Flow Meter Focus
ChemicalProcessing.com introduces Flow meter focus, a compilation of useful articles, news, white papers and product information related to flow meters.
Flow meters are critical instruments at plants across many industries. ChemicalProcessing.com has created Flow meter Focus - a one-stop destination for flow meter information. You'll find articles, white papers, and news on flow meter use as well as editor-selected flow meter products.
Articles
Understand the attraction of magmeters - Magnetic flowmeters provide accuracy and can be used in a variety of applications and environments.
Bend it like Coriolis - Understand the basics of Coriolis flowmeter design. Dual curved-tube and single straight-tube meters offer different advantages.
Taking the pulse of fluid metering - Applications benefit from more precise dosing and improved control.
Can I use a drive to control flow? - A reader asks, "I'm hearing about using a drive with my pump and motor setup for better flow control instead of control valves. Is it worth it? Do I still need some measure of flow control besides a shut-off valve?" Read the answer here.
Calibrating a Parshall flume - A reader has a calibration question regarding Parshall flumes. You can read the answer here.
Make the most of averaging Pitot tubes - These straightforward devices can handle a wide range of flow applications.
The best point - Run your pump at best efficiency and improve process performance
Test it right - The appropriate testing procedures can help direct the selection of pressure or vacuum filtration equipment and ensure optimum equipment operation.
A better blend - A well-maintained continuous liquid blending system boosts dependability and product quality.
Models take off - Process simulation historically has taken place within proprietary modeling environments. However, the ability of simulators to more accurately handle demanding tasks continues to evolve.
Boosting blending accuracy - Optimizing operations using coriolis technology.
Automation vision comes to life - Digital automation helps BASF save time and money, achieve goals and improve loop checking.
Pumping up performance and profit - Enhancing instrument reliability and repeatability.
Fieldbus technology: Cut through the confusion - Fieldbus technology offers many benefits to a chemical processor if used correctly. The key is to focus on front-end design to achieve the full benefits of fieldbus technology.
Nothing like the real thing - Chemical process plant comrades talk about the ways they're making newer technologies work for them.
Make the most of HART-enabled devices - HART-enabled field devices offer many benefits and not just for process control. They can lead to productivity gains, maintenance savings and more efficient and accurate recordkeeping.
Take out torque - A reader's ribbon blendor is experiencing torquing problems. Read tips about how to avoid torque problems in a ribbon blender.
White papers
Technology expands flowmeter capabilities, reduces costs - Capacitance-type magnetic flowmeters have traditionally offered the advantage of having non-wetted electrodes and the ability to measure low conductivity fluids. However, they suffered from a sensitivity to flow noise and zero instability. Innovative technology overcomes these limitations and drives magnetic flowmeters into new areas of application, while reducing installed costs.
Accurate steam mass measurement - Vortex meters are ideal for measuring saturated steam flow, and now can be used to measure mass flow with integrated temperature sensor and controller software. These meters can also be integrated into a Foundation Fieldbus industrial network system.
News
New applications & literature CD features 50 years of flowmeter expertise - McCrometer's new A-Z Flowmeter CD contains the company's most up-to-date flow technology, applications and product specification information based on its 50 years of expertise.
What are your comments?
Comments
