Compressed Air Systems: The Secret is in the Pipe
There’s no such thing as too large a compressed air line.  A common error in compressed air systems is line sizes too small for the desired air flow.
By Hank van Ormer, Don van Ormer and Scott van Ormer
1 of 3 < 1 | 2 | 3 View on one page
A common error we see in compressed air systems, in addition to poor piping practice, is line sizes too small for the desired air flow. This isn’t limited to the interconnecting piping from compressor discharge to dryer to header. It also applies to the distribution lines conveying air to production areas and within the equipment found there. Undersized piping restricts the flow and reduces the discharge pressure, thereby robbing the user of expensive compressed air power. Small piping exacerbates poor piping practices by increasing velocity- and turbulence-induced backpressure. (See “There’s a Gremlin in your air system – Its name is turbulence,” pg 37, Plant Services, July 2002).
Pipe size and layout design are the most important variables in moving air from the compressor to the point of use. Poor systems not only consume significant energy dollars, but also degrade productivity and quality. How does one properly size compressed air piping for the job at hand? You could ask the pipefitter, but the answer probably will be, “What we always do,” and often that’s way off base.
Another approach is matching the discharge connection of the upstream piece of equipment (filter, dryer, regulator or compressor). Well, a 150-hp, two-stage, reciprocating, double-acting, water-cooled compressor delivers about 750 cfm at 100 psig through a 6-in. port. But most 150-hp rotary screw compressors, on the other hand, deliver the same volume and pressure through a 2-in. or 3-in. connection. So, which one is right? It’s obvious which is cheaper, but port size isn’t a good guide to pipe size.
Charts and graphs
Many people use charts that show the so-called standard pressure drop as a function of pipe size and fittings, which sizes the line for the what is referred to as an acceptable pressure drop. This practice, too, can be misleading because the charts can’t accommodate velocity- and flow-induced turbulence. Think about it. According to the charts, a short run of small-bore pipe exhibits a low total frictional pressure drop, but the high velocity causes an extremely large, turbulence-driven pressure drop. Then, there’s the question of the meaning of acceptable pressure drop. The answer to this question often isn’t supported by data, such as the plant’s electric power cost to produce an additional psig.
We’ve audited many plants during the past 20 years and found the unit cost of air for positive displacement compressors runs from several hundred dollars per psig per year to several thousand dollars per psig per year. At current energy costs, you don’t want the pipe to be a source of pressure drop.
Shooting blind
Not knowing the energy cost of lost pressure as a function of line size can lead to a blind decision. Unfortunately, this is what we find in most of the air piping systems installed during the past 30 years. Older systems that were designed with care are often right on the mark, except if they’ve been modified after the original installation.
Some might call pipe sizing a lost art, but we see the issue as a lack of attention to detail, basic piping principles and guidelines. Read on to learn how to size air piping using velocity, which, when combined with appropriate piping practice, ensures an efficient compressed air distribution system. As compressed air system consultants and troubleshooters, we use these guidelines to design new piping systems and to analyze existing system performance and opportunities for improvement.
Interconnects and headers
The interconnecting piping is a critical element that must deliver air to the distribution headers with little pressure loss, if any. This isn’t only an energy question. Also ensures the capacity controls will have sufficient effective storage to allow them to react to real demand and translate less air usage to a comparable reduction in input electrical energy.
Show Comments
Hide Comments
Join the discussion
We welcome your thoughtful comments. Please comply with our Community rules.
Register for free
Log in for complete access.
Comments
  • <p>Nice blog..!!</p>
    Reply
  • <p>&lt; According to the charts, a short run of small-bore pipe exhibits a low total frictional pressure drop, but the high velocity causes an extremely large, turbulence-driven pressure drop &gt;</p> <p>I'm not understanding what is being said/implied here. If I use Crane as an example, 50 cfm free air through a 1/2" sch 40" pipe has a pressure drop of 8.49 psi per 100 feet piping, this pressure drop is actually low?</p>
    Reply
  • <p>Using the similarity of air pressure to voltage, flow rate to current, and pipe friction loss to wire resistance, we should maybe consider borrowing an electrical practice.</p> <p>In electrical design, wire sizes are selected to limit voltage drop in the distribution room to 2%, and to limit voltage drop from the electric room to the farthest point to 3%.</p> <p>Using this logic for a 100 PSI compressor, the piping in the compressor room should be selected for a 2 PSI drop to the compressor room wall, and the piping in the plant is size for a 3 psi drop to the farthest point of use.</p> <p>Instead of complaining about the cost of "oversized" pipe, we should point out the energy saved for the life of the plant's operation.</p>
    Reply
