 mA output to an on/off time proportioning output.
Product Type: Electricity
SCADA Graphical Software Offers Real-time Monitoring and Control of ...
Schneider Electric announces the release of Square D PowerLogic SCADA software version 7.1.
Boiler Harnesses The Sun To Produce Steam
Victory Energy Operations Introduces SolarGen Series Boilers
Victory Energy Operations LLC
Inverters Features an Improved Sensor-less Vector Control Algorithm
Hitachi America, Ltd., Industrial Systems Division, introduces the SJ700 Series of inverters.
Hitachi
Adjustable Frequency AC Drive Provides Adjustable Speed Control of ...
Omega's NFX9000 adjustable frequency AC drive is designed to provide adjustable speed control of three-phase motors.
Semiconductor Heater Saves Energy with Its Compact Size
Omega's RC016 Series of small heaters are compact in size and are designed to prevent condensation, ensuring a minimum operating temperature in small enclosures.
Heat Transfer Media Touts Low Pressure Drop For RTOs
Koch Knight introduces FlexiSaddle low pressure drop heat transfer media
Koch Knight LLC
Circulating Water Temperature Control System Features Stainless Steel Surfaces
Mokon unveils its re-engineered Hydrotherm II Plus
Explosion-proof Liquid Density Meter Does Not Require Barriers or Galvanic ...
Emerson Process Management introduces an explosion-proof/flame-proof version of its Micro Motion 7835 custody transfer density meter.
Contact-Cooled Compressors Maintain Steady Temperatures
Ingersoll Rand contact-cooled compressors deliver increased efficiency
ANSI Flange, Circulation Heaters Have Standardized Design
Chromalox Introduces Global Design for ANSI Flange, Circulation Heaters
C-Face Energy Efficient Gearmotor Offers Combinations up to 10 hp
Baldor Electric Company introduces Dodge QUANTIS GOLD
Power Management Software Solutions Examine Behavior, Improve Monitoring
Siemens Offers Power Management Software
Circulation Heater Is Well-suited for Applications Where Safety and ...
Watlow's CAST-X 500 circulation heater is well-suited for environment where safety and contamination may be an issue
Watlow Electric
AC Industrial Motors Meets API 547 Requirement
Cast Iron and Stainless Steel Pump Models Expand Diaphragm Pump Portfolio
Ingersoll Rand announces expanded its ARO Pro Series portfolio of diaphragm pumps by enhancing the 2- and 3-inch ported metallic pump models to include additional materials of construction.
Magnetic Field Gauss Meter Allows Measurements from 2000 mG to 200 Micro-Tesla
The HHG191 Gauss meter is applied to measuring electromagnetic fields of extremely low frequency (30 to 300Hz) of electric transmission equipment, microwave ovens, air conditioners, computer monitors and video/audio devices.
Motor Protection System Delivers Advanced Graphical Diagnostics
GE Multilin's 369 motor protection system monitors motor health
GE Multilin
Dresser-Rand
Dresser-Rand is offering a new line of single-stage steam turbines, providing API application clients and general industry markets with a rugged and versatile low-horsepower turbine, designed to be equally suited for new or retrofit applications.
Watlow Electric
Watlow's new Rapid Response Heat Exchanger heats gases and fluids as they circulate through the unit's tubular design. It offers users a quick response rate in high-pressure conditions, making it ideal for precision applications.
Schweitzer Engineering Laboratories
Schweitzer Engineering Laboratories, Inc. announces the customizable SEL-3351 Substation Computing Platform designed to replace office-grade PC's in control house environments and the SEL-3301 Protocol Gateway for connecting older and newer equipment.
