Displaying 1-451 of 451 results
Yokogawa Introduces Enhanced YS1000 Controllers
Yokogawa enhanced its YS1000 series single loop controllers.
Meyer Introduces Universal Duty Valves
Meyer introduces Universal Duty Valves.
WM. W. Meyer & Sons Inc.
Cashco Introduces B7 Back Pressure Relief Regulator
Cashco introduced the B7 High Flow/High-Sensitivity Back Pressure Relief Regulator.
Cashco
Seepex Introduces ALPHA Chemical Metering Systems
Seepex introduced a new series of standard ALPHA chemical metering systems designed for simple plug-and-play installations.
Seepex
Crane Launches Pacific Forged Valves
Crane ChemPharma & Energy launched the Pacific Forged line of valves.
CamFil Introduces Stinger Explosion Isolation Valve
CamFil introduces Stinger explosion isolation valve.
Pressure Reactor is Fully Automated
Syrris introduces Atlas Potassium Pressure System.
Product Type: Reactors
Syrris
Bellows Seal Designed For Valve Applications
Senior Operations introduces high-pressure bellows seal.
Senior Operations LLC Metal Bellows
Double Flange Slide Gate Valve Announced
Kemutec announces Mucon DSV Double Flange Slide Gate Valve.
Product Type: Seals & Packing
Kemutec
Rotary Airlock Feeder Is USDA Approved
Meyer introduces Klean-In-Place II Rotary Airlock Feeder.
Stainless Steel Quick Couplings Are Non-Spill and High-Flow
Coupling series offers contamination-free transfer, fill and dispensing of DEF and other chemicals.
Acrylic Flow Meters Feature Interchangeable Direct Reading Scales
Scales offered for water, argon, oxygen, carbon dioxide, nitrogen and helium
Dakota Instruments, Inc.
Fittings Make Press Connections Between Copper and PEX Systems
Viega Transition Fittings Make Press Connections Between Copper and PEX Systems
Viega
Sanitary Butterfly Valve Meets FDA and USDA Standards
Valtorc Introduces Series 535-SN Sanitary Butterfly Valves
Valtorc
Control Valve Handles Energy and Hydrocarbon Processes
Metso Expands Neles Control Valve Line
Metso
Rounded Blade Gate Handles Abrasive Materials
Vortex Adds Rounded Blade Gate to Titan Series Valves
Vortex Valves
Vacuum Receiver Features Clamp-Together Design for Tool-Free Disassembly
Flexicon Launches Vacuum Receiver With Pneumatic Dump Valve
Product Type: Vacuum
Vortex Valves Adds Rounded Blade Gate to Titan Series
Vortex Valves
Double Valve Includes Integrated Soft-Start Function
Ross Controls Announces M Dm2 Series C Double Valve
Ball Valves Are Suitable for Use in Potable-Water Applications
Viega Launches ProPress Zero Lead Ball Valves
Viega
Electric Actuated Ball Valves Include NEMA 4X Enclosures
Clark Solutions Launches 8E Series Electric-Actuated Ball Valves
Hydraulic Pressure Comparator and Pressure Gauge Include Leak-Free Crystal ...
Ametek Crystal Engineering Launches GaugeCalHP Pressure Comparator and XP2i Pressure Gauge
Universal Duty Valves are Suitable for Pollution-Control Applications
Wm. W. Meyer & Sons Launches UDV-Universal Duty Valves for Material Metering
Valve Oven Ensures Purity of Fuel Products
Agilent Technologies Introduces New External Valve Oven for Gas Chromatograph
Control Valve Complies with ISO 15848 Fugitive Emissions Requirements
Flowserve Announces New Valtek GS and Logix 420 Control Valve System
Flowserve
Tubular Cable Conveyers Transfer Friable Materials
Flexicon Launches FLEXI-DISC 6-Inch Tubular Cable Conveyor
Dual-Valve Mass Flow Controllers Manage Flow Into and Out of a Process
Alicat Develops First Bidirectional Flow and Pressure Controller
Alicat Scientific Inc.
Electric Linear Actuators Controls Steam Without Compressed Air
Spirax Sarco Introduces AEL6 Smart Electric Linear Actuators
Combustible Gas Leak Detector Finds Leaks in Industrial Systems
Spectronics Launches PRO-Chek CG Combustible Gas Leak Detector
Spectronics Corp.
Pump System Includes Auto-Fill Option When Flooded Suction is Unavailable
Walchem Introduces Walchem Pump System in Four Configurations
Walchem
Rotary Airlock Valves Feature Tool-Less Access to the Rotor
ACS Drives Launches Rotary Airlock Valves With ACS RotorRail
ACS Valves
Electric Actuator Includes Valve Adaptor to Speed Installation
Spirax Sarco Offers New AEL5 Electric Actuator Range
Air-Cooled Heat Exchanger Monitoring Solution Features Wireless Plug-and-Play...
Emerson Releases Wireless Air-Cooled Heat Exchanger Monitoring Solution
Solenoid Valves Offer Improved SCADA System Drop-Out Current Performance
ASCO Introduces New Products at Emerson Global Users Exchange 2013
ASCO
Rotary Valve Features High-Capacity Rotor Design
ACS Valves Introduces New SD Series of Rotary Valves
ACS Valves
Gauge Expands Psi-Test Capabilities
The XP2i pressure test gauge now comes in a 15,000-psi version.
Crystal Engineering
Backflush Screen Changers Meet Direct Recycling Demands
Maag Presents CSC-BFX Backflush Screen Changer
Maag
Dispensing System Provides Valveless Micro-Volume Fluid Control for Catheter ...
Fluid Metering Introduces PDS-100 Valveless Micro-Volume Fluid Control
Fluid Metering, Inc.
ASME Pressure Vessel Handles up to 15,000 Gallons
Ross Engineering Offers ASME Pressure Vessels
Charles Ross & Son Company
Predictive Diagnostics Suite Available on Any Foundation Fieldbus System
Emerson's AMS Suite Available on any Foundation Fieldbus System
Semi-Automatic Valve Manifold Boxes Feature Rail-Mounted Stick Design
Semi-Gas Systems Simplifies Gas Distribution with Semi-Automatic Valve Manifold Box
Semi-Gas Systems
Digital Valve Controller’s Stainless Steel Housing Prevents Corrosion
Emerson Introduces Fisher Fieldvue DVC6200 Digital Valve Controller
Three-Way PTFE Ball Valve Targets Corrosive and Ultra-Pure Fluid Applications
Aalborg Introduces Three-Way PTFE Ball Valve
Controller Improves Inline Blending
Controller monitors up to five separate blending lines.
West Control Solutions
Shelters Protect Against Hydrocarbon Fires
The 1709 model fire-resistant shelters are designed to protect critical safety equipment from exposure to high-temperature fires in hazardous areas.
Intertec Instrumentation Inc.
