Not all foams are created equally. For example, Ross foams form from a liquid solution with an incipient formation of a second liquid phase. Marangoni foams are stabilized by surface tension gradients due to mass transfer. And particulate foaming happens when solids are present in liquids and increase the solution viscosity. Increased viscosity inhibits the drainage of foams and stabilizes them.
Preventing contaminants from entering the system is nearly always the most effective method to prevent foaming, but often not the most cost effective method. Additionally, anti-foams are commonly used to reduce the foaming tendency of the process. They generally serve to assure a uniform surface tension on the liquid portion of the foam. This removes the surface tension gradient that stabilizes the foams. But Different types of anti-foams work well in some systems and work poorly, or even promote foaming, in other systems.
To help you sort through your foam problems, Sulzer Chemtech has put together a white paper: Foaming in Fractionation Columns. This paper aims to shed light on the foaming process and its root causes so that steps can be taken to eliminate or minimize the formation of foaming.
