Displaying 11-20 of 20 results
Oil-Free Compressor Has Built-In Recovery SystemAtlas Copco's net zero energy consumption compressors recover energy in the form of hot water Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Compressed Air System Reduces Energy CostsCompressed Air System Reduces Energy Costs Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Efficient, Economical Rotary Screw Air CompressorsSullair Corporation announces the availability of its ShopTek lubricated rotary screw air compressor. Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Piston Compressors Packaged For Quiet OperationQuincy Compressor unveils the QT-Xtreme and the PLT-Xtreme, continuous-duty reciprocating compressors with a canopy for delivering reliable shop air without all the noise. Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Contact-Cooled Compressors Maintain Steady TemperaturesIngersoll Rand contact-cooled compressors deliver increased efficiency Category: Fluid handling Product Type: Compressors |
Manufacturer: |
EndurAir Compressor Package Offers a Built-in, Three-Stage Oil Separation SystemGardner Denver's EndurAir rotary air compressor package offers a built-in, three-stage oil separation system Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Booster Compressors Provide Pressures up to 650 PsigKaeser expands compressor line to 650 psig Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Kaeser CompressorsKaeser Compressors announces the new H Series dryers the latest addition to its comprehensive line of refrigerated dryers. Available in flows from 12 to 123 scfm, these non-cycling refrigerated dryers use Kaeser's proven heat-exchanger technology to consistently produce dew points as low as 35ºF. Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Kaeser Compressors announces the BSD 60Compressor offers zero-loss transmission efficiency Category: Fluid handling Product Type: Compressors |
Manufacturer: |
Centrifugal Compressor Features a Damper Seal DesignDresser-Rand's damper seal design for DATUM centrifugal compressors improves rotordynamic stability at high pressures and reduces section-to-section leakage in straight-through and back-to-back compressor configurations by as much as 50 percent Category: Fluid handling Product Type: Compressors |
Manufacturer: |