Pinch Valve Comes With Sleeve Liner
Schubert & Salzer Launches 7078 Pinch Valve
Schubert & Salzer Control Systems
High-Shear Mixers are Suitable for Frequent Formulation Changeovers
Charles Ross & Son Offers Inline High-Shear Mixers
Steam Trap Handles High-Pressure Drips and Light Process Applications
TLV Corp. Launches P65SRN PowerDyne Trap
Rotary Airlock Feeder Includes Redesigned Two-Slide Bar Supports for Easy ...
Hazardous Location Relay Module Powers Actuators in Hazardous Locations
Wago Introduces Hazardous Location Relay Module
Product Type: Module
Wago
Acrylic Flow Meter Includes Newly Designed Multi-Turn Valve
Aalborg Offers Built-In Needle Valve Option for Acrylic Flow Meters
Steam Traps Now Available in ASTM A182 F91 Material
TLV Releases New Material and Connection Options for HR150A and HR260A Steam Traps
Slide Gate Valve Includes Self-Compensating Polymer Seal
Kemutec Introduces New Mucon Slide Gate Valve
Kemutec
2013
Smart Valve Positioners Help Processing Facilities Comply with Emissions ...
Badger Meter Introduces SRD Smart Valve Positioners
New Trickle Valve System Can Withstand Temperatures of up to 500° F
Aerodyne Announces High Temperature Vacu-Valve
Aerodyne
Motorized Valve Actuator Achieves High Control Accuracy
Schubert & Salzer Introduces 2030 Series Motorized Actuator
Mobile Diagnostics Now Available for Fieldbus Network Control Valves
Emerson Offers Mobile Diagnostics for Foundation Fieldbus Network Control Valves
Lockout Valves Available in Body and Port Sizes
Parker Expands Offering for Pneumatic Lockout Valves
Pump Provides Linear, Repeatable Flow Performance
Watson-Marlow Launches ‘Qdos’ Range for Chemical Metering Applications
Double Flapgate Valve Operates in Temperatures Up to 750 Degrees Fahrenheit
Meyer & Sons Introduces Meyer Monster Double Flapgate Valve
Magnetic Drive Gear Pump Handles High-Tech, Medical and Cooling Systems ...
MG200 Gear Pumps from Clark Solutions Feature Pulsation-Free Operation
Conveyor Moves Fragile Food Products
Flexicon Introduces Flexi-Disc Tubular Cable Conveyors
ATEX-IECx-Certified Inductive Sensors Handle Explosive Environments
Steute Xtreme Releases New Line of ATEX-IECx-Certified Inductive Sensors
Steute Xtreme
Piston Trap Station Minimizes Installation Area
TLV Corp. Launches V1P Piston Trap Station
Safety Relief Valve Handles Liquid, Steam, Air and Gas Services
Spirax Sarco Launches SV418 Bronze Safety Relief Valve
Multi-Gun Operates at Pressures Up to 24,000 PSI
NLB Introduces 24,000 PSI Multi-Gun Valve
NLB Corp.
Forged Manifolds Include Built-In Piston Valve
TLV Corp. Releases MP-Series Piston Manifolds
Flow Meter Includes Compact Stem Accessory
Spirax Sarco Releases Gilflo ILVA Flow Meter with Compact Stem Accessory
Slide Gate Valve Features Dust-Tight Seal
Kemutec Introduces Mucon Slide Gate Valve
Kemutec
Slide Gate Valve Includes Unobstructed Full Bore Opening to Eliminate Jams
Kemutec Launches New Mucon Slide Gate Valve
Kemutec
Flow Meter Features Compact Wafer Design
Spirax Sarco Offers the Gilflo ILVA Flow Meter
Ejector Technology Available as Integrated Platform
Piab Offers COAX Technology in Integrated piCHIP Platform
Qdos Pump Range Features ReNu Pump Head Technology
Remote-Mount Digital Valve Controller Handles Extreme Temperatures
Emerson Introduces Remote-Mount Digital Valve Controller
Balancing Valve Maintains Set Flow Rate During Pressure Fluctuations
Bell & Gossett Introduces The Circuit Sentry Flo-Setter
Bell & Gossett
Ribbon Blender Features Clamps to Eliminate Dusting
Charles Ross & Son Introduces 42B Model Ribbon Blenders
Air Filter/Regulators Prevent Dirty Compressed Air from Impacting AODD Pump ...
Sandpiper Launches Line of Air Filter/Regulators and Lubricators
Warren Rupp
New Instrumentation Valves are Available in Various Sizes and PSI Ratings
Brennan Industries Introduces New Selection of Instrumentation Valves
Brennan Industries
Flanged Valves Include OSHA Lock Out/Tag Out
SVF Flow Controls Introduces B41 Flanged Ball Valves
SVF Flow Controls
Pressure Transducer Used in High-Purity Applications Receives IECEx ...
