Displaying 21-30 of 1637 results
Smart Sensors Reduce Motor Downtime
A new smart sensing solution from ABB can reduce downtimes of low-voltage motors.
Butterfly Valves Withstand Elements
Bonomi butterfly valves are suited for use in industrial heating, hydrocarbon and chemical processing, power generation and other industrial applications.
Bonomi North America
Butterfly Valve Enhances Safety
Triple offset butterfly valve delivers flow control, optimized Cv and low Delta P in a single valve.
Unit Loosens Agglomerated Material
System utilizes hydraulically actuated pivoting conditioning arms with extended travel and features "v-shaped" tubular breaker profiles to efficiently return severely agglomerated materials to a free-flowing state.
Product Type: Agglomeration
Membrane System Requires Less Air
Hollow-fiber membrane provides efficient separation of nitrogen from air.
Product Type: Membrane technology
Evonik
Filters Withstand Repeated Steam Cycles
Filter cartridges can withstand 250 steam sterilization cycles for one hour at temperatures of 142°C.
Porvair
Bulk Bag Discharger Fits Restricted Areas
Low-cost frames of variable heights and offsets fit restricted areas previously used for dumping smaller containers such as sacks, pails, drums, boxes and bins.
Mixer Enables Higher Viscosity Processing
Pumping rotor design increases flow capacity.
Silverson Machines
Compact Data Acquisition Device Benefits Small Control Applications
The Memograph M RSG45 Data Manager acquires, displays, records, archives, analyzes and transmits process data to control systems, PCs and maintenance devices.
Wirelessly Monitored Valves Provide Emissions Control
Emerson introduces wirelessly monitored storage tank safety valves.
