Displaying 21-30 of 2684 results
Airlock Suits Sanitary Processes
The new CMD Airlock is suitable for applications where dry raw or finished products are handled and where inspection or system clean-out are required.
Diaphragm Seal Stops Clogging
Flush flanged diaphragm seal isolates pressure instruments from harsh media.
Flow Hoods Minimize Turbulence
Rear wall perforations remove air at the rear of the cabinet to minimize any turbulence.
Multi-Valve Manifolds Equalize Pressure
Ashcroft has introduced a line of stainless steel valve and manifold accessories for use in pressure instrument installations.
Flow Meter Features Hazardous Location Option
Coriolis flow meters feature explosion-proof transmitter with intrinsically safe sensors.
Sensors Increase Range
Liquid level sensors are designed for larger remote tank applications or for mounting on bridges or piers in water level monitoring applications.
Senix
Flow Meter Simplifies HPLC Pump Calibration
Digital liquid flow meter volumetrically measures and records solvent exiting from HPLC systems.
Tovatech
Connectors Improve Fluid Management
Users can connect, reconnect and disconnect even when flow path is wet and pressurized.
Separator Applies Acoustic Wave Technology
The acoustic separator provides cell and protein yields in a closed system without centrifugation.
Pall Corporation
Hydraulic Cylinders Handle High Heat
The Vulcan Series is suited for industrial workplaces with rugged operations, continuous cycles and hot environments.
Milwaukee Cylinder