Brooks Instrument’s SolidSense II Pressure Transducers Receive IECEx Rating
Air/Gas Flow Meter Reduces Energy Consumption
Fluid Components Launches ST75 Air/Gas Flow Meter
Filter Regulator Lube Packs Reduce Valve Operation Hazards
Smith Flow Control Launches Regulator Packs to Ensure Safe Operation of Valves
Smith Flow Control
SIL-Certified Valve Assembly Offers ‘Two Out of Three’ Protection
Norgren Introduces Redundant Valve Manifold
Norgren
Clean Steam Separator Features Enhanced Surface Finish
Spirax Sarco Launches CS10 Clean Steam Separator
Differential Pressure Transducer Features High-Line Pressure Design
AST Introduces New Differential Pressure Transducer
Product Type: Transducer
American Sensor Technologies
Catalog Features a Variety of Tube Fittings
CPV Manufacturing Catalog for Mark VIII O-SEAL Tube Fittings
CPV Manufacturing
Explosion Isolation Valve Prevents Spread of Flames
Rembe Adds the Ventex Passive Isolation Valve to its Product Offerings
Temperature Control Trap Suits Low-Temperature Heating Applications
TLV Introduces LEX3N-TZ Temperature Control Trap
Steam Trap Reduces Copper-Oxide Blockages
TLV Releases P21S PowerDyne Steam Trap
Valves Switch up to Four Times Faster With Pneumatic Volume Booster
Schubert & Salzer Offers 4090 Pneumatic Volume Booster for Faster Valve Switching
Batch Processing Controller Automates Dosing and Dispensing Procedures
Scaletron Introduces Corrosion-Resistant Scales
Scaletron Industries
Tank Blanketing Valve Maintains Non-Combustible Environment
Burling Valve Introduces Pressure Regulator for Blanketing Applications
Burling Valve Company
Compact Actuator Handles Heavy-Duty Service and Tight Spaces
Biffi Italia Launches Pneumatic Actuator Series
Biffi Italia
Wafer Check Valve Now Available in Additional Sizes
Ashi/America Expands PVC Wafer Check Valve Line
Asahi/America
Wireless System Monitors Valves
Westlock Introduces Wireless Valve Monitoring System
Product Type: Hazard analysis
Westlock
Pump Scales to Suit Process Changes
Bredel APEX Hose Pump Handle Corrosive Fluids
System Eases Remote Valve Testing
Netherlocks Offers FAITH Partial Stroke Test System
Netherlocks
Cabinets Extend Safe Shutdown
Intertec Cabinets Protect Against Temperature Fires
Transmitter System Provides Users With Several Sensor Options
Pendotech Offers PressureMAT Transmitter System
Pendotech
Sealed Globe Valves Provide Fugitive Emissions Protection
Crane ChemPharma Offers WTA Bellows Sealed Globe Valves
Crane ChemPharma Flow Solutions
Ball Valve Provides Pressure Up To 600 PSI
Dwyer Introduces UBV Uni-Flange Ball Valve
Replacement Cartridges For Ball Valves Help Reduce Waste
Colonial Engineering Offers Replacement Cartridges For True Union Ball Valves
Steam Trap Station Includes Stainless-Steel Relief Valves
Flowserve Introduces New Gestra Products For Boiler Controls
Flowserve
IML Lock Ensures Valves Are Set In Failsafe Position
Smith Flow Control Introduces IML Lock
Smith Flow Control
Wireless Position Monitor Features On/Off Control For Discrete Valves
Emerson Introduces Wireless Position Monitor
Metering Ball Valve Provides Flow Control For Various Chemical Processes
GF Piping Systems Offers New Metering Ball Valve
110-Gallon Vacuum Handles Big Cleanup Jobs
EXAIR Introduces New Chip Vac
Vacuum Conveyors Feature Receiver-Mounted EPV
Volkmann Introduces Electric Pump Options
Water Heater Offers Instant Temperature Control
Spirax Sarco Launches RediHeat Instantaneous Water Heater
Loader Conveys Powders In Sanitary Applications
K-Tron Introduces Venturi Loader
K-Tron
Valve Model Generator Performs Automatic Assembly
Metso Offers RapidDraw3D Valve Model Generator
Metso
Leak Detection Service Focuses On Valve Seats
Emerson Offers Valve Seat Leak Detection Services
Float Trap Resists Corrosion
TLV Launches J3S-X Float Trap
Regulators Reduce Media Leakage
Rotork Fairchild Unveils High-Pressure Regulator Line
Metering Ball Valve Controls Flow
New design features V-notch ball with 180-degree turn rotation capability.
Pumps Include No Seals Or Valves
Watson-Marlow Launches Qdos Pump Range
Steam Trap Resists Corrosion
Replaceable module enables service without removing the trap body.
Trim Reduces Noise Levels
Metso Introduces Neles Q2-Trim
Metso
Diagnostics Wizard Extracts DCS Configuration
Real-time information is accessed for controller modes, set points, and process variables.
ExperTune
Hose Pumps Handle Corrosive Fluids
Watson-Marlow Bredel Releases Apex Range Pump Line
Level Switch Fits NPT Coupling
SOR Introduces 1540 Level Switch
Valve Position Monitors Provide cCSAus Certification
K Controls Introduces Two Valve Position Monitors
Pressure Regulators Offer Performance Boost
Witt Boosts Performance On Pressure Regulators
Ball Valve Features Three-Piece Design
Viega Propress Introduces Three-Piece Ball Valve
Powder Delivery System Mixes Pharmaceutical Ingredients
Millipore Launches Mobius MIX 1000
Valves And Manifolds Handle Natural Gas Transmission
Parker Hannifin Introduces New Hand Valves And Manifolds
Sensors Measure Ammonium Activity
ECD Launches MVS10/MVS17 Ammonium pIon Sensors
Reducing Valve Includes Air Service Capability
TLV Introduces DR20 With Air System Capability
Strainers Feature Brass Construction
Dwyer Instruments Introduces BYS Brass Y-Strainers
Discharging System Safely Inverts Material Drums
Material Transfer & Storage Offers Dust-Tight Drum Discharging System
Mass Flow Controller Offers Configurable Platform
Brooks Launches GF40/GF80 Thermal MFCs
Industrial Vacuum Handles High-Volume Material Recovery
Vac-U-Max Releases 1020 Industrial Vacuum
VAC-U-MAX
Block Manifold Withstands Repeated Opening And Closing
Dwyer Unveils BBV-1 Three-Valve Block Manifold
Valve Manifold Adapts To Most Pneumatic Applications
Festo Releases MPA-L Valve Manifold
Festo Corporation
Control Booths Limit Impact Of Noise And Dirt
Tri-Mer Introduces Environmental Control Booths
Rotary Airlock Valves Enable Access To Internal Housing
ACS Adds New Rotary Airlock Valves
ACS Valves
Bolted Metallic Pumps Maintain Air Efficiency
Versa-Matic Launches E40 Model Pumps
Pneumatic Conveying System Weighs Bulk Solids
Flexicon Offers Pneumati-Con Conveying System
Pump/Tank Carts Handle Caustic and Acidic Chemicals
Vanton Introduces Mobile Pump/Tank Cart
Compact Measurement Controllers Monitor Low Flow Rates
Bronkhorst Introduces Mini Cori-Flow Measurement Controllers
Bronkhorst USA
Double-Diaphragm Pump Contains No Manifold Seals
Flotronic Pumps Offers Minichem Double-Diaphragm Pump
Flotronic Pumps
PTFE Reactor System Handles Fluorine Or Boron Chemistry
Ace Glass Launches New PTFE Reactor
Ace Glass
Pneumatic Bulk Bag Discharging System Transfers To Silos
Flexicon Offers Pneumatic Bulk Bag Discharging System
Vacuum Conveyor Features Full-Bore Discharge Valve
Volkmann Adds Ultra Low Profile Vacuum-Conveying Unit To VS Series
Flow Meter Includes Inlet/Outlet Needle Valves
