Chemical Processing Powder eHandbooks
Download our latest Powder eHandbooks.
Share Print Related RSS
CP Powder eHandbook: Effective Powder Processing
As many chemical processors know, processing powders can be tricky. Powder properties can be affected if the materials are stored for long periods. Powders can be compressed, vibrated, aerated and exposed to moisture. And specific processes like granulation, blending, drying, milling, lubricating and compression put requirements on how powders can be handled. In this Chemical Processing Powder eHandbook, we take a look at how to effectively process powder including:
  • Compression dryers – the case for choosing a solution that produces optimal air quality and low energy consumption
  • GHS – understanding the requirements and what it means to chemicals processors
  • Predicting powder flow behavior
  • Vibratory screen cleaning methods
  • Fine powder flushing - eliminating a common bin-afflicting problem caused by trapped air
  • Tubular Drag Conveying Technology – an alternative to pneumatic conveying
  • Addressing dust hazards – including explosions
CP Powder eHandbook: Tips for Effective and Safe Handling of Solids
Overview:
powder e-handbook may 2012One of the trickiest materials to process, solids are comprised of powders or particulates, a continuous gaseous phase (usually air) and, almost always, a liquid component. Processors that handle solids know only too well the types of throughput problems that come up on a recurring basis. Effective, economical and safe slurry management; flowability during processing, accurate inventory and volume level management are all very real challenges faced by processors of solids. In this Chemical Processing Powder eHandbook, we take a look at how to effectively handle solids including:
 •Properly accounting for how bulk solids actually will flow in a vessel or overall process -- we take a look at some simple parameters that can often provide a good sense of flowability
 •Strategies for avoiding slurry trouble
•Mitigating pipe segment force imbalances with Reactor Excursion and Leakage Analysis Program
 •Acoustics-based level measurement for accurate powder measurement in bins, tanks and silos
 •Explosion protection methods including suppression, isolation and venting.
Download your copy of this Chemical Processing Powder eHandbook now.
Chemical Processing Powder eHandbook: Succeed at Solids Handling
Overview:
Succeed at Solids HandlingOne of the trickiest materials to process, solids are comprised of powders or particulates, a continuous gaseous phase (usually air) and, almost always, a liquid component. Processors that handle solids know only too well the types of throughput problems that come up on a recurring basis. Clumping; effective, economical and safe slurry mixing; dust management and dust explosion risk mitigation are all very real challenges faced by processors of solids. In this Chemical Processing Powder eHandbook, we take a look at how to effectively handle solids including:
 •Clumping – the 10 most common sources of agglomeration in bulk solids and how to effectively manage them
 •Strategies for optimal slurry mixing
 •Level management detection in storage vessels
 •Dust explosion risks – how to identify and mitigate when processing solids
 •Managing solid cohesiveness with flow strategies
Chemical Processing Powder eHandbook: Address Challenges Posed by Powders
Overview:
Address Challenges Posed by PowdersOne of the trickiest materials to process, powders are comprised of solids or particulates, a continuous gaseous phase (usually air) and, almost always, a liquid component. Many factors influence powder composition including size and distribution, surface roughness and hardness. And, how powders are processed -- vibration, compaction, attrition, segregation -- can influence how powders react. In this Chemical Processing Powder eHandbook, we take a look at how to effectively handle powders, safer dryer operations and how to manage phase changes when processing powders. Download your copy today. Download your copy today.
What are your comments?
Comments