Brooks Instrument Introduces New Sho-Rate Flow Meter
Bulk Bag Discharging System Provides Dust-Tight Operation
Material Transfer Offers Material Master Bulk Bag Discharging
Automatic Gas Control Valves Respond To Multiple Process Signals
Severn Offers Capital Controls Automatic Gas Control Valves
Severn Trent Services
Gas-Feed Disinfection Technology Features Automatic Gas Control Valves
Severn Trent Services Introduces Capital Controls Disinfection Technology
Lift Check Valves Prevent Reverse Flow In Pipelines
Spirax Sarco Unveils A New Range Of Lift Check Valves
New Electrochemical Sensors Measure PH And ORP
Invensys Introduces PH12 Series pH And ORP Sensors
New Smart Valve Actuator Utilizes Brushless Direct Current Voltage Motor
Flowserve Announces Limitorque QXM Smart Valve Actuator
Flowserve
Acrylic Flow Meters Handle Gas And Water Flow Applications
Brooks Instrument Launches Series 2500 Flow Meters
Drum Discharging System Provides 180-Degree Drum Rotation
Material Transfer Offers Dust-Tight Drum Discharging System
New Glass-Tube Flow Meter Includes Scale With Rotating Lens
Dust-Tight Drum Discharging System Provides 180-Degree Drum Rotation
Two-Way-Tight Option Available With New Valve Design
Metso Introduces New Valve Design Based On V-Port
Metso
Handheld Communicator Includes Icon-Based Interface
Emerson Introduces New Icon-Based Interface For The 475 Field Communicator
Proportional Relief Valves Handle Up To One-Inch Piping Systems
Swagelok Unveils RHPS Series PRV Valves
Weigh Batching System Simultaneously Weighs Multiple Ingredients
Flexicon Introduces Plantwide Weigh Batching System
Groove Couplings Are Available In Rigid And Flexible Styles
Anvil Unveils Two-Piece Large Diameter Gruvlok Couplings
Anvil International
Long-Range Wireless System Facilitates Tank-Level Supervision
Omega Engineering Unveils HPWS Long-Range Wireless System
Product Type: Wireless
Air Release Valve Maintains System Fluidity
Larox Introduces Air Release Valve
Larox
New Line Of Rotary Airlock Valves May Reduce Service Cycle
ACS Valves Introduces New Line Of Rotary Airlock Valves
ACS Valves
New Valve Driver Manages Proportional Valves
Enfield Technologies Introduces DI PWM Valve Driver
Actuator Offers Modular Air Cylinder Range
Crane ChemPharma Flow Solutions Launches New Products
Abrasion-Resistant Slide Gate Features Dust-Tight Seal
Vortex Valves Introduces Titan Series Slide Gate
Vortex Valves
Low-Flow Control Valve Withstands High Pressure
Badger Meter Introduces Research Control Valve
High-Integrity Pressure Regulator Provides Shutdown And Injury Safeguards
Midland-ACS Launches High-Integrity Pressure Regulator
Midland-ACS
Springless Diaphragm Valves Available In Integratred And Remote Coil ...
Dwyer Instruments Launches DCS/RDCS Springless Diaphragm Valves
Filling Transmitter Handles Machine Applications
Emerson Introduces Micro Motion Filling Transmitter
Digital Pressure Test Gauges Span Wide Ranges
Palmer Instruments Debuts New Pressure Test Gauges
Palmer Wahl Instruments
Slurry Valve Suitable For Light, Medium Applications
ITT Introduces Fabri-Valve 33 PTD Slurry Valve
Electronic Actuators Can Eliminate 90% Of Internal Wiring With Modular ...
ProMation Engineering Offers Electric Actuators
Pressure Regulator Handles Ultra-Pure Liquids
Plast-O-Matic Introduces Kynar Pressure Regulator
Chemical Dosing System Utilizes Rotor Mounted On Eccentric Shaft
Vanton Pump Introduces Flex-I-Liner Model 12
High-Performance Metal Seat Ball Valves Handle Abrasive Fluids
A-T Controls Introduces M-Series Metal Seat Ball Valves
A-T Controls
Steam Trap Includes Cast Steel Cover With Socket Weld Connections
Spirax Sarco Announces FTC80-FB Ball Float Steam Trap
Industrial Vacuum Collects Combustible Dusts
VAC-U-MAX Releases Model 860/02 Combustible Dusts Vacuum
VAC-U-MAX
Push-Through Slurry Valve Handles Harsh Applications
Diaphragm Valve Suitable For Sterile Processes
Alfa Laval Introduces Line Of Diaphragm Valves
Gas Management System Provides Continuous Pressure And Flow
Concoa Unveils Integrated Gas Management System
Concoa
High-Lift Box, Container Dumper Allows Floor-Level Loading
Flexicon Introduces High-Lift Box/Container Dumper
New Needle Valves Feature An Integrated Stem And PTFE Seat
Hayward Flow Control Releases NVA Series Needle Valves
Application Delivers Real-Time Plant Data To Mobile Devices
ExperTune's PlantTriage Available For Mobile Devices
ExperTune
Pinch Valves Meet Stringent Customer Specs
Larox Flowsys Introduces New Pinch Valves
Larox
Control Valve Provides Liquid Cavitation Reductions
Yeary Controls Unveils Sharktooth Control Valve
Yeary Controls
5-Valve Block And Bleed Manifold Features Precision-Machined Valve Stem To ...
Dwyer Introduces New BBV-2 5-Valve Block And Bleed Manifold
Reference Recorder Displays Differential Pressure To 0.025% Accuracy
Crystal Engineering Releases nVision Reference Recorder
Crystal Engineering
Process Filter Gage Determines State Of In-Line Filters
Dwyer Instruments Offers New Process Filter Gage
Calibration System Handles Flow Meters Used In Less-Precise Applications
Flow Dynamics Introduces FTS Continuous Loop Calibrator
Flow Dynamics
Purge And Pressurization System Operates In Highly Corrosive Environments
Pepperl+Fuchs Introduces 5000Q Series Purge and Pressurization System
AODD Pump Utilizes Flap Valves For Maximum Solids Passage
Wilden Pump & Engineering Introduces 51 MM Brahma Pump
New Pump Includes Flanged 76-MM Top Inlet And Bottom Discharge
Wilden Unveils 76-MM Brahma Pump
Intelligent Valve Controller Can Reduce Commissioning Time
Metso Implements Neles Intelligent Valve Controller Upgrade
Metso
Wrap Absorbs Valve Leaks
New Pig Introduces Oil-Only Valve Wrap
New Pig Corp.
Software Suite Extends Predictive Maintenance Capabilities
Emerson's AMS Suite Expands Scope With Profibus DP Support
Pneumatic Conveyor Can Save Energy And Labor
Hapman's MiniVac Features Side-Door Access
Hapman
Three-Way Shut-Off Valve Offers Handle With 180-Degree Rotation
Dwyer Instruments Launches Three-Way Shut-Off Valve
AODD Pumps Utilize Accu-Flo Technology
Wilden Introduces Advanced Plastic Series A100P AODD Pumps
Filter Removes Water From Diesel Fuel And Hydraulic Oils
Serflico Trans-O-Filter Includes Media Options
Serfilco
Non-Contact Transmitter Penetrates Froth And Measures Pulp Height
Hawk Measurement Develops A Non-Contact Transmitter
Hawk Measurement
New Control Valves Can Help Plants Meet Environmental Regulations
Metso Introduces New Line of Control Valves
Metso
Axial Piston Pump Aims To Increase The Productivity Of Heavy-Duty Machines
Parker Hannifin Announces New PV360 Axial Piston Pump
Flow Controller Features Advanced Core Sensor Technology
Sierra Introduces New High Performance Flow Controller
Dump Hopper Provides A Dust-Free Dumping Option
Metalfab's Dump Hopper Features A Baffle And Bin Vent
Metalfab Inc.
Ball Valves Include Seating Options For Varying Temperature Ranges
Tyco Flow Control Launches the Series 300 Ultra-Seal Ball Valves
Tyco Flow Control
Higher Control-Valve Range Provide More Options For Various Applications
Spirax Sarco Releases The New Spira-Trol Range
O-Ring Feed-Through Can Prevent Leaks Into Enclosures
Parker Introduces Captured O-Ring Feed-Through and Bulkhead Fitting
Tune Cascade Loops From A Web Browser
ExperTune Offers Web-Based Tuning Of Cascade Loops
ExperTune
AODD Pump Technology Is Designed Energy Savings
Warren Rupp Launches The AirVantage AODD Pump
Warren Rupp
Customers Can Select Valve Features With Online-Configuration Tool
ASCO Introduces Two- and Three-Way Valves With Online-Configuration Tool
ASCO
Intelligent Control Valve Now Includes High-Pressure Classes
Neles RotaryGlobe Expands Metso’s iCV Offering
Metso
Seals-Free Pumps May Reduce Maintenance Costs
Watson-Marlow’s Bredel SPX Pump Is Designed For Harsh Environments
Temperature Controller Comes Equipped With Position Feedback
Dwyer Instruments Launches New Valve Temperature Controller
Pumps Come With Quick-Disconnect
Minimize Overspray And Quality Problems With Modular Spray System
Spraying Systems’ New Model Offers Precision Spraying
Product Type: Nozzle
Spraying Systems Co.
Polypro Ball Valve Is Ideal For Chemical Applications
Plast-O-Matic Introduces Electrically Actuated Ball Valve
Metal-Seated Ball Valves Include Self-Cleaning System
ChemPharma Introduces Krombach Ball-Valve Line
Automated Overfill Protection Reduces Potential Hazards
SIS-TECH Introduces Automated Overfill Protection System
SIS-TECH Solutions
Two-Way Ball Valve Can Handle Up To 1,500 PSI
Dwyer Instruments Introduces MSV Two-Way Ball Valves
iESD Valves Can Improve Plant Safety
Metso Launches SIL 3-Certified Ball Valves
Metso
Emergency Breathing System Features Integrated Rescue Hose
MSA Introduces ExtendAire II Breathing System
Product Type: Personnel protective equipment
MSA
High-Flow Diaphragm Valve Designed for Improved Flow Performance And Reduced ...
GF Piping Introduces Diaphragm Valve
Safety Valve Controller Is Designed For Emergency Shutdown, Venting
New Neles ValvGuard VG9000 increases safety cost-efficiently
Metso
Software Monitors Instruments, Valves, Controls
ExperTune’s PlantTriage Control System Monitoring Software
ExperTune
Electronic Latching Valve Suited For Green Designs
ITT-Alcon Electronic Latching Valve Ideal for Green Designs
Portable And Fixed Mount Mixers Use Modular Assembly Design
Nettco i-Series Portable and Fixed Mount Mixers
Gas Flow Control Valve Automates Chemical Feed Process
Condition Monitoring Kit Includes Four Machine Assessment Tools
Sanitary Pumps Prove Ideal Where Bacteria, Contamination Must Be Avoided
Moyno Sanitary Pumps Offer Superior Performance Features
Moyno
Bulk Bag System Weighs And Dumps
V-1063 Bulk Bag and Manual Weigh Batch System from Flexicon
Product Type: Weighing
Valveless Chemical Treatment System Delivers Caustic Soda
Flow Conditioner SignifiReduces Flow Meter Straight-Run Requirements
Vortab Co. Introduces VIP Flow Conditioner
Vortab Company
Emergency Relief Vent Is Available In Top-Guided And Hinged Configurations
VCI Introduces Emergency Relief Vent Series
Cashco
System Transports Multiple Samples
Swagelok Showcases SSV Series Analyzers
Pump System Optimizes Tank Cleaning And Spray Nozzles
Fluid Delivery System Introduced by Spraying Systems Co.
Critical Control Functions Easily Changed On Flowmeter
Sierra Instruments' Next-Gen Flowmeters, Controllers
Compressors Tout Capacities Ranging From 457 To 980 acfm
Sullair Redesigns its 200 HP compressors
Sullair
Dirty Service Control Valve Solutions Serve Severe Applications
Emerson Expands Dirty Service Control Valve Solutions
Transmitters Convert Measurements Into Wireless Sensor Signals
Honeywell Adds Universal I/O Transmitters to OneWireless
Explosion-Proof System Inverts Drums Safely
MTS hydraulic Lift & Seal System
Tank Level Gauges Designed For Cryogenic/Liquefied Gas
Mid-West Instrument Introduces Cryogenic/Liquefied Gas Level Indication
Mid-West Instrument
Compact Gauge Valve Reduces Need for Supports
Rotary Disc Valve Touts Leak Tight Shut Off
Larox Flowsys Introduces Rotary Disc Valve
Larox
Pumps Handle Abrasive Liquids
Blackmer
Explosion Isolation Pinch Valve Prevents Deflagration Propagation
Fike Introduces Explosion Isolation Pinch Valve
Fike
Flow Sensor Permits Hot-Tap Access To The Pipe Stream
GF Piping Systems Metal Magmeter
Multi-Port Selector Valve Is Suitable For Corrosive Environments
Field Communicator Features Valve Diagnostic Capabilities
Pneumatic And Electric Actuated Ball Valves Minimize Backlash
Omega's Pneumatic and Electri c Actuated Ball Valves--BVP70/BVP80
Half-Inch Needle Valve Boosts Reliability
Parker Hannifin Introduces Half-Inch Needle Valve
Pressure Sensors Prevent Overflow Of Tanks
Red Valve Co. Inc.
Valve Maintains Set Flow Regardless Of Fluctuations
ITT Bell & Gossett Introduces Optiflo Control and Ultraset Valves
Bell & Gossett
Vacuum Conveyors Meet Traceability Requirements
PIAB Presents Compliant Vacuum Conveyors
Large Butterfly Valve Features An Off-Center Shaft
GF Piping Systems Expands Butterfly Valve Offering
Control-Valve Actuators Provide Precise Operation
Position Monitor Uses WirelessHART Communications
Emerson Process Management Fisher® 4320
Product Type: Communication
PvDF Valve Protects Media Purity
Sampling System Valves Feature Direct In-Line Closed-Loop Design
Sure Seal, Inc.
Polyethlyene Piping Handles Low Temperatures
Reversing Electric Actuators Good For Valve Automation Applications
Hayward 's New Line of Reversing Electric Actuators
Self-Priming Pump Can Handle Harsh Materials
New KNF Pump for Liquids
KNF Neuberger Inc.
Transducers Offer Improved Control Accuracy
Eurotherm’s IP Series Offers Two New Transducers
Eurotherm
Ammonium Sensors Deliver Economical Analytical Measurement Solution
Drum Dumper Seals, Tips, Mates And Discharges Materials
X-0607 Drum Dumper From Flexicon
Pressure, Strain and Force Handbook Features Hundreds Of Products
Pressure Strain and Force Handbook Features Hundreds Of Products
Flowmeter System Handles High-Pressure Applications With Only Two Moving Parts
PD Flowmeter System
Flow Technology
Portable And Fixed-Mount Mixers Can Be Configured Numerous Ways
LIGHTNIN Nettco S-Series Mixer
Electro-Pneumatic Positioners Offer Reliable Control
Bray Electro-Pneumatic Positioners with Reliable, High Performance Control
Bray International Inc.
Air Filter Regulator Handles Harsh Environments
ControlAir Inc. Introduces Air Filter Regulator Type 330
Valve Position Sensor Based On Proven Sensing Technology
Honeywell Adds Valve Position Sensor to OneWireless Portfolio
Desuperheater Promotes Rapid Water Absorption
Pick Desuperheater Series DS
Pick Heaters, Inc.
Relief Valve Good For Low Emission, Overpressure Monitoring
Groth Corp. Introduces 1800A Series Full Lift Type Valve
Continental Disc Corporation
Lockout/Tagout Device Secures Plug Valve
Brady Worldwide Introduces Lockout/Tagout Device
Brady Corporation
Flow Meters Feature More Control And Flexibility
Sierra Introduces Next Generation Flow Meters and Controllers
Ball Valve Delivers Consistent Sealing
Swagelok Introduces FKB Series Ball Valve
Air Blender Lifts And Turns Dry Materials
Dynamic Air Introduces Blendcon Blender
Dynamic Air
Metal-Free Chemical Dispensing System Enhances Safety
Metal-Free Chemical Dispensing System Contains Hazardous Fumes
Colder Products Co.
Rotary Actuator Reduces Valve/Actuator Dimensions
Emerson Process Management Introduces Fisher 2052 Rotary Actuator
Butterfly Valves Offer Superior Chemical Resistance
Valve Status Monitors with DC, AC or Bus Network Signaling
Bray Controls has expanded and improved its Series 52 2N1 ProxSensor line of valve status monitors.
Bray Controls
Software Capabilities Increase Productivity and Project Acceleration
Intergraph has released the latest version of its 3-D design solution, SmartPlant 3D, with expanded functionality.
Product Type: Drawing and layout software
Intergraph
Two-Way Valves with Improved Performance and Online Configuration Tool
ASCO has unveiled its 8262/8263 Series two-way, direct-acting solenoid valves with increased AC and DC pressure ratings and real-time online configuration and ordering.
ASCO
Low–High ESV System Isolates Upstream Flow
Buckling Pin Technology
Explosion-Proof Current-to-Pressure Transducer Is Vibration and Position ...
ControlAir Inc. announces the introduction of the Type-595XP Explosion-Proof Current-to-Pressure I/P Transducer.
Horizontal Batch Mixer Features Adjustable Paddle Blades
Marion Mixers Inc. has unveiled a custom-designed horizontal batch mixer with adjustable paddle blades.
Marion Mixers
Remote Gas Calibrator Expedites Maintenance
Product Type: Detector
General Monitors
Seated Butterfly Valves Target Corrosive Applications
Seated Butterfly Valves Designed For Corrosive Applications
Sampling Valves Utilize a Rack and Gear Combination
Strahman Valves has announced the availability of its "Quick Advance" (QA) sampling valve.
Strahman Valves
Single and Double Block and Bleed Needle Valves
High Pressure Equipment Company has developed a line of block and bleed needle valves that deliver safe, reliable operations up to 20,000 psi.
Filtration System Saves Equipment Costs, Floor Space and Labor Costs
Pentair Industrial introduces the Aqualine Liquid Filtration System, a cost-saving solution for high-flow-rate applications.
Pentair Industrial
Rotary Valve Uses Special Seal Technology
Rotary Valve Uses Special Seal Technology -- POSI-SEAL rotary valve ensures shutoff against maximum rated pressure drop, regardless of flow direction
Control Module for Use in Conventionally Wired Applications
Emerson Process Management announces a FieldQ control module for use in conventionally wired applications.
Retractable pH Sensor for Tough Industrial Applications
ABB has released the Endura TBX587 Retractable pH sensor.
Stainless Steel Solenoid Valve Available In New Size
Magnatrol Valve Corp.
Mass Flow Controller with ANSI or DIN Flanges
Sierra Instruments' Max-Trak Model 180 Industrial Mass Flow Meters and Controllers are now available with 316 stainless steel (ANSI or DIN) flange mounting for gas flow rates up to 1000 SLPM.
Wye Line Diverter Directs Dry Bulk Material
Vortex Valves North America introduces its Quantum Series 3-Way Wye Line Diverter specifically engineered to handle dry bulk solids in pneumatic conveying systems with vacuum or positive pressures up to 15 PSIG (1 barg).
Vortex Valves
Shaft Seal System “Floats” on Water
With the addition of the Water Mizer, Inpro/Seal now offers a number of shaft-sealing systems for use in applications where wet or dry particulates, powders and slurries are handled, processed, packaged and stored.
Inpro Seal
Shaft-sealing Systems Handle Shaft Run-outs and Deflections
Inpro/Seal now offers two shaft-sealing systems for the containment of powders, abrasives, liquids and toxic vapors; the Air Mizer-PS and the Articulating Air Mizer- PS.
Inpro Seal
Filtering Centrifuge Is Designed for Solids/Liquid Separation
The Western States Machine Company's Laboratory Filtering Centrifuge is designed for solids/liquid separation.
Product Type: Centrifugation
Mass Flow Controller Is Insensitive to Fluctuations
Brooks Instrument has released the B-Series mass flow controller, a family of mass flow products designed to be insensitive to fluctuations in pressure and temperature.
Supply Sticks Strengthen, Simplify Process Piping
Direct Drive Compressor Is Quiet And Easy To Maintain
Quincy Compressor Releases New Direct Drive Rotary Screw Compressor
High-Pressure Flange Kit Is NSF Certified
Lubrizol Introduces High-Pressure Flange Kit for reliability and maintenance
Product Type: Replacement components and materials
Lubrizol
Snap-Action, Air Relay Pressure Switches Can Be Fine Tuned
K-TEK Introduces Air Relay Pressure Switches from BETA
K-TEK
Acrylic Rotometers Are Easy to Disassemble
Omega's FL-2500 series direct read rotometer kits offer versatility at a low cost.
Trunnion Mounted, Metal Seated Ball Valves Are Designed for High Temperature,...
Strahman's Trunnion Mounted, Metal Seated Ball Valves have been specifically designed for severe service applications such as those found in oil and gas, petrochemical, refining, polymer, steam, catalyst, DCU (delayed coking unit) and coal gasification industries.
Strahman Valves
Control-Disk Valve Has Double the Control Range
Emerson Process Management introduces the Fisher Control-Disk valve.
Non-metallic Valves Will Operate in Highly Caustic Environments
Groth Corporation announces a line of relief valves designed for environments too corrosive for metallic or fiberglass valves.
Groth Corp.
Compact Control Valves Feature Reversible Actuator
Samson’s 3525 Series Valves Designed For On-Off Service
Samson Controls Inc.
Electronic Valve Actuator Is Designed to Enhance Safety and Reduce Downtime
Flowserve Corporation introduces the Flowserve Limitorque QX valve actuator to its family of electronic actuators
Flowserve
Asset Manager Reduces Costs and Improves Uptime Through Predictive Diagnostics
Flowserve Corporation has launched the Flowserve ValveSight, an asset management solution for integrated control valves and automated quarter-turn valve packages.
Flowserve
Industrial Pump Features a Kalrez Perfluoroelastomer Diaphragm
ITT-Flojet has introduced the G57C, an air-operated, industrial pump with a Kalrez perfluoroelastomer diaphragm from DuPont Performance Elastomers
ITT Industries
Digital Peristaltic Pump May Maximize Productivity
Thermo Fisher Scientific Introduces Peristaltic Pump
Thermo Fisher Scientific Inc.
Mid-West Instrument Offer New Line Of Gauges
Mid-West Instrument
Relief Valve Is Designed For Corrosive Processes
Groth Corp. Introduces Relief Valve For Corrosive Processes
Groth Corp.
Tank Level Gauges Work With Cryogenic/Liquefied Gas
Mid-West Instrument Introduces Tank Level Gauges
Mid-West Instrument
Spring-energized Seals Are Designed for High-Performance Aerospace Applications
CoorsTek introduces the redesigned MetaPlast II spring-energized seal
CoorsTek, Inc.
Software Suite Simplifies the Setup and Management of Smart Wireless Networks
Emerson Process Management announces its AMS Suite: Intelligent Device Manager 9.5 applications for planning and managing scalable wireless networks to support the growing demand for wireless solutions in the process automation industry.
Piping Software Features New Look
Engineered Software, Inc. Releases PIPE-FLO Professional 2009
Explosion-Proof Compressed-Air Dryers Deliver Without Electricity
Parker Hannifin’s Explosion-Proof Compressed-Air Dryers Deliver Without Electricity
Product Type: Membrane technology
Chemical Instrumentation | Gems Introduces UCL-510 Ultrasonic Continuous ...
Gems Introduces UCL-510 Ultrasonic Continuous Liquid Level Sensor
Gems Sensors & Controls
Ball Valve Features a Locking Handle for Added Security
Asahi/America, Inc. introduces a locking handle for their Type 21 Ball Valves
Asahi/America, Inc.
Ultrasonic Flow Transmitters Bring “Sing Around” Technology to a Range of ...
Clark Solutions unveils the ClarkSonic Ultrasonic Flow Transmitters
Local Operator Interface Is Available for Mass Flow Meters and Controllers
Brooks Instrument releases local operator interface for its 4800 Series Mass Flow Meters and Controllers
Acrylic Flow Meters Feature Dual Interchangeable Scales
Dakota Instrument unveils its ACR Clear Acrylic Flow Meter
Differential Pressure Transmitter Offers Full Over-Range Protection
Mid-West Instrument’s 4-20mA Differential Pressure Transmitter An Option on Model 240
Mid-West Instrument
Enhanced Mass Flow Meters/Controllers Offer Digital Communications and a ...
Brooks Instrument Enhances Its 4800 Series of Mass Flow Meters/Controllers with Digital Communications and a Downport Connection Option.
Three-Way Valve Improves Temperature Control
Emerson’s Fisher GX 3-way valve improves temperature control
Fluid Handling Instrument | Plast-O-Matic Valves Introduces Spigot Ends for ...
Plast-O-Matic Valves Introduces Spigot Ends for Valves and Regulators
Product Type: Spigots
Bulk Bag Discharging Application Increases Batch Accuracy
National Bulk Equipment Offers Bulk Bag Discharging Application
National Bulk Equipment, Inc.
New Spray Nozzle Promotes Process Productivity
Delavan Spray Technologies Showcases SDX spray Drying Nozzles
Stainless Steel Valve With Inflatable Seat Offers Leak-Proof Seal
Posi-flate
Sanity V-Blenders Can Be Customized to Fit Your Intimate Dry Blending Needs
Ross V-Blenders can be customized to fit your intimate dry blending needs
Horizontal Cartridge Dust Collector Provides Efficient Filtration in a ...
MikroPul's MikroFlo horizontal cartridge dust collector provides efficient filtration in a compact size.
MikroPul
Cost-effective Metal Detector Introduced for Bulk Flow Products
Mettler-Toledo Safeline introduces its new cost-effective metal detector.
Mettler Toledo
Gore Products Covers a Range of Sealing and Fluid Handling Requirements
W. L. Gore offers wide range of sealing products
W.L. Gore
Metal-seated Valve Design Introduced for Critical Service Applications
Metal-seated valve design introduced for critical service applications
Hemiwedge Valve Corporation
Blower Package Features the Qx Blower and a Noise Enclosure
The Qube by Tuthill is a quiet and low-cost solution for pneumatic conveying, wastewater aeration and more.
Product Type: Blower
Cast Iron and Stainless Steel Pump Models Expand Diaphragm Pump Portfolio
Ingersoll Rand announces expanded its ARO Pro Series portfolio of diaphragm pumps by enhancing the 2- and 3-inch ported metallic pump models to include additional materials of construction.
Diaphragm Metering Pump Offers a Built-in DFD Leak Detection System
Omega Engieering's PHP-800 Series diaphragm metering pump has PVDF double ball valves, can pump up to 42 GPH (2700 ml/min), and handle output pressures up to 12.1 bar (175 psi).
Enhanced Digital Valve Controller Is SIL3 Certified
Emerson's Fisher Fieldvue DVC6000 digital valve controller is SIL3 certified
Weigh Batching System De-Lumps the Product and Feeds It Gravimetrically into ...
Flexicon's weigh batching system de-lumps the product and feeds it gravimetrically into rigid bins
Miniature Solenoid Valves Isolate Fluid Hermetically
Omega's solenoid valves isolate fluid hermetically
Multipurpose Ball Valves Offer Positive, Quarter-Turn Shutoff
Swagelok valve family expands with multipurpose ball valves
Manual Dump to Rigid Bin Weigh Batching System Eliminates Dust
Manual dump to rigid bin weigh batching system eliminates dust
Small-scale Contained Filter Dryer Provides Efficiency and Versatility
Contained filter drying designed for R&D
Powder Systems Limited
Flanged Ball Valve Is Fire Tested to Ensure High-Temperature Performance
Flanged ball valve from Assured Automation passes fire test
Assured Automation
High-Pressure Metering Pump Covers a Wide Range of Applications
Watson-Marlow launches high-pressure metering pump
Space-saving Flow Meter Measures Process Gas or Air Flows
FCI introduces space-saving flow meter
Quick-Access Screener Speeds Cleaning, Inspection and Screen Changes
Quick-access screener speeds cleaning, screen changes
Precision Epoxy Protects, Seals and Reconditions Surfaces
Ceramic-filled epoxy protects, repairs surfaces
Category: Materials of construction
Product Type: Coatings/linings
Devcon
Gear and Lube Oil Filtration System Is Designed for Higher Viscosity Fluids
Portable gear and lube oil filtration system from Trico fills major void
Trico Corporation
Miniature Rotary Batch Mixer Blends with 100% Uniformity
Munson's miniature rotary batch mixer blends with 100% uniformity
Dry Vacuum Pump Valve Features a Wedge Sealing System
Dry vacuum pump valve features wedge sealing system
BOC Edwards
Metering Pump Offers Precise Control in Low-Flow Applications
Metering pump offers precise control in low-flow applications
Moyno
Tank Level Gauges Are Suite for Cryogenic/Liquefied Gas Applications
Mid-West releases tank-level gauges for cryogenic, liquefied gas
Mid-West Instrument
MVGT Trays Provide Increased Capacity
Sulzer Chemtech's MVGT trays provide increased capacity
Product Type: Distillation
Sulzer Chemtech
Peristaltic Pumps Are Designed for the Metering, Dosing and Transferring of ...
Watson-Marlow Bredel introduced its 520/620/720 family of peristaltic pumps are designed for the accurate metering, dosing and transferring of sensitive fluids in sanitary environments, making them ideal for accurate filtration, fermentation, dispensing, coating and seamless integration into ...
Mid-West Instrument, Inc.
Mid-West Instrument, Inc. introduces a new line of tank level gauges for cryogenic/liquefied Gas for both stationary and mobile applications.
Mid-West Instrument
Lasso Technik
Lasso Technik announced the patented Stop-Silent Check Valve Series to the U.S. market.
Lasso Technik
Flowserve Corp.
Flowserve Corp. launched the Flowserve Logix 3400IQ Foundation Fieldbus digital valve positioner. The 3400IQ features a new FISCO-compliant user interface board, improved potentiometer, piezoelectric technology, and host interoperability to provide operating versatility and fast, easy and ...
Flowserve
Conval, Inc.
Conval a supplier of high-temperature, high-pressure valves recently announced the addition of ASME III, Class 1, 2, 3 and NPT certifications to its list of quality credentials. The N-stamp certifications are now available on the company's Clampseal globe and check valves, Swivldisc gate valves, ...
Blackmer
Blackmer, a supplier of positive displacement rotary vane, eccentric disc, peristaltic hose and centrifugal pump technologies, announced the addition of the SX3 Series to its line of stainless steel sliding vane pumps.
Blackmer
Veriflo
Veriflo offers miniature point-of-use pressure regulator
Rithmware Technologies Releases Drying-centered Simulation Software
Rithmware Technologies releases drying-centered simulation software
Metso Automation
The ND9000 intelligent valve controller from Metso Automation, designed to operate with most control valve actuators, allows users to benchmark control performance on rotary and linear valves.
Metso
Midland Manufacturing
Midland Manufacturing presents a new ball valve seat designed to provide higher dimensional stability and improved sealind in low and high temperatures
Flowserve Corp
Flowserve Corp. announcces the Limitorque MX smart electronic valve actuator
NLB
NLB offers high-flow multi-gun valve
NLB Corp.
GF Piping offers paddlewheel flowmeter line
McCrometer
Macro Sensors
Macro Sensors offers user-friendly digital controllers and indicators
Donaldson
Donaldson introduces fully tested containment system
McCrometer
Sullair
Sullair
Neptune
Waukesha Cherry-Burrell
Norcross
Cyclonaire
Cyclonaire phase conveyors can handle abrasive materials
Flowserve
Cyclonaire
Moore
Martin
IEDCO
Neptune Chemical Pump
Pelletron
Kleentek
Macro Sensors
Leistritz
Milwaukee Valve Company
George Fischer
Drexelbrook
Pelletron
Hansen Technologies
George Fischer
Asahi/America
General Monitors
ExperTune PlantTriage Assesses Batch Process Performance
ExperTune's new release of PlantTriage software assesses the performance of batch processes. It pinpoints areas where improvements can increase yields, throughput, and decrease turnaround times.
ExperTune
Kaeser Compressors announces the new H Series dryers – the latest addition to its comprehensive line of refrigerated dryers. Available in flows from 12 to 123 scfm, these non-cycling refrigerated dryers use Kaeser's proven heat-exchanger technology to consistently produce dew points as low as 35ºF.
Asahi
Asahi/America, Inc. introduces the Quarter-Bloc PVC True-Union Ball Valve. The NSF-61 certified valve features all-thermoplastic construction with no metallic parts, and offers excellent flow characteristics due to the full orifice opening, which is equivalent to the inside diameter of the ...
Its angled vent valve is easy to actuate, even when the Swagelok® remote-mount two-valve manifold is panel mounted. This compact manifold features a non-rotating, hardened needle design to minimize seal wear, protect the seat from galling, and promote long service life and leak-tight shutoff.
George Fischer
George Fischer, Inc. has introduced the economical H2O Type 374 Valve designed specifically to provide superior performance in water applications. NSF 61 certified for potable water applications, the new true union valve offers a number of safety and convenience features in a compact size that ...
Jacob Tubing
The new Jacob Tubing USDA valve is designed specifically for low pressure/vacuum conveying, bulk material handling and air flow systems for the dairy, food and pharmaceutical industries where equipment must meet USDA Dairy sanitary levels or equivalent.
Asahi/America Inc.
These globe control valves are designed for precise flow control and are available in both pneumatic (air to spring) or electric (115vac 1ph supply voltage), in body materials of PVC, PP, PVDF and PTFE, and in sizes from ½-inch to 4-inches.
ISL-USA
Flowserve Corp.
Burkert
ITT Industries Engineered Valves Group
CPV Manufacturing
ZOOK Enterprises LLC
Red Valve Co. Inc.
Noveon IP Holdings Corp.
Woodward Industrial Controls
Roto-Disc Company
Asahi/America Inc.
Fauske & Associates
An index to the latest chemical processing products.
2006
2009
2007
2012
2014
2004
2005
2008
2010
2011
Displaying 1-451 of 451 results
